[方案相关] 小华HC32F448驱动硬件I2C
1584|8
 楼主| t60yz 发表于 2024-2-28 19:31 | 显示全部楼层 |阅读模式
数据手册中说明了 i2c 2 的配置功能号是SDA为50,SCL为51,如果是I2C1 就是48 和49,对应时钟是FG1
全局宏定义:
//全局宏定义
/* Define port and pin for SDA and SCL */
#define I2C_SDA_PORT        (GPIO_PORT_D)//类似HAL库的配置
#define I2C_SDA_PIN         (GPIO_PIN_00)
#define I2C_SCL_PORT        (GPIO_PORT_D)
#define I2C_SCL_PIN         (GPIO_PIN_01)
#define I2C_SDA_FUNC        (GPIO_FUNC_50)        //pin脚功能配置号
#define I2C_SCL_FUNC        (GPIO_FUNC_51)        //详情见数据手册引脚配置页
/* I2C unit define */
#define I2C_UNIT            (CM_I2C2)                                                //硬件I2C地址
#define I2C_FCG             (FCG1_PERIPH_I2C2)        //开启时钟
* @defgroup I2C_Configuration BSP I2C Configuration
#define I2C_BAUDRATE      (400000UL) //I2C波特率配置
#define I2C_TIMEOUT       (0x64U)                 //
硬件I2C 的GPIO口配置
* @brief   I2C_Init0 配置gpio口功能,主要是功能号I2C_SCL_FUNC和SDA_FUNC,要按照数据手册写
* @param
* @retval LL_OK
static void I2C_GPIO_Init(void)
    stc_gpio_init_t stcGpioInit;
    /* Configuration I2C GPIO */
    (void)GPIO_StructInit(&stcGpioInit);
    (void)GPIO_Init(I2C_SCL_PORT, I2C_SCL_PIN, &stcGpioInit);//初始化gpio
    (void)GPIO_Init(I2C_SDA_PORT, I2C_SDA_PIN, &stcGpioInit);
    GPIO_SetFunc(I2C_SCL_PORT, I2C_SCL_PIN, I2C_SCL_FUNC);//配置功能为SCL
    GPIO_SetFunc(I2C_SDA_PORT, I2C_SDA_PIN, I2C_SDA_FUNC);//SDA
    /* Enable I2C Peripheral*/
                FCG_Fcg1PeriphClockCmd(I2C_FCG, ENABLE);//开启外设时钟
    (void)I2C_Init(I2C_UNIT);//I2C初始化函数
I2C 初始化函数:
* @brief  I2C_Init1 配置i2c的波特率,边沿时长,分频系数,总线命令
* @param  CM_I2C_TypeDef *I2Cx:I2C1 or I2C2 ,you only need to write a i2c base dar directly
* @retval LL_OK
int32_t I2C_2_Init(CM_I2C_TypeDef *I2Cx)
    int32_t i32Ret;
    float32_t fErr;
    stc_i2c_init_t stcI2cInit;
    I2C_DeInit(I2Cx);
    (void)I2C_StructInit(&stcI2cInit);
    stcI2cInit.u32Baudrate = I2C_BAUDRATE;
    stcI2cInit.u32SclTime  = 0U;
    stcI2cInit.u32ClockDiv = I2C_CLK_DIV2;
    i32Ret = I2C_Init(I2Cx, &stcI2cInit, &fErr);
    if (LL_OK == i32Ret) {
        I2C_BusWaitCmd(I2Cx, ENABLE);
    I2C_Cmd(I2Cx, ENABLE);
    return i32Ret;
 楼主| t60yz 发表于 2024-2-28 19:32 | 显示全部楼层
I2C写字节函数和 传输cmd、传输data函数,还有初始化函数
#include "oledfont.h"
#include "oled.h"
#include "hc32_ll_i2c.h"//很重要的头文件,I2C_trans等函数的来源
#define OLED_ADD                                         (0x3c)                 //写入OLED初始地址
#define DATA_Len                                         (0x02)                 //写入数据长度
#define I2C_DIR_TX2        (0x00)                 //写入标志
  * @brief  OLED_WR_Byte 写入一字节/两字节
        * @param  *dat
  * @retval 返回 LL_OK
        *用法举例:OLED_WR_Byte(buf),buf定义:可定义为数组,如 int8_t buf[2];
int32_t OLED_WR_Byte(uint8_t *dat)
        int32_t i32Ret;
        I2C_SWResetCmd(I2C_UNIT,ENABLE);//I2C复位
        I2C_SWResetCmd(I2C_UNIT,DISABLE);
        i32Ret = I2C_Start(I2C_UNIT, I2C_TIMEOUT);//启动I2C
        if(LL_OK==i32Ret)
                //写入基地址
                i32Ret=I2C_TransAddr(I2C_UNIT,(uint8_t)OLED_ADD,I2C_DIR_TX2,I2C_TIMEOUT );
                if(LL_OK==i32Ret)
                        //写入指令数据,这里DATA_Len=2,一次性传输 *dat 两个数据过去,第一个数据是固定寄存器地址,一
            //个是实时指令
                        i32Ret=I2C_TransData(I2C_UNIT,dat,DATA_Len ,I2C_TIMEOUT );
                        //如果把寄存器地址和数据指令两个字节分开传输,就解出这几行注释,上面先传寄存器地址,下面这几行传
            //数据
//                        if(LL_OK==i32Ret)
