- * CONFIGURATION BITS Generated Driver Source File.
- * [url=home.php?mod=space&uid=288409]@file[/url] config_bits.c
- * @ingroup config_bitsdriver
- * [url=home.php?mod=space&uid=247401]@brief[/url] This file contains the API Implementation for the Device Configuration Bits driver.
- * [url=home.php?mod=space&uid=895143]@version[/url] Driver Version 2.0.2
- * @version Package Version 2.1.6
- ? [2024] Microchip Technology Inc. and its subsidiaries.
- Subject to your compliance with these terms, you may use Microchip
- software and any derivatives exclusively with Microchip products.
- You are responsible for complying with 3rd party license terms
- applicable to your use of 3rd party software (including open source
- software) that may accompany Microchip software. SOFTWARE IS ?AS IS.?
- NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS
- SOFTWARE, INCLUDING ANY IMPLIED WARRANTIES OF NON-INFRINGEMENT,
- MERCHANTABILITY, OR FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT
- WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
- INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY
- KIND WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF
- MICROCHIP HAS BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE
- FORESEEABLE. TO THE FULLEST EXTENT ALLOWED BY LAW, MICROCHIP?S
- TOTAL LIABILITY ON ALL CLAIMS RELATED TO THE SOFTWARE WILL NOT
- EXCEED AMOUNT OF FEES, IF ANY, YOU PAID DIRECTLY TO MICROCHIP FOR
- THIS SOFTWARE.
- // Configuration bits: selected in the GUI
- //CONFIG1
- #pragma config FEXTOSC = ECH // External Oscillator Mode Selection->EC (external clock) above 8 MHz
- #pragma config RSTOSC = HFINTOSC_64MHZ // Power-up Default Value for COSC->HFINTOSC with HFFRQ = 64 MHz and CDIV = 1:1
- //CONFIG2
- #pragma config FCMENP = ON // Fail-Safe Clock Monitor Enable - Primary XTAL Enable->Fail-Safe Clock Monitor enabled; timer will flag FSCMP bit and OSFIF interrupt on EXTOSC failure.
- #pragma config CLKOUTEN = OFF // Clock Out Enable->CLKOUT function is disabled
- #pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable->Fail-Safe Clock Monitor enabled
- #pragma config CSWEN = ON // Clock Switch Enable->Writing to NOSC and NDIV is allowed
- #pragma config FCMENS = ON // Fail-Safe Clock Monitor Enable - Secondary XTAL Enable->Fail-Safe Clock Monitor enabled; timer will flag FSCMP bit and OSFIF interrupt on SOSC failure.
- #pragma config PR1WAY = ON // PRLOCKED One-Way Set Enable->PRLOCKED bit can be cleared and set only once
- //CONFIG3
- #pragma config MVECEN = OFF // Multivector Enable->Interrupt contoller does not use vector table to prioritze interrupts
- #pragma config MCLRE = EXTMCLR // Master Clear (MCLR) Enable->If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is MCLR
- #pragma config BOREN = SBORDIS // Brown-out Reset Enable->Brown-out Reset enabled , SBOREN bit is ignored
- #pragma config PWRTS = PWRT_OFF // Power-up Timer Selection->PWRT is disabled
- #pragma config IVT1WAY = ON // IVTLOCK One-Way Set Enable->IVTLOCKED bit can be cleared and set only once
- #pragma config LPBOREN = OFF // Low-Power BOR Enable->Low-Power BOR disabled
- //CONFIG4
- #pragma config XINST = OFF // Extended Instruction Set Enable->Extended Instruction Set and Indexed Addressing Mode disabled
- #pragma config LVP = ON // Low-Voltage Programming Enable->Low voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored
- #pragma config ZCD = OFF // ZCD Disable->ZCD module is disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON
- #pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable->Stack full/underflow will cause Reset
- #pragma config BORV = VBOR_1P9 // Brown-out Reset Voltage Selection->Brown-out Reset Voltage (VBOR) set to 1.9V
- #pragma config PPS1WAY = ON // PPSLOCKED One-Way Set Enable->PPSLOCKED bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle
- //CONFIG5
- #pragma config WDTCPS = WDTCPS_31 // WDT Period Select->Divider ratio 1:65536; software control of WDTPS
- #pragma config WDTE = OFF // WDT Operating Mode->WDT Disabled; SWDTEN is ignored
- //CONFIG6
- #pragma config WDTCWS = WDTCWS_7 // WDT Window Select->window always open (100%); software control; keyed access not required
- #pragma config WDTCCS = SC // WDT Input Clock Selector->Software Control
- //CONFIG7
- #pragma config SAFEN = OFF // Storage Area Flash (SAF) Enable->SAF disabled
- #pragma config BBEN = OFF // Boot Block Enable->Boot block disabled
- #pragma config BBSIZE = BBSIZE_512 // Boot Block Size Selection->Boot Block size is 512 words
- //CONFIG8
- #pragma config WRTB = OFF // Boot Block Write Protection->Boot Block not Write protected
- #pragma config WRTC = OFF // Configuration Register Write Protection->Configuration registers not Write protected
- #pragma config WRTD = OFF // Data EEPROM Write Protection->Data EEPROM not Write protected
- #pragma config WRTAPP = OFF // Application Block Write Protection->Application Block not write protected
- #pragma config WRTSAF = OFF // Storage Area Flash (SAF) Write Protection->SAF not Write Protected
- //CONFIG9
- #pragma config CP = OFF // User Program Flash Memory and Data EEPROM Code Protection->PFM and Data EEPROM code protection disabled
- End of File
