它山之石可以攻玉 https://bbs.21ic.com/?12980 [收藏] [复制] [RSS]
日志
LPC2XXX在UV3中,RV编译器,加密方法
已有 1654 次阅读2006-4-30 14:40 |个人分类:ARM应用|系统分类:ARM
;/* STARTUP.S: Startup file for Philips LPC2000                               */
;/* <<< Use Configuration Wizard in Context Menu >>>                          */
;/* This file is part of the uVision/ARM development tools.                   */
;/* Copyright (c) 2005-2006 Keil Software. All rights reserved.               */
;/* This software may only be used under the terms of a valid, current,       */
;/* end user licence from KEIL for a compatible version of KEIL software      */
;/* development tools. Nothing else gives you the right to use this software. */
; *  The STARTUP.S code is executed after CPU Reset. This file may be
; *  translated with the following SET symbols. In uVision these SET
; *  symbols are entered under Options - ASM - Set.
; *  REMAP: when set the startup code initializes the register MEMMAP
; *  which overwrites the settings of the CPU configuration pins. The
; *  startup and interrupt vectors are remapped from:
; *     0x00000000  default setting (not remapped)
; *     0x80000000  when EXTMEM_MODE is used
; *     0x40000000  when RAM_MODE is used
; *  EXTMEM_MODE: when set the device is configured for code execution
; *  from external memory starting at address 0x80000000.
; *  RAM_MODE: when set the device is configured for code execution
; *  from on-chip RAM starting at address 0x40000000.
; Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
Mode_USR        EQU     0x10
Mode_FIQ        EQU     0x11
Mode_IRQ        EQU     0x12
Mode_SVC        EQU     0x13
Mode_ABT        EQU     0x17
Mode_UND        EQU     0x1B
Mode_SYS        EQU     0x1F
I_Bit           EQU     0x80            ; when I bit is set, IRQ is disabled
F_Bit           EQU     0x40            ; when F bit is set, FIQ is disabled
;// <h> Stack Configuration (Stack Sizes in Bytes)
;//   <o0> Undefined Mode      <0x0-0xFFFFFFFF:8>
;//   <o1> Supervisor Mode     <0x0-0xFFFFFFFF:8>
;//   <o2> Abort Mode          <0x0-0xFFFFFFFF:8>
;//   <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:8>
;//   <o4> Interrupt Mode      <0x0-0xFFFFFFFF:8>
;//   <o5> User/System Mode    <0x0-0xFFFFFFFF:8>
;// </h>
UND_Stack_Size  EQU     0x00000000
SVC_Stack_Size  EQU     0x00000020
ABT_Stack_Size  EQU     0x00000000
FIQ_Stack_Size  EQU     0x00000000
IRQ_Stack_Size  EQU     0x00000040
USR_Stack_Size  EQU     0x00000050
Stack_Size      EQU     (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \
                         FIQ_Stack_Size + IRQ_Stack_Size + USR_Stack_Size)
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
Stack_Top       EQU     Stack_Mem + Stack_Size
;// <h> Heap Configuration
;//   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF>
;// </h>
Heap_Size       EQU     0x00000000
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
Heap_Mem        SPACE   Heap_Size
; VPBDIV definitions
VPBDIV          EQU     0xE01FC100      ; VPBDIV Address
;// <e> VPBDIV Setup
;// <i> Peripheral Bus Clock Rate
;//   <o1.0..1>   VPBDIV: VPB Clock
;//               <0=> VPB Clock = CPU Clock / 4
;//               <1=> VPB Clock = CPU Clock
;//               <2=> VPB Clock = CPU Clock / 2
;//   <o1.4..5>   XCLKDIV: XCLK Pin
;//               <0=> XCLK Pin = CPU Clock / 4
;//               <1=> XCLK Pin = CPU Clock
;//               <2=> XCLK Pin = CPU Clock / 2
;// </e>
VPBDIV_SETUP    EQU     1
