qq7643066的个人空间 https://bbs.21ic.com/?1354292 [收藏] [复制] [RSS]
日志
RK3288 增加双屏异显 eDP+LVDS
热度 1已有 4223 次阅读2020-2-16 20:20 |系统分类:嵌入式系统| RK3288开发板
CPURK3288
系统:Android 5.1
下面是官方文档中的信息。
1rk3288 支持的显示接口可以任意组合。
2、双屏异显时,一个显示接口当主屏,另一个当副屏;主副屏由板级 dts 文件确定,启动后无法动态更改。
3、当两路显示接口显示不同分辨率时,rk3288 只能为一路显示接口提供精确时钟,另一路显示接口时钟会有微小频偏。
瑞芯微虽然提供了 Android 5.1 的补丁,但是本人在移植过程中出现一些问题(打补丁最好一行行核对,不要图方便直接使用指令)。
设备 eDP 为主屏,lvds 为副屏。
1)首先修改两个屏参文件 lcd-xxx.dtsi
eDP 屏参文件补丁
diff --git
a/kernel/arch/arm/boot/dts/lcd-NV116FH1.dtsi
b/kernel/arch/arm/boot/dts/lcd-NV116FH1.dtsi
index
3862b05..7bf992f
100755
--- a/kernel/arch/arm/boot/dts/lcd-NV116FH1.dtsi
@@ -3,11 +3,9 @@
-        disp_timings: display-timings {
-                        native-mode =
<&timing0>;
-                        timing0: timing0 {
+        display-timings {
+                        native-mode =
<&nv116fhm>;
+                        nv116fhm: timing0 {
                 screen-type =
<SCREEN_EDP>;
                 out-face    = <OUT_P666>;
                 clock-frequency = <205000000>;
@@ -30,4 +30,3 @@
                swap-gb = <0>;
lvds 屏参文件补丁
diff --git
a/kernel/arch/arm/boot/dts/lcd-ZJ080NA-08A.dtsi
b/kernel/arch/arm/boot/dts/lcd-ZJ080NA-08A.dtsi
old mode 100644
new mode 100755
index
fc6385c..58f999be
@@ -3,11 +3,10 @@
-                        native-mode =
<&timing0>;
+        display-timings {
+                        native-mode =
<&zj080na>;
+                        zj080na: timing0 {
                 screen-type =
<SCREEN_DUAL_LVDS>;
                 lvds-format =
<LVDS_8BIT_1>;
                 out-face    = <OUT_P888>;
@@ -30,4 +30,3 @@
                swap-gb = <0>;
2)根据官方提供,打上 kernel 补丁
https://images.cnblogs.com/OutliningIndicators/ContractedBlock.gif
 kernel 补丁
3)根据官方提供,打上 hardware 补丁
 hardware 补丁
4)根据官方提供,打上 framework 补丁
 framework 补丁
5)官方提供的补丁打完了,但是此时编译可能会报错,如下:
cts/tests/tests/view/src/android/view/cts/WindowTest.java:846: error: WindowTest.MockWindow is not abstract and does not override abstract method
moveExtendDisplay()
in Window
public class MockWindow
extends Window {
Note: Some input
files use or
override a deprecated API.
Note: Recompile
with -Xlint:deprecation
for details.
1 error
make: *** [out/target/common/obj/APPS/CtsViewTestCases_intermediates/classes-full-debug.jar]
Error
41
make: *** Waiting for unfinished jobs....
Note: Some input
files use or
Note: Recompile
for details.
Note: Some input
files use
unchecked or unsafe operations.
Note: Recompile
with -Xlint:
unchecked for details.
Note: Some input
files use or
Note: Recompile
for details.
Note: Some input
files use
Note: Recompile
with -Xlint:
Warning:
AndroidManifest.xml already defines minSdkVersion (
in http://schemas.android.com/apk/res/android);
using existing value in manifest.
Warning:
AndroidManifest.xml already defines targetSdkVersion (
#### make failed
to build some targets (
03:55 (mm:ss)) ####
根据编译错误提示,需要修改
文件。
diff --git
a/cts/tests/tests/view/src/android/view/cts/WindowTest.java
b/cts/tests/tests/view/src/android/view/cts/WindowTest.java
index
3c5386d..8732ae7
100755
@@ -998,6 +998,19 @@ public class WindowTest
extends ActivityInstrumentationTestCase2<WindowCtsActivi
         @Override
+        public void moveAppToDisplay(int id) {
+        @Override
+        public void syncDualDisplay()
+        @Override
+        public void
moveExtendDisplay() {
+        @Override
         public void
setDefaultWindowFormat(
int format) {
super.setDefaultWindowFormat(format);
6)此时可以编译成功,在屏参正确的前提下,主屏显示正常,副屏出现花屏,需要在 system.prop
里添加属性 ro.htg.force=1
diff --git
a/device/rockchip/rk3288/system.prop b/device/rockchip/rk3288/system.prop
index
26a2b09..c4f2c3d
100755
@@ -12,6 +12,7 @@
rild.libpath=/system/lib/libril-rk29-dataonly.so
 rild.libargs=-d /dev/ttyACM0
 persist.tegra.nvmmlite = 1
 ro.audio.monitorOrientation=true
+ro.htg.force=1
 #NFC
 debug.nfc.fw_download=false
此时大功告成,双屏可以正常显示,也可以实现双屏异显。
如果 lcd 出现重复性黑屏亮屏,找到对应的屏参文件,在正常范围内调节频率 clk 值即可。
display-timings {
                        native-mode =
<&ee101ia>;
                        ee101ia: timing0 {
                screen-type =
<SCREEN_DUAL_LVDS>;
                lvds-format =
<LVDS_8BIT_1>;
                color-mode = <COLOR_RGB>;
                // 调节 lcd 频率
                clock-frequency = <148500000>;
                hactive = <1920>;
                vactive = <1080>;
如果单屏调试都正常点亮,打补丁后,点不亮或者有花屏现象,尝试增大对应屏的电源使能延时
 lcd_en {
    rockchip,power_type = <GPIO>;
    gpios = <&gpio7 GPIO_A5
GPIO_ACTIVE_HIGH>;
-   rockchip,delay = <10>;
+   rockchip,delay = <100>;
路过
鸡蛋
鲜花
握手
雷人
发表评论 评论 (2 个评论)
回复 幽魂 2020-2-18 19:53
需要开发app支持吧
回复 幽魂 2020-2-26 20:58
请问下 RK3288怎么改成MIPI+LVDS双屏异显
