[技术问答] HC32F460 IIC
2588|7
 楼主| Luxuff 发表于 2024-3-14 10:35 | 显示全部楼层 |阅读模式
HC32F460JETA-LQFP48 配置IIC,PB12\PB13可以正常运行,换PA10\PA11就不行了,时钟和数据都监测不到,为啥吖?已确认PA10\PA11未被占用,且支持IIC输出,各位大佬,救救孩子
  1. //宏定义
  2. #define ADC_ADDRESS                         (0x48U) //01001000<<1 = 1001000
  3. #define I2C_ADC_SCL_PORT                    (GPIO_PORT_B)
  4. #define I2C_ADC_SCL_PIN                     (GPIO_PIN_12)
  5. #define I2C_ADC_SDA_PORT                    (GPIO_PORT_B)
  6. #define I2C_ADC_SDA_PIN                     (GPIO_PIN_13)
  7. #define I2C_ADC_GPIO_SCL_FUNC               (GPIO_FUNC_49)
  8. #define I2C_ADC_GPIO_SDA_FUNC               (GPIO_FUNC_48)
  9. #define I2C_ADC_UNIT                        (CM_I2C3)
  10. #define I2C_ADC_FCG_USE                     (FCG1_PERIPH_I2C3)
  11. //初始化部分
  12. int32_t ADC_POT_Initialize(void)
  13. {
  14.
  15.     LL_PERIPH_WE(LL_PERIPH_ALL);
  16.     //ADC
  17.    /* Initialize I2C port*/
  18.     GPIO_SetFunc(I2C_ADC_SCL_PORT, I2C_ADC_SCL_PIN, I2C_ADC_GPIO_SCL_FUNC);
  19.     GPIO_SetFunc(I2C_ADC_SDA_PORT, I2C_ADC_SDA_PIN, I2C_ADC_GPIO_SDA_FUNC);
  20.     //GPIO_SetFunc(I2C_PTT_SCL_PORT, I2C_PTT_SCL_PIN, I2C_PTT_GPIO_SCL_FUNC);
  21.     //GPIO_SetFunc(I2C_PTT_SDA_PORT, I2C_PTT_SDA_PIN, I2C_PTT_GPIO_SDA_FUNC);
  22.     /* Enable I2C Peripheral*/
  23.     FCG_Fcg1PeriphClockCmd(I2C_ADC_FCG_USE, ENABLE);
  24.    // FCG_Fcg1PeriphClockCmd(I2C_PTT_FCG_USE, ENABLE);
  25.
  26.
  27.     int32_t i32Ret;
  28.     stc_i2c_init_t stcI2cInit;
  29.     float32_t fErr;
  30.     I2C_DeInit(I2C_ADC_UNIT);
  31.     //I2C_DeInit(I2C_PTT_UNIT);
  32.     (void)I2C_StructInit(&stcI2cInit);
  33.     stcI2cInit.u32ClockDiv = I2C_CLK_DIV8;
  34.     stcI2cInit.u32Baudrate = I2C_ADC_BAUDRATE;
  35.     stcI2cInit.u32SclTime = 3UL;
  36.     i32Ret = I2C_Init(I2C_ADC_UNIT, &stcI2cInit, &fErr);
  37.     if(i32Ret != LL_OK){
  38.       while(1);
  39.     }
  40.
  41.     /*stcI2cInit.u32Baudrate = I2C_PTT_BAUDRATE;
  42.     i32Ret = I2C_Init(I2C_PTT_UNIT, &stcI2cInit, &fErr);
  43.     if(i32Ret != LL_OK){
  44.       while(1);
  45.     }*/
  46.
  47.     I2C_BusWaitCmd(I2C_ADC_UNIT, ENABLE);
  48.     //I2C_BusWaitCmd(I2C_PTT_UNIT, ENABLE);
  49.     /* Peripheral registers write protected */
  50.     LL_PERIPH_WP(LL_PERIPH_ALL);
  51.
  52.     uint8_t data[3];
  53.     i32Ret = I2C_Master_Receive(I2C_ADC_UNIT, ADC_ADDRESS | 0x01, data, 3);
  54.     if(i32Ret == LL_OK){
  55.       memcpy(&adc_config ,&data[2], 1);
  56.     }
  57.
  58.     return i32Ret;
  59. }
  1. //不能正常运行的宏,我就改了针脚配置
  3. #define I2C_ADC_SCL_PORT                    (GPIO_PORT_A)
  4. #define I2C_ADC_SCL_PIN                     (GPIO_PIN_10)
  5. #define I2C_ADC_SDA_PORT                    (GPIO_PORT_A)
  6. #define I2C_ADC_SDA_PIN                     (GPIO_PIN_11)
  9. #define I2C_ADC_UNIT                        (CM_I2C1)
  10. #define I2C_ADC_FCG_USE                     (FCG1_PERIPH_I2C1)
wubangmi 发表于 2024-3-15 09:21 | 显示全部楼层
有没有可能是你板子有问题,也就是你PA10/PA11的引脚上有电容,或者没有上拉电阻,或者上拉电阻太大?
 楼主| Luxuff 发表于 2024-3-15 13:17 | 显示全部楼层
有没有可能是你板子有问题,也就是你PA10/PA11的引脚上有电容,或者没有上拉电阻,或者上拉电阻太大? ...
昨天已经解决了,就是你说的这个问题,没有上拉电阻,我太依赖开发板了
daichaodai 发表于 2024-3-18 07:59 来自手机 | 显示全部楼层
呵呵,IIC必须要加上啦电阻才得行。
小夏天的大西瓜 发表于 2024-3-26 15:36 | 显示全部楼层
上拉电阻是必须的嘛?IIC通讯电气设计
LOVEEVER 发表于 2024-3-27 10:52 | 显示全部楼层
昨天已经解决了,就是你说的这个问题,没有上拉电阻,我太依赖开发板了 ...
开发板一般情况下IIC有相关的跳线吧?
xdvca 发表于 2024-7-31 22:39 | 显示全部楼层
在配置 HC32F460JETA-LQFP48 的 I2C 时,如果 PB12 和 PB13 可以正常工作,但 PA10 和 PA11 不能工作,这可能涉及多个因素,包括引脚配置、外设设置、或者其他硬件问题。
