[PIC®/AVR®/dsPIC®产品] pic单片机警报声源程序
476|1
 楼主| lzmm 发表于 2023-5-26 09:00 | 显示全部楼层 |阅读模式
1脚为电源端接5V电源,8脚接地, 4脚为控制端,暂不用.2,6,7脚为警音
        控制端,按下S1、S2、S3可发出不同的警音
       5脚为音频输出端,当停止音频输出时,该脚置低;
电路原理图如下:
  1. #include<p12f629.inc>       ;
  2. #include <pic12f629.inc>
  3.     __config 0x3F4C ;_CPC_ON & _CPU_ON & _CPP_ON & _PWRTE_OFF & _WDT_ON & _FOSC_HS ; 0x3F4C
  4. ; RAM-Variable
  5. CSR1         equ 0x20
  6. CSR2        equ 0x21
  7. STATUS_TEMP equ 0x2C
  8. PCL_TEMP equ 0x2D
  9. DE_TIME1 equ 0x22
  10. DE_TIME0 equ 0x23
  11. DE_TIME2 equ 0x24
  12. DE_TIME3 equ 0x25
  13. TIME_TMP0 equ 0x26
  14. TIME_TMP1 equ 0x27
  15. SOUND_D_TIME0 equ 0x28
  16. SOUND_D_TIME1 equ 0x29
  17. DE_TMEP0 equ 0x2A
  18. DE_TMEP1 equ 0x2B
  19. CON_SOUND equ 0x55
  20. SOUND_B_TIME0 equ 0x56
  21. SOUND_B_TIME1 equ 0x57
  22. SOUND_D_TIME2 equ 0x58
  23. CON_A_STAY equ 0x59
  24. TR0_TIME equ 0x5A
  25. SOUND_C_TIME1 equ 0x5B
  26. SOUND_D_TIME3 equ 0x5C
  27. SOUND_C_TIME0 equ 0x5D
  28. W_TEMP equ 0x5E
  29. ; Program
  30.     Org 0x0000
  31. ;   Reset-Vector
  32.     GOTO MAIN
  33.     Org 0x0004
  34. ;   Interrupt-Vector
  35.     MOVWF W_TEMP
  36.     SWAPF STATUS,W
  37.     BCF STATUS,RP0
  38.     MOVWF STATUS_TEMP
  39.     MOVF PCLATH,W
  40.     MOVWF PCL_TEMP
  41.     GOTO Interrupt_0
  42. Interrupt_0
  43.     BTFSC INTCON,T0IF
  44.     BTFSS INTCON,T0IE
  45.     GOTO Interrupt_exit
  46.     MOVF TR0_TIME,W
  47.     ADDWF TMR0,F
  48.     MOVLW 0x04
  49.     BCF INTCON,T0IF
  50.     BSF CON_SOUND,2
  51.         XORWF GPIO,F
  52.     CLRWDT
  53. Interrupt_exit
  54.     MOVF PCL_TEMP,W
  55.     MOVWF PCLATH
  56.     SWAPF STATUS_TEMP,W
  57.     MOVWF STATUS
  58.     SWAPF W_TEMP,F
  59.     SWAPF W_TEMP,W
  60.     RETFIE
  61. ;*****************************************
  62. RAM_00
  63.     MOVLW 0x49
  64.     MOVWF CSR1
  65.     MOVLW 0x21
  66.     MOVWF CSR2
  67. MAIN_RAM
  68.     INCF CSR2,F
  69.     MOVF CSR2,W
  70.     MOVWF FSR
  71.     CLRF INDF
  72.     DECFSZ CSR1,F
  73.     GOTO MAIN_RAM
  74.     CLRF CSR2
  75.     RETURN
  76. MAIN
  77.     CALL RAM_00
  78.     BSF STATUS,RP0
  79.     ;CALL LADR_0x03FF
  80.     ;MOVWF SFR_0x10
  81.     CLRF STATUS
  82.     MOVLW 0xA7
  83.     CLRF SOUND_B_TIME0
  84.     CLRF SOUND_B_TIME1
  85.     CLRF SOUND_D_TIME2