//                                i32Ret=I2C_TransData(I2C_UNIT,dat,DATA_Len ,I2C_TIMEOUT );
//                if(LL_OK != i32Ret)
//                        (void)I2C_Stop(BSP_TCA9539_I2C_UNIT,100);
//                        I2C_SWResetCmd(BSP_TCA9539_I2C_UNIT,ENABLE);
//                        I2C_SWResetCmd(BSP_TCA9539_I2C_UNIT,DISABLE);
                (void)I2C_Stop(I2C_UNIT,I2C_TIMEOUT );
                return i32Ret;
  * @brief  oled_cmd 写入oled指令
        * @param  i2c_cmd,一个8位无符号整数
  * @retval void
static void oled_cmd(uint8_t i2c_cmd)
        uint8_t u8TXBuf[2];
        u8TXBuf[0]=0x00;
        u8TXBuf[1]=i2c_cmd;
        OLED_WR_Byte(u8TXBuf);
//        uint8_t *cmd;
//        uint8_t adr1;
//        uint8_t *adr;
//        adr1=0x00;
//        adr=&adr1;
//        cmd=&i2c_cmd;
//         BSP_I2C_Write(BSP_TCA9539_I2C_UNIT, OLED_ADD, adr,1,cmd, 1);
  * @brief  oled_data�
  * @param  i2c_data 传数据
  * @retval
static void oled_data(uint8_t i2c_data)
                uint8_t u8TXBuf[2];
                u8TXBuf[0]=0x40;
                u8TXBuf[1]=i2c_data;
//                uint8_t *dat;
//                uint8_t adr1;
//                uint8_t *adr;
//                adr1=0x40;
//                adr=&adr1;
//                dat=&i2c_data;
//         BSP_I2C_Write(BSP_TCA9539_I2C_UNIT, OLED_ADD,adr ,1,dat, 1);
  * @brief  oled_init 初始化oled
  * @param
  * @retval
void oled_init(void)
  DDL_DelayMS(800);
        oled_cmd(0xAE); //display off
        oled_cmd(0x20);        //Set Memory Addressing Mode
        oled_cmd(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        oled_cmd(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        oled_cmd(0xc8);        //Set COM Output Scan Direction
        oled_cmd(0x00); //---set low column address
        oled_cmd(0x10); //---set high column address
        oled_cmd(0x40); //--set start line address
        oled_cmd(0x81); //--set contrast control register
        oled_cmd(0xff); // 0x00~0xff
        oled_cmd(0xa1); //--set segment re-map 0 to 127
        oled_cmd(0xa6); //--set normal display
        oled_cmd(0xa8); //--set multiplex ratio(1 to 64)
        oled_cmd(0x3F); //
        oled_cmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        oled_cmd(0xd3); //-set display offset
        oled_cmd(0x00); //-not offset
        oled_cmd(0xd5); //--set display clock divide ratio/oscillator frequency
        oled_cmd(0xf0); //--set divide ratio
        oled_cmd(0xd9); //--set pre-charge period
        oled_cmd(0x22); //
        oled_cmd(0xda); //--set com pins hardware configuration
        oled_cmd(0x12);
        oled_cmd(0xdb); //--set vcomh
        oled_cmd(0x20); //0x20,0.77xVcc
        oled_cmd(0x8d); //--set DC-DC enable
        oled_cmd(0x14); //
        oled_cmd(0xaf); //--turn on oled panel
main函数
* @brief  Main function
* @param  None
int32_t main(void)
    /* Unlock peripherals or registers */
    LL_PERIPH_WE(LL_PERIPH_ALL);
    /* Initialize BSP system clock. */
//    BSP_CLK_Init();不要取消这行注释,时钟冲突了
    /* Initialize BSP expand IO. */
    BSP_IO_Init();//也把SDA和SCL初始化成功了
    /* Initialize BSP LED. */
    BSP_LED_Init();
                /* Initialize DDL_Printf */
                DDL_PrintfInit(BSP_PRINTF_DEVICE, BSP_PRINTF_BAUDRATE, BSP_PRINTF_Preinit);
                /* Initialize I2C2 */
                I2C_GPIO_Init();
                LED_Init();
