Assuming that you have designed the opamp correctly, the limited value of "gm" of opmap and the input parasitc capacitance may be the root cause.<br /><br /> Iout = -(V- - V+)*gm, V+ = 0<br /> Vout = Iout*Rout<br /><br />Becasue gm is a limited value, there is ALWAYS a "V-" corresponding to Vout!<br /><br /><br /> <br />
