[活动专区] 【AT-START-F405测评】+Workbench生成代码控制LED
 楼主| xu@xupt 发表于 2024-4-21 20:36 | 显示全部楼层 |阅读模式
【AT-START-F405测评】+1、Workbench生成代码控制LED
1、AT32_Work_Bench安装
A、安装软件
AT 32 Work Bench可以通过MCU图形配置生成初始化C代码和相应的IDE项目,从而减少开发工作量、时间和成本。AT 32工作台具有以下功能:
1.支持外围设备初始化配置
2.支持PIN UX配置和定制PIN标签
3。支持自动系统时钟配置
4.支持在线代码查看
5.支持“添加用户代码”功能(现有代码不会被新项目覆盖)
6.支持Keil、IAR和AT 32 IDE
7中的自动项目生成。记录最近的设计
8。生成配置报告(.pdf)
9.支持简体中文和英文菜单
10.支持Windows和Linux
11。支持在线软件升级和MCU硬件下载
https://www.arterychip.com/en/support/index.jsp?index=6
0cc9df13d7704c004fad9ccada5fd307
B、配置
AT 32 Work Bench和STM 的很像
在本例中配置的
c2b5f97a6fac72a0fe64d39ed77dea34
很直观的配置,可以配置管脚,很方便。
cae08ce8ae8526af5d0dd42822a3c168
2、AT32_Work_Bench代码生成
生成的代码如下:
/* add user code begin Header */
  * @file     main.c
  * @brief    main program
  *                       Copyright notice & Disclaimer
  * The software Board Support Package (BSP) that is made available to
  * download from Artery official website is the copyrighted work of Artery.
  * Artery authorizes customers to use, copy, and distribute the BSP
  * software and its related documentation for the purpose of design and
  * development in conjunction with Artery microcontrollers. Use of the
  * software is governed by this copyright notice and the following disclaimer.
  * THIS SOFTWARE IS PROVIDED ON "AS IS" BASIS WITHOUT WARRANTIES,
  * GUARANTEES OR REPRESENTATIONS OF ANY KIND. ARTERY EXPRESSLY DISCLAIMS,
  * TO THE FULLEST EXTENT PERMITTED BY LAW, ALL EXPRESS, IMPLIED OR
  * STATUTORY OR OTHER WARRANTIES, GUARANTEES OR REPRESENTATIONS,
  * INCLUDING BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY,
  * FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT.
/* add user code end Header */
/* Includes ------------------------------------------------------------------*/
#include "at32f402_405_wk_config.h"
/* private includes ----------------------------------------------------------*/
/* add user code begin private includes */
/* add user code end private includes */
/* private typedef -----------------------------------------------------------*/
/* add user code begin private typedef */
/* add user code end private typedef */
/* private define ------------------------------------------------------------*/
/* add user code begin private define */
/* add user code end private define */
/* private macro -------------------------------------------------------------*/
/* add user code begin private macro */
/* add user code end private macro */
/* private variables ---------------------------------------------------------*/
/* add user code begin private variables */
/* add user code end private variables */
/* private function prototypes --------------------------------------------*/
/* add user code begin function prototypes */
/* add user code end function prototypes */
/* private user code ---------------------------------------------------------*/
/* add user code begin 0 */
/* add user code end 0 */
  * @brief main function.
  * @param  none
  * @retval none
int main(void)
  /* add user code begin 1 */
  /* add user code end 1 */
  /* system clock config. */
wk_system_clock_config();
  /* config periph clock. */
wk_periph_clock_config();
  /* nvic config. */
wk_nvic_config();
  /* initgpio function. */
wk_gpio_config();
  /* add user code begin 2 */
  /* add user code end 2 */
while(1)
    /* add user code begin 3 */
gpio_bits_reset(GPIOF, GPIO_PINS_4 | GPIO_PINS_5 | GPIO_PINS_6);
    /* add user code end 3 */
通多编译,下载可以实现三个LED同时亮。
3dc7077463e92f990e8a226c7c95c427
0f3c9a1e464fcd8f22276b43d3e3930f
效果
a8a8c785215eb369d2a5bb2369731acc
bf4150b75d7b39bb6d4c770fb692173b
8afd2321aa1d59312e522ffd00260de9
16b3cb43f3589a22da3a6c985b98fe1c
171351c8cf77fe6a3499200de5e83a98
af464d9df01f931b4a6cb368833f02fe
62b1f8aeacd7449de14d1be6144c0570
快速回复 返回顶部 返回列表
