[cadence] CADENCE IC 610 安装无法运行 lmli和 icfb&
3175|1
 楼主| alexchenyu 发表于 2013-9-29 17:18 | 显示全部楼层 |阅读模式
15:12:25 (lmgrd) Can't open /usr/tmp/.flexlm/lmgrdl.3715, errno: 215:12:25 (lmgrd) "chenyu-virtual-machine": Not a valid server hostname, exiting.15:12:25 (lmgrd) Valid license server system hosts are: "chenyu" 15:12:25 (lmgrd) Using license file "/home/eda/ic610/share/license/license.dat"15:12:25 (lmgrd) Can't remove statfile /usr/tmp/.flexlm/lmgrdl.3715: errno No such file or directorychenyu@chenyu-virtual-machine:~$
我安装成功,.bashrc文件也正确修改,/usr/bin/tmp/文件夹也创建,但lmli不能正常使用,这是为什么呀?
 楼主| alexchenyu 发表于 2013-9-29 17:21 | 显示全部楼层
求,哪位大吓给点指点????、
