哪位大神能帮我看看程序吗?
/* Files to Include */
/* Device header file */
#if defined(__XC16__)
#include <xc.h>
#elif defined(__C30__)
#if defined(__PIC24E__)
#include <p24Exxxx.h>
#elif defined (__PIC24F__)||defined (__PIC24FK__)
#include <p24Fxxxx.h>
#elif defined(__PIC24H__)
#include <p24Hxxxx.h>
#endif
#endif
#include <stdint.h> /* Includes uint16_t definition */
#include <stdbool.h> /* Includes true/false definition */
#include "system.h" /* System funct/params, like osc/peripheral config */
#include "user.h" /* User funct/params, such as InitApp */
#include "libpic30.h" /* C30函数库 */
#include "common.h"
/* Global Variable Declaration */
#define ModPulseCtl PORTDbits.RD1
/* i.e. uint16_t <variable_name>; */
uint8_t ReceivedState = 0;
uint8_t ReceivedChar = 0;
uint8_t UartReceivedData[4] = {0,0,0,0} ;
uint16_t Int_Mask = 0; /* 中断标志 */
/* Main Program */
void __attribute__ ( (interrupt, no_auto_psv) ) _U1RXInterrupt( void )
IFS0bits.U1RXIF = 0;
switch ( ReceivedState )
case 0:
ReceivedChar = U1RXREG;
if( ReceivedChar == 0x55 ) ReceivedState = 1;
else ReceivedState = 0;
break;
case 1:
if( ReceivedChar == 0xAA ) ReceivedState = 2;
break;
case 2:
UartReceivedData[0] = U1RXREG;
ReceivedState = 3;
break;
case 3:
UartReceivedData[1] = U1RXREG;
ReceivedState = 4;
break;
case 4:
UartReceivedData[2] = U1RXREG;
ReceivedState = 5;
break;
case 5:
UartReceivedData[3] = U1RXREG;
ReceivedState = 6;
break;
case 6:
if( ReceivedChar == 0x5A ) ReceivedState = 7;
break;
case 7:
if( ReceivedChar == 0xA5 )
ReceivedState = 0;
Int_Mask = 1;
break;
/*此段关于串口的程序在网络传输时不需要*/
void __attribute__ ( (interrupt, no_auto_psv) ) _U1TXInterrupt( void )
IFS0bits.U1TXIF = 0;
void __attribute__((interrupt, auto_psv)) _DMA0Interrupt(void)
_DMA0IF = 0; /* Clear DMA interrupt flag to prepare for next block */
int16_t main(void)
/* Configure the oscillator for the device */
ConfigureOscillator();
/* Initialize IO ports and peripherals */
Port_Inint();
InitApp();
Interrupt_Init();
/* TODO <INSERT USER APPLICATION CODE HERE> */
while(1)
if( UartReceivedData[1] == 0x01 )
{ ModPulseCtl = 1;
U1TXREG = 0x23; }
else
ModPulseCtl = 0;
void InitApp(void)
Uart_Init();
void Uart_Init(void)
U1MODEbits.STSEL = 0; // 1-Stop bit
U1MODEbits.PDSEL = 0; // No Parity, 8-Data bits
U1MODEbits.ABAUD = 0; // Auto-Baud disabled
U1MODEbits.BRGH = 0; // Low-Speed mode
U1MODEbits.UEN = 0;
U1BRG = 20; // Baud Rate setting for 115200
U1STAbits.URXISEL0 = 0; //Bits6,7 Int. on character recieved
U1STAbits.URXISEL1 = 0; //Bits6,7 Int. on character recieved
U1STAbits.UTXISEL0 = 0;
U1STAbits.UTXISEL1 = 0;
RPOR5bits.RP84R = 1; //TXs
RPINR18bits.U1RXR = 83; //RX
U1MODEbits.UARTEN = 1; // And turn the peripheral on
U1STAbits.UTXEN = 1;