                oled_init();
    /* Peripheral registers write protected */
    LL_PERIPH_WP(LL_PERIPH_ALL);
                        oled_cls();
                        DDL_DelayMS(200);
    for (;;) {
                        //oled_cls();
                        //显示一个汉字标题,如果没有oledfont中没有title数组,就换显示个字符串或数组的函数
                        show_title();
      //DDL_DelayMS(50UL);
//                        LED_G_TOGGLE();
//                        BSP_LED_Toggle(LED_YELLOW);
//                        DDL_Printf("advance\n");
把文件的全部内容放下面:
        1.oled.h
//本程序只供学习使用,未经作者许可,不得用于其它任何用途
//  文 件 名   :
//  版 本 号   :
//  作    者   : huang jin
//  生成日期   : 2014/3/16
//  最近修改   : 2023/8/25
//  功能描述   : 0.96寸OLED 接口演示例程(HC32F448系列硬件IIC)
//              说明:
//              GND   电源地
//              VCC   接5V或3.3v电源
//              SCL   接PD1(SCL)
//              SDA   接PD0(SDA)
//Copyright(C) 中景园电子2014/3/16
//All rights reserved
#ifndef __OLED_H
#define __OLED_H
#include "stdlib.h"
#include "hc32_ll.h"
#include "ev_hc32f448_lqfp80_bsp.h"
#define OLED_MODE 0
#define SIZE 8
#define XLevelL                0x00
#define XLevelH                0x10
#define Max_Column        128
#define Max_Row                64
#define        Brightness        0xFF
#define X_WIDTH         128
#define Y_WIDTH         64
//-----------------OLED IIC端口定义----------------
#define OLED_CMD  0        //写命令
#define OLED_DATA 1        //写数据
//OLED控制用函数
int32_t OLED_WR_Byte(uint8_t *dat);//I2C传输字节函数
void oled_init(void);//初始化
void oled_display_char(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size);
void oled_show_string(uint8_t x, uint8_t y, char ch[], uint8_t TextSize);//显示字符串,TextSize是尺寸大小
void oled_showCN(unsigned char x, unsigned char y, unsigned char CN[],unsigned char N); //显示汉字
void oled_drawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[]);        //画图
void oled_showNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size1); //显示数字
void oled_full(uint8_t data);
void oled_cls(void);  //清屏
void oled_on(void);   //开启
void oled_off(void);        //关闭
void show_title(void);//显示一个固定标题
#endif
.oled.c
//  文 件 名   :
//  版 本 号   :
//  作    者   : huang jin
//  生成日期   : 2014/3/16
//  最近修改   : 2023/8/25
//              说明:
//              GND   电源地
//              VCC   接5V或3.3v电源
//              SCL   接PD1(SCL)
//              SDA   接PD0(SDA)
#include "oled.h"
        * @param  *dat
  * @retval 返回 LL_OK
        int32_t i32Ret;
        if(LL_OK==i32Ret)
                //写入基地址
                if(LL_OK==i32Ret)
                        //写入指令数据,这里DATA_Len=2,一次性传输 *dat 两个数据过去,第一个数据是固定寄存器地址,一个是实时指令
                        //如果把寄存器地址和数据指令两个字节分开传输,就解出这几行注释,上面先传寄存器地址,下面这几行传数据
                return i32Ret;
  * @retval void
        uint8_t u8TXBuf[2];
        u8TXBuf[0]=0x00;
        u8TXBuf[1]=i2c_cmd;
//        uint8_t *cmd;
//        uint8_t adr1;
//        uint8_t *adr;
//        adr1=0x00;
//        adr=&adr1;
//        cmd=&i2c_cmd;
  * @brief  oled_data�
  * @retval
                uint8_t u8TXBuf[2];
                u8TXBuf[0]=0x40;
//                uint8_t *dat;
//                uint8_t adr1;
//                uint8_t *adr;
//                adr1=0x40;
//                adr=&adr1;
//                dat=&i2c_data;
  * @brief  oled_setPos 坐标设置函数
  * @param  x,y,
  * @retval
static void oled_setPos(uint8_t x, uint8_t y)
