[PIC®/AVR®/dsPIC®产品] PIC18F458单片机,IIC操作流程代码
943|1
 楼主| 木木guainv 发表于 2025-1-17 04:15 | 显示全部楼层 |阅读模式
以下包含了PIC18单片机驱动代码部分,供大家使用
#ifndef __I2C_H__
#define __I2C_H__
/* link the I/O library */
#pragma library io
#include <pic18fregs.h>
#define _I2CPARAM_SPEC        __data
/* I2C modes of operation */
#define I2C_SLAVE10B_INT        0x0f
#define I2C_SLAVE7B_INT                0x0e
#define I2C_SLAVE_IDLE                0x0b
#define I2C_MASTER                0x08
#define I2C_SLAVE10B                0x07
#define I2C_SLAVE7B                0x06
/* slew rate control */
#define I2C_SLEW_OFF        0xc0
#define I2C_SLEW_ON        0x00
/* macros to generate hardware conditions on I2C module */
/* generate stop condition */
#define I2C_STOP()        SSPCON2bits.PEN=1
/* generate start condition */
#define I2C_START()        SSPCON2bits.SEN=1
/* generate restart condition */
#define I2C_RESTART()        SSPCON2bits.RSEN=1
/* generate not acknoledge condition */
#define I2C_NACK()        SSPCON2bits.ACKDT=1; SSPCON2bits.ACKEN=1
/* generate acknoledge condition */
#define I2C_ACK()        SSPCON2bits.ACKDT=0; SSPCON2bits.ACKEN=1
/* wait until I2C is idle */
#define I2C_IDLE()        while((SSPCON2 & 0x1f) | (SSPSTATbits.R_W));
/* is data ready from I2C module ?? */
#define I2C_DRDY()        (SSPSTATbits.BF)
/* function equivalent to macros for generating hardware conditions */
/* stop */
void i2c_stop(void);
/* start */
void i2c_start(void);
/* restart */
void i2c_restart(void);
/* not acknoledge */
void i2c_nack(void);
/* acknoledge */
void i2c_ack(void);
/* wait until I2C goes idle */
void i2c_idle(void);
/* is character ready in I2C buffer ?? */
unsigned char i2c_drdy(void);
/* read a character from I2C module */
unsigned char i2c_readchar(void);
/* read a string from I2C module */
char i2c_readstr(_I2CPARAM_SPEC unsigned char *ptr, unsigned char len);
/* write a character to I2C module */
char i2c_writechar(unsigned char dat);
/* write a string to I2C module */
char i2c_writestr(unsigned char *ptr);
/* configure I2C port for operation */
void i2c_open(unsigned char mode, unsigned char slew, unsigned char addr_brd);
void i2c_close(void);
#endif        /* __I2C_H__ */
原文链接:https://blog.csdn.net/weixin_43855490/article/details/144025953
mintspring 发表于 2025-1-18 14:38 | 显示全部楼层
这些老型号没法用MCC,真是非常的遗憾。如果可以用MCC会用的人很多。
