/** ****************************************************************************** * [url=home.php?mod=space&uid=288409]@file[/url] main.c * [url=home.php?mod=space&uid=187600]@author[/url] Alexander * [url=home.php?mod=space&uid=895143]@version[/url] V1.0.0 * [url=home.php?mod=space&uid=212281]@date[/url] 04-January-2023 * [url=home.php?mod=space&uid=247401]@brief[/url] Main program body ****************************************************************************** * @attention * * Copyright (c) 2023 HKMicroelectronics. * All rights reserved. * * This software is licensed under terms that can be found in the LICENSE file * in the root directory of this software component. * If no LICENSE file comes with this software, it is provided AS-IS. * ****************************************************************************** */ /* Includes ------------------------------------------------------------------*/ #include "main.h" /** @addtogroup HK32F030Mxx_StdPeriph_Examples * @{ */ /** @addtogroup GPIO_IOToggle * @{ */ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ #define BSRR_VAL 0x0006 /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ GPIO_InitTypeDef GPIO_InitStructure; /* Private function prototypes -----------------------------------------------*/ /* Private functions ---------------------------------------------------------*/ /** * @brief Main program. * @param None * @retval None */ int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (KEIL_startup_hk32f030m.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_hk32f030m.c file */ /* GPIOD Periph clock enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOD, ENABLE); /* Configure PD01 and PD02 in output pushpull mode */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOD, &GPIO_InitStructure); while(1) { /* Set PD01 and PD02 */ GPIOD->BSRR = BSRR_VAL; /* Reset PD01 and PD02 */ GPIOD->BRR = BSRR_VAL; /* Set PD01 and PD02 */ GPIOD->BSRR = BSRR_VAL; /* Reset PD01 and PD02 */ GPIOD->BRR = BSRR_VAL; /* Set PD01 and PD02 */ GPIOD->BSRR = BSRR_VAL; /* Reset PD01 and PD02 */ GPIOD->BRR = BSRR_VAL; /* Set PD01 and PD02 */ GPIOD->BSRR = BSRR_VAL; /* Reset PD01 and PD02 */ GPIOD->BRR = BSRR_VAL; /* Set PD01 and PD02 */ GPIOD->BSRR = BSRR_VAL; /* Reset PD01 and PD02 */ GPIOD->BRR = BSRR_VAL; } } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif /** * @} */ /** * @} */
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
196
2465
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
