lattice的ipexpress异常,解决办法
1488|0
 楼主| lichenllin 发表于 2023-6-5 11:00 | 显示全部楼层 |阅读模式
最近ip服务器可能会遇到问题,建议客户把更新检查关掉。我们有对应的IP下载链接。
   https://www.latticesemi.com/ispupdate/ipexpress/
   https://radiantip.latticesemi.com/IP_Repository/
或者按下面操作
    The patch modifies the URLs in the .ini file.
    Customers could do this themselves by following this by doing the following:
    • Update the existing lvnetset.ini from the following locations:
    a. On Windows: <diamond_install_location>/data/lvnetset.ini
    b. On Linux: <diamond_install_location>/data/lvnetset.ini
    • Replace the contents of lvnetset.ini with the below text:
    IP_Server_Url  = https://ipupdate.latticesemi.com/ipexpress/
    Web_Url         = https://www.latticesemi.com
    Server_Url       = https://diamondupdate.latticesemi.com/
    Active_Url       = https://www.latticesemi.com/activesupport/cflistener.cfm
    Upload_Url     = https://diamonderror.latticesemi.com
  如有问题以及资料更新 ,请联系 www.szfpga.com