VPBDIV_Val      EQU     0x00000000
; Phase Locked Loop (PLL) definitions
PLL_BASE        EQU     0xE01FC080      ; PLL Base Address
PLLCON_OFS      EQU     0x00            ; PLL Control Offset
PLLCFG_OFS      EQU     0x04            ; PLL Configuration Offset
PLLSTAT_OFS     EQU     0x08            ; PLL Status Offset
PLLFEED_OFS     EQU     0x0C            ; PLL Feed Offset
PLLCON_PLLE     EQU     (1<<0)          ; PLL Enable
PLLCON_PLLC     EQU     (1<<1)          ; PLL Connect
PLLCFG_MSEL     EQU     (0x1F<<0)       ; PLL Multiplier
PLLCFG_PSEL     EQU     (0x03<<5)       ; PLL Divider
PLLSTAT_PLOCK   EQU     (1<<10)         ; PLL Lock Status
;// <e> PLL Setup
;//   <o1.0..4>   MSEL: PLL Multiplier Selection
;//               <1-32><#-1>
;//               <i> M Value
;//   <o1.5..6>   PSEL: PLL Divider Selection
;//               <0=> 1   <1=> 2   <2=> 4   <3=> 8
;//               <i> P Value
;// </e>
PLL_SETUP       EQU     1
PLLCFG_Val      EQU     0x00000043
; Memory Accelerator Module (MAM) definitions
MAM_BASE        EQU     0xE01FC000      ; MAM Base Address
MAMCR_OFS       EQU     0x00            ; MAM Control Offset
MAMTIM_OFS      EQU     0x04            ; MAM Timing Offset
;// <e> MAM Setup
;//   <o1.0..1>   MAM Control
;//               <0=> Disabled
;//               <1=> Partially Enabled
;//               <2=> Fully Enabled
;//               <i> Mode
;//   <o2.0..2>   MAM Timing
;//               <0=> Reserved  <1=> 1   <2=> 2   <3=> 3
;//               <4=> 4         <5=> 5   <6=> 6   <7=> 7
;//               <i> Fetch Cycles
;// </e>
MAM_SETUP       EQU     1
MAMCR_Val       EQU     0x00000002
MAMTIM_Val      EQU     0x00000004
; External Memory Controller (EMC) definitions
EMC_BASE        EQU     0xFFE00000      ; EMC Base Address
BCFG0_OFS       EQU     0x00            ; BCFG0 Offset
BCFG1_OFS       EQU     0x04            ; BCFG1 Offset
BCFG2_OFS       EQU     0x08            ; BCFG2 Offset
BCFG3_OFS       EQU     0x0C            ; BCFG3 Offset
;// <e> External Memory Controller (EMC)
EMC_SETUP       EQU     0
;//   <e> Bank Configuration 0 (BCFG0)
;//     <o1.0..3>   IDCY: Idle Cycles <0-15>
;//     <o1.5..9>   WST1: Wait States 1 <0-31>
;//     <o1.11..15> WST2: Wait States 2 <0-31>
;//     <o1.10>     RBLE: Read Byte Lane Enable
;//     <o1.26>     WP: Write Protect
;//     <o1.27>     BM: Burst ROM
;//     <o1.28..29> MW: Memory Width  <0=>  8-bit  <1=> 16-bit
;//                                   <2=> 32-bit  <3=> Reserved
;//   </e>
BCFG0_SETUP EQU         0
BCFG0_Val   EQU         0x0000FBEF
;//   <e> Bank Configuration 1 (BCFG1)
;//   </e>
BCFG1_SETUP EQU         0
BCFG1_Val   EQU         0x0000FBEF
;//   <e> Bank Configuration 2 (BCFG2)
;//   </e>
BCFG2_SETUP EQU         0
BCFG2_Val   EQU         0x0000FBEF
;//   <e> Bank Configuration 3 (BCFG3)
;//   </e>
BCFG3_SETUP EQU         0
BCFG3_Val   EQU         0x0000FBEF
;// </e> End of EMC
;// <e> 生成加密代码
EN_CRP       EQU     1
;// </e> 生成加密代码
; External Memory Pins definitions
PINSEL2         EQU     0xE002C014      ; PINSEL2 Address
PINSEL2_Val     EQU     0x0E6149E4      ; CS0..3, OE, WE, BLS0..3,
                                        ; D0..31, A2..23, JTAG Pins
; Area Definition and Entry Point
;  Startup Code must be linked first at Address at which it expects to run.
                AREA    RESET, CODE, READONLY
                ARM
; Exception Vectors
;  Mapped to Address 0.
;  Absolute addressing mode must be used.
