[STM32] TIM8捕获,TIM1pwm输出问题
2222|6
 楼主| 红绿灯不休息 发表于 2015-1-24 12:06 | 显示全部楼层 |阅读模式
这个程序是设置TIM8进行捕获,TIM1进行PWM输出。TIM1没有输出。如果在主程序中先写TIM1在写TIM8,TIM1输出正常。如果在TIM8的配置中设置滤波为0x0;TIM1有输出。如果在TIM1中取消通道1的设置,TIM1有输出。如果在TIM1设置最后重新设置TIM1->CR2=0x0;TIM1有输出。以上情况都可以使TIM1有输出,调试过程中观察TIM1寄存器,TIM->CR2和TIM1->CRC会被意外改变。不能解释以上各种原因。
  1. #include "stm32f10x.h"
  2. void RCC_Configuration(void);
  3. void GPIO_Configuration(void);
  4. void TIM8_Configuration(void);
  5. void TIM1_Configuration(void);
  6. int main(void)
  7. {
  8.           RCC_Configuration();
  9.           GPIO_Configuration();
  10.           TIM8_Configuration();
  11.     TIM1_Configuration();
  12.           while(1);
  13. }
  14. void GPIO_Configuration()
  15. {
  16.   GPIO_InitTypeDef GPIO_InitStructure;
  17.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
  18.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  19.         GPIO_Init(GPIOC , &GPIO_InitStructure);
  20.         GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  22.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.         GPIO_Init(GPIOA , &GPIO_InitStructure);
  24. }
  25. void RCC_Configuration(void)
  26. {
  27.         ErrorStatus HSEStartUpStatus;
  28.           RCC_DeInit();
  29.           RCC_HSEConfig(RCC_HSE_ON);
  30.           HSEStartUpStatus = RCC_WaitForHSEStartUp();
  31.           if(HSEStartUpStatus == SUCCESS)
  32.           {
  33.             RCC_HCLKConfig(RCC_SYSCLK_Div1);
  34.             RCC_PCLK2Config(RCC_HCLK_Div1);
  35.             RCC_PCLK1Config(RCC_HCLK_Div2);
  36.                         RCC_ADCCLKConfig(RCC_PCLK2_Div6);
  37.             FLASH_SetLatency(FLASH_Latency_2);
  38.       FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  39.             RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  40.             RCC_PLLCmd(ENABLE);
  41.             while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  42.             RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  43.             while(RCC_GetSYSCLKSource() != 0x08);
  44.           }
  45.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA, ENABLE);
  46.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1|RCC_APB2Periph_TIM8, ENABLE);
  47. }
  48. void TIM8_Configuration(void)
  49. {
  50.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  51.         TIM_ICInitTypeDef  TIM_ICInitStructure;
  52.   TIM_TimeBaseStructure.TIM_Period = 65000;
  53.         TIM_TimeBaseStructure.TIM_Prescaler=1000-1;
  54.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  55.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  56.         TIM_TimeBaseInit(TIM8,&TIM_TimeBaseStructure);
  57.         TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising ;
  58.         TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  59.   TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  60.         TIM_ICInitStructure.TIM_ICFilter = 0xF;
  61.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  62.         TIM_ICInit(TIM8, &TIM_ICInitStructure);
  63.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  64.         TIM_ICInit(TIM8, &TIM_ICInitStructure);
  65.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_3;
  66.         TIM_ICInit(TIM8, &TIM_ICInitStructure);
  67.         TIM_ITConfig(TIM8, TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3,ENABLE);
  68.         TIM_Cmd(TIM1,ENABLE);
  69. }
  70. void TIM1_Configuration(void)
  71. {
  72.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  73.         TIM_OCInitTypeDef TIM_OCInitStructure;
  74.         TIM_TimeBaseStructure.TIM_Period = 90-1;
  75.         TIM_TimeBaseStructure.TIM_Prescaler=10000-1;
  76.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  77.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
  78.         TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
  79.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
  80.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  81.         TIM_OCInitStructure.TIM_OutputNState=TIM_OutputState_Disable;
  82.         TIM_OCInitStructure.TIM_Pulse=0;
  83.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  84.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);
  85.         TIM_OC2Init(TIM1,&TIM_OCInitStructure);
  86.         TIM_OC3Init(TIM1,&TIM_OCInitStructure);
  87.         TIM_OC4Init(TIM1,&TIM_OCInitStructure);
  88.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  89.         TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  90.         TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
  91.         TIM_SetCompare1(TIM1,10);
  92.         TIM_SetCompare2(TIM1,20);
  93.         TIM_SetCompare3(TIM1,30);
  94.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  95.         TIM_Cmd(TIM1,ENABLE);
  96.
  97. }
airwill 发表于 2015-1-25 18:33 | 显示全部楼层
TIM->CR2 是控制寄存器, 运行不应该改变的, 是不是你的程序的什么地方有问题, 错误地修改了这个寄存器, 你可以借助调试器的断点功能捕捉修改这个寄存器的地址的.
 楼主| 红绿灯不休息 发表于 2015-1-25 21:27 | 显示全部楼层
TIM->CR2 是控制寄存器, 运行不应该改变的, 是不是你的程序的什么地方有问题, 错误地修改了这个寄存器, 你 ...
刚才打断点看了,从92行开始CR2的值被改变了,直到102行都可以改变CR2的值。如果main函数中先调用TIM1,后调用TIM8,TIM1->CR2的值始终没有改变,如果去掉第66行,也不会改变TIM1->CR2的值。所以是不是很奇怪。
airwill 发表于 2015-1-25 23:59 | 显示全部楼层
我以为是运行中改变了呢, 原来是初始化中改变, 那是因为库函数的问题, 不奇怪的
所以初始化是要注意先后关系的, 看参考例程的顺序吧
 楼主| 红绿灯不休息 发表于 2015-1-26 19:12 | 显示全部楼层
所以初始化是要注意先后关 ...
可是初始化的程序里调用的库函数并没有对TIM1->CR2进行设置,为什么会被改变,而这种改变又似乎和另一条语句。
airwill 发表于 2015-1-26 21:07 | 显示全部楼层
嗯, 这个问题, 还是找调试器帮忙吧
跟踪到库函数内部, 看看怎么修改这些寄存器的, 看这些对用好库函数和 mcu 也有帮助.
 楼主| 红绿灯不休息 发表于 2015-1-27 20:59 | 显示全部楼层
嗯, 这个问题, 还是找调试器帮忙吧
跟踪到库函数内部, 看看怎么修改这些寄存器的, 看这些对用好库函数和 mc ...
找到原因是由于TIM1函数中定义的TIM_OCInitStructure结构体的初值不为零,被调用后影响了CR2中的最低位使得不能输出PWM波。
