[MM32软件] 能帮忙分析一下这段程序吗?
 楼主| Jacquetry 发表于 2023-3-25 23:22 | 显示全部楼层 |阅读模式
照人家提供的代码来的,但是为啥播放不了音频啊?
static void I2S_Mode_Config(SPI_I2S_STANDARD_TypeDef usStandard, SPI_I2S_DATAFORMAT_TypeDef usWordLen, SPI_I2S_AUDIO_FREQ_TypeDef usAudioFreq, SPI_I2S_TRANS_MODE_TypeDef usMode)
    I2S_InitTypeDef I2S_InitStructure;
    if ((usMode == I2S_Mode_SlaveTx) && (usMode == I2S_Mode_SlaveRx)) {
        return;
    RCC_APB1PeriphClockCmd(RCC_APB1ENR_SPI3, ENABLE);
    SPI_DeInit(SPI3);
    if (usMode == I2S_Mode_MasterTx) {
        I2S_InitStructure.I2S_Mode = I2S_Mode_MasterTx;
        I2S_InitStructure.I2S_Standard = usStandard;
        I2S_InitStructure.I2S_DataFormat = usWordLen;
        I2S_InitStructure.I2S_MCLKOutput = I2S_MCLKOutput_Enable;
        I2S_InitStructure.I2S_AudioFreq = usAudioFreq;
        I2S_InitStructure.I2S_CPOL = I2S_CPOL_Low;
        I2S_Init(SPI3, &I2S_InitStructure);
    else if (usMode == I2S_Mode_MasterRx) {
        I2S_InitStructure.I2S_Mode = I2S_Mode_MasterRx;
    SPI_DMACmd(SPI3, ENABLE);
    I2S_Cmd(SPI3, ENABLE);
快速回复 返回顶部 返回列表
