stm32配置中断死机????
 楼主| liujun11 发表于 2013-4-20 17:26 | 显示全部楼层 |阅读模式
void Touch_Config(void)
        EXTI_InitTypeDef EXTI_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
#if 1
                //下面是SPI相关GPIO初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //通用推挽输出
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        //按键user
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;  //通用推挽输出
        //下面是SPI相关GPIO初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;  //上拉输入
        //Configure PC6 pin: TP_CS pin
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;         //推挽输出
        GPIO_Init(GPIOC,&GPIO_InitStructure);
        //Configure PC4 pin: TP_INT pin
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
#endif
        LED_ON(LED1);
#if 1
/*---------------------中断优先级配置--------------------------------------------------------------*/
                /* Configure one bit for preemption priority */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);           // 设置中断组 为2
        NVIC_InitStructure.NVIC_IRQChannel=EXTI4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=2;
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel=EXTI3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=1;
/*---------------------外部中断优先级配置--------------------------------------------------------------*/
        LED_ON(LED2);
          /* Generate software interrupt: simulate a falling edge applied on PEN EXTI line */
        /*-------------触摸屏中断---------------------*/
          GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource4);
          /* Configure PEN EXTI Line to generate an interrupt on falling edge */
          EXTI_InitStructure.EXTI_Line = EXTI_Line4;
          EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
          EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
          EXTI_InitStructure.EXTI_LineCmd = ENABLE;
          EXTI_Init(&EXTI_InitStructure);
        EXTI_GenerateSWInterrupt(EXTI_Line4);
        LED_ON(LED3);
        /*-------------------按键中断------------------------*/
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource8);
        EXTI_InitStructure.EXTI_Line = EXTI_Line3;
  //        EXTI_GenerateSWInterrupt(EXTI_Line4);
        EXTI_GenerateSWInterrupt(EXTI_Line3);
#endif
程序走到第一红色部分死机
LED1,LED2,亮
LED3灭的
不知道哪里出问题了?
/*---------------------------------------------时钟配置---------------------------------------------------------------------*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA  | RCC_APB2Periph_GPIOC
                                                           |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
                                                           ,ENABLE );
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //使能IO复用功能,使用中断功能重要!!!
        while(SysTick_Config(SystemCoreClock / 1000));
QQ:1009243634,
airwill 发表于 2013-4-20 18:36 | 显示全部楼层
怎么个"死机"法.
我很久没有遇到 "死机" 问题了.
建议借助调试工具来看. 因为"死机" 实在太不好分析了
lxj19901115 发表于 2013-5-7 17:57 | 显示全部楼层
很简单的方法,没有找到中断函数入口