;  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors         LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            ; Reserved Vector
;               LDR     PC, IRQ_Addr
                LDR     PC, [PC, #-0x0FF0]     ; Vector from VicVectAddr
                LDR     PC, FIQ_Addr
Reset_Addr      DCD     Reset_Handler
Undef_Addr      DCD     Undef_Handler
SWI_Addr        DCD     SWI_Handler
PAbt_Addr       DCD     PAbt_Handler
DAbt_Addr       DCD     DAbt_Handler
                DCD     0                      ; Reserved Address
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
                IMPORT  SWI_Handler
Undef_Handler   B       Undef_Handler
;SWI_Handler    B       SWI_Handler            ; Part of RTL
PAbt_Handler    B       PAbt_Handler
DAbt_Handler    B       DAbt_Handler
IRQ_Handler     B       IRQ_Handler
FIQ_Handler     B       FIQ_Handler
; Reset Handler
                EXPORT  Reset_Handler
Reset_Handler
; Setup External Memory Pins
                IF      :DEF:EXTERNAL_MODE
                LDR     R0, =PINSEL2
                LDR     R1, =PINSEL2_Val
                STR     R1, [R0]
                ENDIF
; Setup External Memory Controller
                IF      EMC_SETUP <> 0
                LDR     R0, =EMC_BASE
                IF      BCFG0_SETUP <> 0
                LDR     R1, =BCFG0_Val
                STR     R1, [R0, #BCFG0_OFS]
                ENDIF
                IF      BCFG1_SETUP <> 0
                LDR     R1, =BCFG1_Val
                STR     R1, [R0, #BCFG1_OFS]
                ENDIF
                IF      BCFG2_SETUP <> 0
                LDR     R1, =BCFG2_Val
                STR     R1, [R0, #BCFG2_OFS]
                ENDIF
                IF      BCFG3_SETUP <> 0
                LDR     R1, =BCFG3_Val
                STR     R1, [R0, #BCFG3_OFS]
                ENDIF
                ENDIF   ; EMC_SETUP
; Setup VPBDIV
                IF      VPBDIV_SETUP <> 0
                LDR     R0, =VPBDIV
                LDR     R1, =VPBDIV_Val
                STR     R1, [R0]
                ENDIF
; Setup PLL
                IF      PLL_SETUP <> 0
                LDR     R0, =PLL_BASE
                MOV     R1, #0xAA
                MOV     R2, #0x55
;  Configure and Enable PLL
                MOV     R3, #PLLCFG_Val
                STR     R3, [R0, #PLLCFG_OFS]
                MOV     R3, #PLLCON_PLLE
                STR     R3, [R0, #PLLCON_OFS]
                STR     R1, [R0, #PLLFEED_OFS]
                STR     R2, [R0, #PLLFEED_OFS]
;  Wait until PLL Locked
PLL_Loop        LDR     R3, [R0, #PLLSTAT_OFS]
                ANDS    R3, R3, #PLLSTAT_PLOCK
                BEQ     PLL_Loop
;  Switch to PLL Clock
                MOV     R3, #(PLLCON_PLLE:OR:PLLCON_PLLC)
                ENDIF   ; PLL_SETUP
; Setup MAM
                IF      MAM_SETUP <> 0
                LDR     R0, =MAM_BASE
                MOV     R1, #MAMTIM_Val
                STR     R1, [R0, #MAMTIM_OFS]
                MOV     R1, #MAMCR_Val
                STR     R1, [R0, #MAMCR_OFS]
                ENDIF   ; MAM_SETUP
; Memory Mapping (when Interrupt Vectors are in RAM)
MEMMAP          EQU     0xE01FC040      ; Memory Mapping Control
                IF      :DEF:REMAP
                LDR     R0, =MEMMAP
                IF      :DEF:EXTMEM_MODE
                MOV     R1, #3
                ELIF    :DEF:RAM_MODE
                MOV     R1, #2
                ELSE
                MOV     R1, #1
                ENDIF
                STR     R1, [R0]
                ENDIF
; Initialise Interrupt System
; Setup Stack for each mode
                LDR     R0, =Stack_Top
;  Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
;  Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
;  Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
;  Enter IRQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
;  Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
;  Enter User Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_USR
                MOV     SP, R0
                SUB     SL, SP, #USR_Stack_Size
;当EN_CRP等于1时,生成加密代码,否则,不生成加密代码
    IF      EN_CRP <> 0
        IF .> 0x1fc
            INFO 1,"\nThe data at 0x000001fc must 0x87654321.\Please delete some source before this line!"
        ENDIF
CrpData
        WHILE . < 0x1fc
            NOP
        WEND
CrpData1
                   DCD      0x87654321
    ENDIF
; Enter the C code
                IMPORT  __main
                LDR     R0, =__main
                BX      R0
; User Initial Stack & Heap
                AREA    |.text|, CODE, READONLY
                IMPORT  __use_two_region_memory
                EXPORT  __user_initial_stackheap
                LDR     R0, =  Heap_Mem
                LDR     R1, =(Stack_Mem + USR_Stack_Size)
                LDR     R2, = (Heap_Mem +      Heap_Size)
                LDR     R3, = Stack_Mem
                BX      LR
                END
注:本STARTUP.S是在ATRX上用的,如果不用内核,参照修改一下即可。
选中,生成的程序即是加密的,不选中,生成的程序即是不加密的。
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