    oled_cmd(0xb0+y);
        oled_cmd(((x&0xf0)>>4)|0x10);
        oled_cmd((x&0x0f)|0x01);
  * @brief  oled_full 满屏填充数据
  * @param  data:      Ҫ��������
  * @retval ��
void oled_full(uint8_t data)//0xff
    uint8_t m,n;
        for(m=0;m<8;m++)
                oled_cmd(0xb0+m);                //page0-page1
                oled_cmd(0x00);                //low column start address
                oled_cmd(0x10);                //high column start address
                for(n=0;n<128;n++)
                                oled_data(data);
  * @brief  oled_cls 清屏
  * @param
        * @retval
void oled_cls(void)
        oled_full(0x00);
        * @brief  OLED_ON 开启oled显示
  * @param
        * @retval
void oled_on(void)
        oled_cmd(0X8D);  //SET DCDC命令
        oled_cmd(0X14);  //DCDC ON
        oled_cmd(0XAF);  //OLED DISPLAY ON
  * @brief  OLED_OFF 关闭oled
  * @param
        * @retval
void oled_off(void)
        oled_cmd(0X8D);  SET DCDC命令
        oled_cmd(0X10);  //DCDC ON
        oled_cmd(0XAE);  //OLED DISPLAY ON
  * @param
  * @retval
  DDL_DelayMS(800);
        oled_cmd(0x3F); //
        oled_cmd(0x22); //
        oled_cmd(0x12);
        oled_cmd(0x14); //
  * @brief  oled_display_char
  * @param  x,y : 坐标可填范围:x:0-127, y:0-7
*                                        chr:- 显示字符
        *                                        Char_Size : 字符大小(填16/8)
        * @retval ��
        unsigned char c=0,i=0;
                c=chr-' ';//�õ�ƫ�ƺ��ֵ
                if(x>128-1){x=0;y=y+2;}
                if(Char_Size == 16)
                        oled_setPos(x,y);
                        for(i=0;i<8;i++)
                        oled_data(F8X16[c*16+i]);
                        oled_setPos(x,y+1);
                        for(i=0;i<8;i++)
                        oled_data(F8X16[c*16+i+8]);
                else
                        oled_setPos(x,y);
                        for(i=0;i<6;i++)
                        oled_data(F6x8[c][i]);
        * @brief  oled_show_string 显示一串string
        *        ch[] : 字符串
        *        TextSize : you can write 1 or 2 (1和2代表的尺寸:1:6*8 ; 2:8*16)
        * @retval ��
    uint8_t c = 0,i = 0,j = 0;
        switch(TextSize)
                case 1:
                        while(ch[j] != '\0')
                                c = ch[j] - 32;
                                if(x > 126)
                                        x = 0;
                                        y++;
                                oled_setPos(x,y);
                                for(i=0;i<6;i++)
                                x += 6;
                                j++;
                }break;
                case 2:
                                c = ch[j] - 32;
                                if(x > 120)
                                        x = 0;
                                        y++;
                                oled_setPos(x,y);
                                for(i=0;i<8;i++)
                                oled_setPos(x,y+1);
                                for(i=0;i<8;i++)
                                x += 8;
                                j++;
                }break;
* @brief  oled_showCN  显示汉字
  * @param  x,y: (x:0~127, y:0~7);
        *                                        N:oledfont.h
        * @retval
        unsigned char wm=0;
        unsigned int  adder=32*N;