  86.     CLRF CON_A_STAY
  87.     CLRF TR0_TIME
  88.     CLRF SOUND_C_TIME1
  89.     MOVWF SOUND_D_TIME3
  90.     MOVLW 0xFE
  91.     MOVWF SOUND_C_TIME0
  92.     CLRF STATUS
  93.     MOVLW 0x58
  94.     MOVWF TIME_TMP0
  95.     MOVLW 0x02
  96.     MOVWF TIME_TMP1
  97.     ;CALL DELAY_0
  98.     MOVLW 0x07
  99.     MOVWF CMCON ;SFR_0x19       ; !!Warning: SFR_0x19 is Unimplemented
  100.     MOVLW 0x81
  101.     BSF STATUS,RP0
  102.     MOVWF TMR0
  103.     MOVLW 0x3B  ;0x3B
  104.     MOVWF GPIO  ;PORTA
  105.     BCF STATUS,RP0
  106.     CLRF GPIO  ;PORTA
  107.     BSF INTCON,GIE
  108.     CLRF GPIO   ;PORTA
  109.     GOTO SEARCH_KEY
  110. WHILE_0
  111.     BTFSS CON_SOUND,5
  112.     GOTO WHILE_1
  113.     BCF CON_SOUND,0
  114.     CALL LADR_0x0154
  115. SEARCH_KEY
  116.     CLRWDT
  117.     BCF STATUS,RP0
  118.     BTFSC GPIO  ,4        ;BTFSC GPIO  ,4   ;PORTA,4
  119.     GOTO SOUND_A_0
  120.     BTFSC   GPIO,5
  121.     GOTO SOUND_B_0
  122.     BTFSC GPIO,0   ;PORTA,0
  123.     GOTO SOUND_C_0
  124.     BTFSC GPIO,1  ;  PORTA,1
  125.     GOTO SOUND_D_0
  126.     BTFSS GPIO   ,1   ;PORTA,1
  127.     GOTO WHILE_0
  128.
  129. WHILE_1
  130.     CLRF GPIO   ;PORTA
  131.     MOVLW 0xA7
  132.     BCF INTCON,T0IE
  133.     BCF CON_SOUND,5
  134.     BCF CON_SOUND,0
  135.     MOVWF SOUND_D_TIME3
  136.     BCF GPIO,2   ;   PORTA,2
  137.     GOTO SEARCH_KEY
  138. ;********************************
  139. SOUND_A_0
  140.     BTFSC CON_SOUND,0
  141.     GOTO SOUND_A_1
  142.     BSF INTCON,T0IE
  143.     BSF CON_SOUND,0
  144.     BCF CON_SOUND,5
  145. SOUND_A_1
  146.     CALL SOUND_A_2
  147.     GOTO SEARCH_KEY
  148. SOUND_A_2
  149.     BSF STATUS,RP0
  150.     MOVF TMR0,W
  151.     XORLW 0x81
  152.     BTFSC STATUS,Z
  153.     GOTO SOUND_A_3
  154.     MOVLW 0x81
  155.     MOVWF TMR0
  156. SOUND_A_3
  157.     BCF STATUS,RP0
  158.     BTFSS CON_SOUND,2
  159.     RETURN
  160.     BCF CON_SOUND,2
  161.     INCFSZ CON_A_STAY,F
  162.     GOTO SOUND_A_5
  163. SOUND_A_EXIT
  164.     MOVLW 0x3B
  165.     MOVWF TR0_TIME
  166.     RETURN
  167. SOUND_A_5
  168.     MOVLW 0x02
  169.     SUBWF CON_A_STAY,W
  170.     BTFSC STATUS,C
  171.     GOTO SOUND_A_6
  172. SOUND_A_51
  173.     MOVLW 0x76
  174.     MOVWF TR0_TIME
