为何程序中,两处用的数据类型为何不同?必须这么用吗?
769|1
 楼主| 狂奔的蜗牛哥 发表于 2015-3-15 14:15 | 显示全部楼层 |阅读模式
以下是2440 mmu的部分程序
*关开门狗
#define WTCON (*(volatile unsigned long *)0x53000000)
void dis_wtd(void)
        WTCON = 0;
*将前4K代码复制到SDRAM
#define mem_ctl_base 0x48000000
void memset(void)
        unsigned long const mem_cfg_val[] = {
        0x22011110,
        0x00000700,
        0x00000700,
        0x00000700,
        0x00000700,
        0x00000700,
        0x00000700,
        0x00018005,
        0x00018005,
        0x008c07a3,
        0x000000b1,
        0x00000030,
        0x00000030,
        unsigned char i;
        volatile unsigned long *p = (volatile unsigned long *)mem_ctl_base;
        for(i=0; i<13; i++)
                p = mem_cfg_val;
void copy_to_sdram(void)
        unsigned int *pdwsrc = (unsigned int *)2048;
        unsigned int *pdwdest = (unsigned int *)0x30004000;
        while(pdwsrc < (unsigned int *)4096)
                *pdwdest = *pdwsrc;
                pdwdest++;
                pdwsrc++;
我想问一下为何程序中,两处用的数据类型为何不同?必须这么用吗?
而后面的程序则是unsigned int *pdwsrc = (unsigned int *)2048;
我是新手,希望各位前辈能够指点一下,谢谢了!
 楼主| 狂奔的蜗牛哥 发表于 2015-3-15 14:19 | 显示全部楼层