        oled_setPos(x , y);
        for(wm = 0;wm < 16;wm++)
                oled_data(CN[adder]);
                adder += 1;
        oled_setPos(x,y + 1);
                adder += 1;
  * @brief  oled_drawBMP
* @param  x0,y0 : 坐标上下限(x0:0~127, y0:0~7);
        *                                        x1,y1 : (x1:1~128,y1:1~8)
        * @retval
        unsigned int j=0;
        unsigned char x,y;
  if(y1%8==0)
                y = y1/8;
  else
                y = y1/8 + 1;
        for(y=y0;y<y1;y++)
                oled_setPos(x0,y);
    for(x=x0;x<x1;x++)
                        oled_data(BMP[j++]);
//m^n
uint32_t oled_pow(uint8_t m,uint8_t n)
        uint32_t result=1;
        while(n--)
          result*=m;
        return result;
* @brief  oled_showNum 显示数字
                        num
                        len         数字长度
                        sizel 数字大小 12/16/24
  * @retval
        uint8_t t,temp;
        for(t=0;t<len;t++)
                //        BSP_LED_Toggle(LED_BLUE);
                temp=(num/oled_pow(10,len-t-1))%10;
                if(temp==0)
                        oled_display_char(x+(size1/2)*t,y,'0',size1);
                else
                        oled_display_char(x+(size1/2)*t,y,temp+'0',size1);
* @brief  show_title 显示一个汉字标题,仅用以测试
  * @param
  * @retval
        uint32_t i;
        oled_cls();
        for(i=0; i<=10; i++)
                if(i<=4)
                        oled_showCN(20+i*16,1,Title,i);  //
                else
                        oled_showCN(10+(i-5)*16,4,Title,i);  //
main.c ,注意要把oled头文件加进去
* @file  i2c/i2c_bl24c256/source/main.c
* @brief Main program of I2C for the Device Driver Library.
@verbatim
   Change Logs:
   Date             Author          Notes
   2023-05-31       CDT             First version
@endverbatim
* Copyright (C) 2022-2023, Xiaohua Semiconductor Co., Ltd. All rights reserved.
* This software component is licensed by XHSC under BSD 3-Clause license
* (the "License"); You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
*                    opensource.org/licenses/BSD-3-Clause
* Include files
#include "main.h"
* @addtogroup HC32F448_DDL_Examples
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
#define LED_G_PORT          (GPIO_PORT_A)
#define LED_G_PIN           (GPIO_PIN_02)
/* LED toggle definition */
#define LED_G_TOGGLE()      (GPIO_TogglePins(LED_G_PORT, LED_G_PIN))
* Global variable definitions (declared in header file with 'extern')
* Local function prototypes ('static')
* Local variable definitions ('static')
* Function implementation - global ('extern') and local ('static')
* @brief  LED Init,显示一个板上的灯配合测试
* @param  None
* @retval None
static void LED_Init(void)
    stcGpioInit.u16PinState = PIN_STAT_RST;
    stcGpioInit.u16PinDir = PIN_DIR_OUT;
    (void)GPIO_Init(LED_G_PORT, LED_G_PIN, &stcGpioInit);
* @retval LL_OK
    int32_t i32Ret;
    float32_t fErr;
    I2C_DeInit(I2Cx);
    return i32Ret;
* @param
* @retval LL_OK
    (void)I2C_2_Init(I2C_UNIT);
* @param  None
int32_t main(void)
    BSP_LED_Init();
                I2C_GPIO_Init();
                LED_Init();
                oled_init();
                        oled_cls();
                        DDL_DelayMS(200);
    for (;;) {
                        //oled_cls();
                        show_title();
//                        LED_G_TOGGLE();
* EOF (not truncated)
