电脑可以识别自定义的Hid设备,可是给设备发数据时候总是卡死在写函数,writefile。部分代码如下- UINT WriteReportThread(LPVOID pParam)//写线程
- while(1)
- ResetEvent(WriteOverlapped.hEvent);
- WaitForSingleObject(WriteOverlapped.hEvent, INFINITE);
- DataSending = false;
- return 0;
- BOOL CUSBDlg::SendData()//发送数据
- BOOL Result;
- UINT LastError;
- UINT i;
- CString Str,str_send;
- DWORD Length = 0;
- if(MyDevFind==FALSE)
- AddToInfoOut(_T("设备未找到"));
- return FALSE;
- if(hWriteHandle==INVALID_HANDLE_VALUE)
- AddToInfoOut(_T("无效的写报告句柄,可能是打开设备时失败"));
- return FALSE;
- if(DataSending==TRUE)
- AddToInfoOut(_T("数据正在发送中,暂时不能发送"));
- return FALSE;
- memset(WriteReportBuffer, 0, 512);
- WriteReportBuffer[0]=0x00;
- CString str_id=itos(WriteReportBuffer[0],16).Right(2);
- GetDlgItem(IDC_EDIT_REPORTID)->SetWindowText(str_id);
- GetDlgItemText(IDC_ESend, str_send);
- UINT count=str_send.GetLength();
- for(i=1; i<1+count; i++)
- WriteReportBuffer[i]=(UCHAR)str_send.GetAt(i-1);
- WriteReportBuffer[1] = 0x40;
- WriteReportBuffer[2] = 0xa2;
- WriteReportBuffer[3] = 0x02;
- AddToInfoOut(_T("发送信息:1字节报告ID+8字节实际数据"));
- Str=_T("");
- for(i=0; i<Capabilities.OutputReportByteLength; i++)
- Str+=itos(WriteReportBuffer[i],16).Right(2)+_T(" ");
- AddToInfoOut(Str, FALSE);
- str_send.Insert(0, _T("发送信息"));
- GetDlgItem(IDC_REC_STR)->SetWindowText(str_send);
- UpdateWindow();
- DataSending=TRUE;
- Result=WriteFile(hWriteHandle,
- &WriteReportBuffer,
- Capabilities.OutputReportByteLength,
- &Length,
- (LPOVERLAPPED)&WriteOverlapped);
- if(Result==FALSE)
- LastError=GetLastError();
- if((LastError==ERROR_IO_PENDING)||(LastError==ERROR_SUCCESS))
- return TRUE;
- else
- DataSending=FALSE;
- AddToInfoOut(_T("错误代码:")+itos(LastError));
- if(LastError==1)
- AddToInfoOut(_T("该设备不支持WriteFile函数。"), FALSE);
- return FALSE;
- AddToInfoOut(_T("数据发送成功!"));
- DataSending = FALSE;
- return TRUE;
