[综合信息] IAP升级 整合多个bin文件为一个升级包
 楼主| 晓伍 发表于 2025-2-22 18:39 | 显示全部楼层 |阅读模式
1、我们的程序分区目前为:
Boot 0x8000000 – 0x8004000 16KB
Settings 0x8004000 – 0x8006000 8KB
App 0x8006000 – 0x800B000 20KB
Download 0x800B000 – 0x800FFFF 20KB
2、烧录时候的bin文件有三个:
Bootloader.bin. 起始地址0x8000000
Settings.bin 起始地址0x8004000
Application.bin 起始地址0x8006000
3、我们新建一个(16+8+20)*1024个字节的数组,将Bootloader.bin从0开始填到数组中,将Settings.bin从0x4000处填充到数组中,将Application.bin 从0x6000填充到数组中,最后写入文件中,即可得到我们想要的all.bin
4、代码路径:
5、代码分析:
generate_bin.c
#include <stdio.h>
#include <time.h>
#include <string.h>
#include <assert.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include "settings.h"
#include "flash.h"
#define APP_BIN_PATH            "../Application/build/Application.bin"
#define BOOT_BIN_PATH           "../Bootloader/build/Bootloader.bin"
#define SETTING_BIN_PATH        "../Settings/build/Settings.bin"
#define ALL_BIN_LENGTH          (16 + 8 + 20) * 1024
#define OTA_BIN_LENGTH          (8 + 20) * 1024
static int copy_bootloader_bin(MI_U8 *p_buff)
    FILE *file;
    MI_U8 r_buff[BOOT_SIZE] = {0};
    size_t r_size;
    size_t file_size;
    file = fopen(BOOT_BIN_PATH,"rb");
    if (file == NULL)
        printf("fopen BootLoader error\n");
        return -1;
    fseek(file,0,SEEK_END);
    file_size = ftell(file);
    fseek(file,0,SEEK_SET);
    r_size = fread(r_buff,sizeof(MI_U8),sizeof(r_buff),file);
    if (r_size != file_size)
        printf("read bootloader size == %ld\n",r_size);
    else
        printf("read bootloader file ok\n" );
    memcpy(p_buff,r_buff,r_size);
    fclose(file);
    return 0;
static int copy_settings_bin(MI_U8 *p_buff)
    FILE *file = fopen(SETTING_BIN_PATH,"rb");
    MI_U8 r_buff[SETTINGS_SIZE] = {0};
    size_t r_size;
    size_t file_size;
    if (file == NULL)
        printf("fopen Application error\n");
        return -1;
        printf("read settings size == %ld\n",r_size);
    else
        printf("read settings file ok\n" );
    p_buff += (BOOT_SIZE);
    fclose(file);
    return 0;
static int copy_application_bin(MI_U8 *p_buff)
    FILE *file = fopen(APP_BIN_PATH,"rb");
    MI_U8 r_buff[APP_SIZE] = {0};
    size_t r_size;
    size_t file_size;
    if (file == NULL)
        return -1;
        printf("read Application size == %ld\n",r_size);
    else
        printf("read Application file ok\n" );
    p_buff += (BOOT_SIZE + SETTINGS_SIZE);
    fclose(file);
    return 0;
static MI_BOOL create_all_bin(void)
    int ret;
    MI_U8 all_data[ALL_BIN_LENGTH] = {0};
    size_t w_size = 0;
    ret = copy_bootloader_bin(all_data);
    if (ret != 0)
        printf("copy_bootloader_bin error\n");
        return -1;
    ret = copy_settings_bin(all_data);
    if (ret != 0)
        printf("copy_settings_bin error\n");
        return -1;
    ret = copy_application_bin(all_data);
    if (ret != 0)
        printf("copy_application_bin error\n");
        return -1;
    FILE *file = fopen("../output/all.bin","wb");
    if (file == NULL)
        printf("fopen all.bin error\n");
        return -1;
    w_size = fwrite(all_data,1,(BOOT_SIZE + SETTINGS_SIZE + APP_SIZE),file);
    fclose(file);
    if (w_size == BOOT_SIZE + SETTINGS_SIZE + APP_SIZE)
        printf("Create bin is Ok\n");
    else
        printf("Create bin error\n");
        return -1;
    return MI_TRUE;
int main(int argc,char *argv[])
    if (MI_TRUE == create_all_bin())
        printf(FONT_COLOR_BLUE"Create all.bin Success!\n"COLOR_NONE);
    else
        printf(BACKGROUND_COLOR_RED"Create all.bin Success!\n"COLOR_NONE);
    return 0;
6、Makefile
CC = gcc
SRC = $(wildcard *.c)
OBJ = $(addprefix $(BUILD_DIR)/,$(notdir $(SRC:.c=.o)))
#OBJ = $(patsubst %.c, %.o, $(SRC))
TRAGET = generate
BUILD_DIR = build
C_INCLUDES +=  \
        -I../Common/Flash \
        -I../Common/Settings \
        -I../Common
C_FLAG += -Wall -MD -MP -MF"$(@:%.o=%.d)"
C_FLAG += -DUSER_SETTING_IN_HOST
all: $(BUILD_DIR) $(BUILD_DIR)/$(TRAGET)
$(BUILD_DIR)/$(TRAGET):$(OBJ) Makefile | $(BUILD_DIR)
        $(CC)  $< -o $@
$(OBJ): $(SRC)  Makefile | $(BUILD_DIR)
        $(CC) -c $(C_FLAG) $(C_INCLUDES) $< -o $@
$(BUILD_DIR):
        @-mkdir $@
clean:
        @rm -rf $(TRAGET)
        @rm -rf $(OBJ)
        @rm -rf $(BUILD_DIR)
-include $(wildcard $(BUILD_DIR)/*.d)
# *** EOF ***
7、根目录下make后会在output下生成all.bin文件
8、make allbin 烧录到板卡验证。
原文链接:https://blog.csdn.net/weixin_43932857/article/details/130487395
快速回复 返回顶部 返回列表
