[实用程序源码及工具软件] 基于华芯微特SWM181CB的IO模拟SPI接口的AD8370的PGA模块驱动代码-缥缈九哥验测
865|3
 楼主| 缥缈九哥 发表于 2023-9-20 18:47 | 显示全部楼层 |阅读模式
/* @file        ad8370.c        */
/* @version        V1.00        */
/* $author:        yuanxihua@21cn.com        */
/* $Date:         2023/09/09 02:54 $        */
/* @brief         SWM181CBT6 Series AD8370 Driver Sample Code                                                */
/* @note        */
/* Copyright (C) 2010-2023 PM9GZY Technology Corp. All rights reserved.                        */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
________________________________________________
|        SWM181CBT6                                                AD8370                |
|        PB5 PC2 PD1 PC5                ---->                DATA                |
|        PB6 PC3 PD2 PC6                ---->                CLCK                |
|        PB7 PC4 PD3 PC7                ---->                LTCH                |
|_______________________________________________|
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
typedef struct {GPIO_TypeDef *port;uint32_t pin;}pin_t;
pin_t data[4]={{GPIOB, PIN5},{GPIOC, PIN2},{GPIOD, PIN1},{GPIOC, PIN5}};
pin_t clck[4]={{GPIOB, PIN6},{GPIOC, PIN3},{GPIOD, PIN2},{GPIOC, PIN6}};
pin_t ltch[4]={{GPIOB, PIN7},{GPIOC, PIN4},{GPIOD, PIN3},{GPIOC, PIN7}};
#define AD8730_delay                2
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void AD8370_Set_value(uint8_t chn,uint8_t pga)
    if(chn>3){return;}
//        printf("\n\rDATA:PORT=%x PIN=%x ",(int)data[chn].port,(int)data[chn].pin);
//        printf("\n\rCLCK:PORT=%x PIN=%x ",(int)clck[chn].port,(int)clck[chn].pin);
//        printf("\n\rLTCH:PORT=%x PIN=%x ",(int)ltch[chn].port,(int)ltch[chn].pin);
        GPIO_ClrBit(clck[chn].port, clck[chn].pin);// CLCK = LOW
        GPIO_SetBit(ltch[chn].port, ltch[chn].pin);// LTCH = HIGH
        GPIO_ClrBit(data[chn].port, data[chn].pin);// DATA = LOW
        delay_ms(1);
        GPIO_ClrBit(ltch[chn].port, ltch[chn].pin);// LTCH = LOW
        delay_us(AD8730_delay);
        for(int i=0;i<8;i++)
                if(pga&0x80){GPIO_SetBit(data[chn].port, data[chn].pin);}// DATA = HIGH
                else                {GPIO_ClrBit(data[chn].port, data[chn].pin);}// DATA = LOW
                GPIO_SetBit(clck[chn].port, clck[chn].pin);        // CLCK = HIGH
                GPIO_ClrBit(clck[chn].port, clck[chn].pin);        // CLCK = LOW
                pga<<=1;
//代码完毕
 楼主| 缥缈九哥 发表于 2023-9-20 18:48 | 显示全部楼层
最近项目用到
hotpower 发表于 2023-9-20 21:05 | 显示全部楼层
很不错,顶一个
Prry 发表于 2023-9-20 23:25 | 显示全部楼层
可以用硬件spi驱动,高效节约cpu资源
个人签名:童时不懂世事艰,笑谈学成锦衣还。岁月无声已先过,男儿有泪空自弹。    莫待沾霜愁上发,须嬴吐气喜开颜。拼搏半年誓如愿,不到长城心不甘。
67
