Orcad出错,苦恼中,请求各位帮助
1858|1
 楼主| 今人古月 发表于 2008-3-22 14:18 | 显示全部楼层 |阅读模式
OrCAD, ce, IO, se, ic
<br /><font color=#FF00C0>各位大虾,你们装的orcad10.5&nbsp;有没有以下问题:<br />用open菜单打开已建的*opj文件事出现下面的错误:&nbsp;</font><br /><font color=#FF00C0></font><br />This&nbsp;application,&nbsp;Capture&nbsp;CIS,has&nbsp;encounterned&nbsp;following&nbsp;unrecoverable&nbsp;exception,and&nbsp;hence&nbsp;needs&nbsp;closed&nbsp;down&nbsp;<br /><br />EXCEPTION_ACCESS_VIOLATION:&nbsp;<br />&nbsp;&nbsp;One&nbsp;of&nbsp;the&nbsp;threads&nbsp;has&nbsp;tried&nbsp;to&nbsp;read&nbsp;from&nbsp;or&nbsp;write&nbsp;to&nbsp;a&nbsp;virtual&nbsp;address&nbsp;for&nbsp;which&nbsp;it&nbsp;does&nbsp;not&nbsp;have&nbsp;the&nbsp;appropriate&nbsp;access&nbsp;<br /><br />Do&nbsp;you&nbsp;want&nbsp;to&nbsp;save&nbsp;all&nbsp;the&nbsp;open&nbsp;design&nbsp;now&nbsp;before&nbsp;Capture&nbsp;closes?&nbsp;&nbsp;<br /><br /><font color=#FF00C0>我在网上看到有人说,解决方法:</font>&nbsp;<br /><br />HKEY_CURRENT_USER&nbsp;SoftwareMicrosoftWindowsCurrentVersionPoliciesExplorer下的&nbsp;NoRecentDocsHistory注册表项(DWORD类型的)设置为0,重启explorer.exe进程&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<font color=#FF00C0>&nbsp;可是,我的注册表中没有&nbsp;NoRecentDocsHistory项。我自己新建了一个并设置为0,但问题依旧,请大家帮帮忙,看看应该怎么解决,不胜感激。</font><br />
 楼主| 今人古月 发表于 2008-3-22 23:01 | 显示全部楼层
555
大家都没有人遇到过这个问题么,等待中。。。。。
