[AT32F403/403A] AT32F403A ADC抢占同时模式有没有例程?
 楼主| hans00911 发表于 2023-5-24 14:04 | 显示全部楼层 |阅读模式
AT32F403A ADC  抢占同时模式ADC1  ADC2 同时单通道采亲有没有例程?用于FOC电机控制,还有两种普通通道可以用ADC3做普通采样就行,现在就是没找到 ADC1  ADC2 抢占同时模式的例程,普通模式倒是有,找到了
hoop 发表于 2023-5-24 17:46 | 显示全部楼层
  1. static void adc_config(void)
  3.   adc_base_config_type adc_base_struct;
  4.   crm_periph_clock_enable(CRM_ADC1_PERIPH_CLOCK, TRUE);
  5.   crm_periph_clock_enable(CRM_ADC2_PERIPH_CLOCK, TRUE);
  6.   crm_adc_clock_div_set(CRM_ADC_DIV_6);
  7.   nvic_irq_enable(ADC1_2_IRQn, 0, 0);
  8.   /* select combine mode */
  9.   adc_combine_mode_select(ADC_PREEMPT_SMLT_ONLY_MODE);
  10.   adc_base_default_para_init(&adc_base_struct);
  11.   adc_base_struct.sequence_mode = TRUE;
  12.   adc_base_struct.repeat_mode = FALSE;
  13.   adc_base_struct.data_align = ADC_RIGHT_ALIGNMENT;
  14.   adc_base_struct.ordinary_channel_length = 1;
  15.   adc_base_config(ADC1, &adc_base_struct);
  16.
  17.   adc_preempt_channel_length_set(ADC1, 1);
  18.   adc_preempt_channel_set(ADC1, ADC_CHANNEL_7, 1, ADC_SAMPLETIME_239_5);
  19.   adc_preempt_conversion_trigger_set(ADC1, ADC12_PREEMPT_TRIG_TMR1TRGOUT, TRUE);
  20.   adc_interrupt_enable(ADC1, ADC_PCCE_INT, TRUE);
  21.   adc_base_config(ADC2, &adc_base_struct);
  22.   adc_preempt_channel_length_set(ADC2, 1);
  23.   adc_preempt_channel_set(ADC2, ADC_CHANNEL_3, 1, ADC_SAMPLETIME_239_5);
  24.   adc_preempt_conversion_trigger_set(ADC2, ADC12_PREEMPT_TRIG_SOFTWARE, TRUE);
  25.   adc_interrupt_enable(ADC2, ADC_PCCE_INT, TRUE);
  26.   adc_enable(ADC1, TRUE);
  27.   adc_enable(ADC2, TRUE);
  28.   adc_calibration_init(ADC1);
  29.   while(adc_calibration_init_status_get(ADC1));
  30.   adc_calibration_start(ADC1);
  31.   while(adc_calibration_status_get(ADC1));
  32.   adc_calibration_init(ADC2);
  33.   while(adc_calibration_init_status_get(ADC2));
  34.   adc_calibration_start(ADC2);
  35.   while(adc_calibration_status_get(ADC2));
  36. }
  37. void ADC1_2_IRQHandler(void)
  38. {
  39.   if(adc_flag_get(ADC1, ADC_PCCE_FLAG) != RESET)
  40.   {
  41.     adc_flag_clear(ADC1, ADC_PCCE_FLAG);
  42.     adc1_preempt_valuetab = adc_preempt_conversion_data_get(ADC1, ADC_PREEMPT_CHANNEL_1);
  43.   }
  44.   if(adc_flag_get(ADC2, ADC_PCCE_FLAG) != RESET)
  45.   {
  46.     adc_flag_clear(ADC2, ADC_PCCE_FLAG);
  47.     adc1_preempt_valuetab = adc_preempt_conversion_data_get(ADC2, ADC_PREEMPT_CHANNEL_1);
  48.   }
  49. }
 楼主| hans00911 发表于 2023-5-24 19:01 | 显示全部楼层
 楼主| hans00911 发表于 2023-5-24 20:18 | 显示全部楼层
如果是同时模式的话,ADC1完成转换,中断里只潘判读ADC的完成标志,不判断ADC2的中断断标志接读ADC2的转换值应该也是完成了吧
hoop 发表于 2023-5-25 09:04 | 显示全部楼层
理论上也是可以的,不过按照前面的写法是最完美的,容错能力强
 楼主| hans00911 发表于 2023-5-25 09:46 | 显示全部楼层
好的,谢谢
快速回复 返回顶部 返回列表
