[技术问答] 请教HC32F002 LPUART_Transmit库函数使用 报告警
 楼主| volbin0042 发表于 2023-12-7 17:36 | 显示全部楼层 |阅读模式
2维无法宣告常数型态  报告警
如何处理 (删const 可正常)
指针型态宣告 观念模糊
//P1
const uint8_t P1_num[3][13]={
{12,0x70,0x31,0x2E,0x70,0x69,0x63,0x3D,0x31,0x31,0xff,0xff,0xff},  //'**=1
{12,0x70,0x31,0x2E,0x70,0x69,0x63,0x3D,0x31,0x32,0xff,0xff,0xff},  //'up=12
{12,0x70,0x31,0x2E,0x70,0x69,0x63,0x3D,0x33,0x32,0xff,0xff,0xff}   //'dn=32
void App_P1_num(uint8_t X1)
        LPUART_Transmit(LPUART1, P1_num[X1], P1_num[X1][0], 0xFFFFFF);
en_result_t LPUART_Transmit(LPUART_TypeDef* LPUARTx, uint8_t *pu8Data, uint32_t u32Size, uint32_t u32Timeout)
                pu8Data++;
    while(u32Size)
        while(!REG_READBITS(LPUARTx->ISR, LPUART_ISR_TXE)){;}
        REG_WRITE(LPUARTx->DR, *pu8Data);
        pu8Data++;
        u32Size--;
    while(!REG_READBITS(LPUARTx->ISR, LPUART_ISR_TC)){;}
    REG_CLEARBITS(LPUARTx->ICR, LPUART_ICR_TC);
    return Ok;
wubangmi 发表于 2023-12-7 17:55 | 显示全部楼层
  LPUART_Transmit(LPUART1, (uint8_t *)&P1_num[X1], P1_num[X1][0], 0xFFFFFF);
 楼主| volbin0042 发表于 2023-12-8 13:23 | 显示全部楼层
  LPUART_Transmit(LPUART1, (uint8_t *)&P1_num[X1], P1_n ...
感谢回复!
祝平安顺心!
chenjun89 发表于 2023-12-8 19:42 来自手机 | 显示全部楼层
数据类型定义问题
快速回复 返回顶部 返回列表
