[MM32软件] MM32G0001配置PWM
 楼主| 发表于 2025-4-10 13:57 | 显示全部楼层 |阅读模式
void TIM3_Configure(void)
    GPIO_InitTypeDef        GPIO_InitStruct;
    TIM_OCInitTypeDef       TIM_OCInitStruct;
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
    /* Compute the value to be set in ARR regiter to generate signal frequency at 100 Khz */
    uint32_t TimerPeriod = (TIM_GetTIMxClock(TIM1) / 100000 ) - 1;
    /* Compute CCR1 value to generate a duty cycle at 80% for channel 1 */
    uint32_t Channel1Pulse = ((uint32_t)800 * (TimerPeriod - 1)) / 1000;//设置占空比,可以自己直接赋值
    RCC_APB1PeriphClockCmd(RCC_APB1ENR_TIM3, ENABLE);
    TIM_TimeBaseStructInit(&TIM_TimeBaseStruct);
    TIM_TimeBaseStruct.TIM_Prescaler         = 0;
    TIM_TimeBaseStruct.TIM_CounterMode       = TIM_CounterMode_Up;
    TIM_TimeBaseStruct.TIM_Period            = TimerPeriod;
    TIM_TimeBaseStruct.TIM_ClockDivision     = TIM_CKD_Div1;
    TIM_TimeBaseStruct.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStruct);
    TIM_OCStructInit(&TIM_OCInitStruct);
    TIM_OCInitStruct.TIM_OCMode       = TIM_OCMode_PWM1;
    TIM_OCInitStruct.TIM_OutputState  = TIM_OutputState_Enable;
    TIM_OCInitStruct.TIM_Pulse        = 0;
    TIM_OCInitStruct.TIM_OCPolarity   = TIM_OCPolarity_High;
    TIM_OCInitStruct.TIM_OCIdleState  = TIM_OCIdleState_Set;
    TIM_OCInitStruct.TIM_Pulse = Channel1Pulse;//占空比
    TIM_OC1Init(TIM3, &TIM_OCInitStruct);
    RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOA, ENABLE);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_4);  /* TIM3_CH1  */
                                                           //这里根据手册的引脚复用图选择第三个参数,这里是第四复用功能
    GPIO_StructInit(&GPIO_InitStruct);
    GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_11;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
    GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStruct);
    TIM_Cmd(TIM3, ENABLE);
    TIM_CtrlPWMOutputs(TIM3, ENABLE);//使能PWM输出
MM32和STM32配置PWM差不多,除了引脚复用和最后的PWM输出使能有所区别,其他基本一样。
原文链接:https://blog.csdn.net/weixin_74242699/article/details/147113544
发表于 2025-4-23 20:12 | 显示全部楼层
这种通过结构体配置的方式,应该是参考的ST的风格
发表于 2025-4-23 21:17 来自手机 | 显示全部楼层
PWM本身通用性就比较强
发表于 2025-4-24 18:35 | 显示全部楼层
学习一下
快速回复 返回顶部 返回列表