  175.     RETURN
  176. SOUND_A_6
  177.     MOVLW 0x03
  178.     SUBWF CON_A_STAY,W
  179.     BTFSC STATUS,C
  180.     GOTO SOUND_A_7
  181. SOUND_A_61
  182.     MOVLW 0x8F
  183.     MOVWF TR0_TIME
  184.     RETURN
  185. SOUND_A_7
  186.     MOVLW 0x04
  187.     SUBWF CON_A_STAY,W
  188.     BTFSC STATUS,C
  189.     GOTO SOUND_A_8
  190. SOUND_A_71
  191.     MOVLW 0x94
  192.     MOVWF TR0_TIME
  193.     RETURN
  194. SOUND_A_8
  195.     MOVLW 0x05
  196.     SUBWF CON_A_STAY,W
  197.     BTFSC STATUS,C
  198.     GOTO SOUND_A_9
  199. SOUND_A_81
  200.     MOVLW 0xA3
  201.     MOVWF TR0_TIME
  202.     RETURN
  203. SOUND_A_9
  204.     MOVLW 0x06
  205.     SUBWF CON_A_STAY,W
  206.     BTFSS STATUS,C
  207.     GOTO SOUND_A_81
  208.     MOVLW 0x07
  209.     SUBWF CON_A_STAY,W
  210.     BTFSS STATUS,C
  211.     GOTO SOUND_A_71
  212.     MOVLW 0x08
  213.     SUBWF CON_A_STAY,W
  214.     BTFSS STATUS,C
  215.     GOTO SOUND_A_61
  216.     MOVLW 0x09
  217.     SUBWF CON_A_STAY,W
  218.     BTFSS STATUS,C
  219.     GOTO SOUND_A_51
  220.     CLRF CON_A_STAY
  221.     GOTO SOUND_A_EXIT
  222. ;********************************
  223. SOUND_B_0
  224.     BTFSC CON_SOUND,0
  225.     GOTO SOUND_B_1
  226.     BSF INTCON,T0IE
  227.     BSF CON_SOUND,0
  228.     BCF CON_SOUND,5
  229.     CLRF SOUND_B_TIME0
  230.     CLRF SOUND_B_TIME1
  231. SOUND_B_1
  232.     CALL SOUND_B_2
  233.     GOTO SEARCH_KEY
  234. SOUND_B_2
  235.     BSF STATUS,RP0
  236.     MOVF TMR0,W
  237.     XORLW 0x81
  238.     BTFSC STATUS,Z
  239.     GOTO SOUND_B_3
  240.     MOVLW 0x81
  241.     MOVWF TMR0
  242. SOUND_B_3
  243.     BCF STATUS,RP0
  244.     BTFSS CON_SOUND,1
  245.     GOTO SOUND_B_5
  246.     MOVLW 0x66
  247.     MOVWF TR0_TIME
  248.     BTFSS CON_SOUND,2
  249.     RETURN
  250.     BCF CON_SOUND,2
  251.     INCF SOUND_B_TIME0,F
  252.     BTFSC STATUS,Z
  253.     INCF SOUND_B_TIME1,F
  254.     DECF SOUND_B_TIME1,W
  255.     MOVLW 0x90
  256. SOUND_B_4
  257.     BTFSC STATUS,Z
  258.     XORWF SOUND_B_TIME0,W
  259.     BTFSS STATUS,Z
  260.     RETURN
  261.     MOVLW 0x02
  262.     CLRF SOUND_B_TIME0
  263.     CLRF SOUND_B_TIME1
  264.         XORWF CON_SOUND,F
  265.     RETURN
  266. SOUND_B_5
  267.     MOVLW 0x85
pzsh 发表于 2023-9-18 20:22 | 显示全部楼层
汇编语言,厉害
