onway笔记 https://bbs.21ic.com/?197419 [收藏] [复制] [RSS] 自己平时积累的一些资料,作为备份存在这里,也希望能够分享给大家
日志
DC notch filter
已有 1601 次阅读2010-1-8 17:15 |系统分类:DSP| matlab, DC, notch, filter
13.23. DC REMOVAL
When we digitize analog signals using an analog-to-digital
(A/D) converter, the converter's output typically contains some small DC bias: that is, the
average of the digitized time samples is not zero. That DC bias may have come
from the original analog signal or from imperfections within the A/D converter.
Another source of DC bias contamination in DSP is when we truncate a discrete
sequence from a B-bit representation to word
widths less than B bits. Whatever the source,
unwanted DC bias on
a signal can cause problems. When we're performing spectrum analysis, any DC bias on the signal
shows up in the frequency domain as energy at zero Hz, the X(0) spectral sample. For an N-point FFT the X(0)
spectral value is proportional to N and becomes
inconveniently large for large-sized FFTs. When we plot our spectral magnitudes,
the plotting software will accommodate any large X(0) value and squash down the remainder of the
spectrum in which we are more interested.
A non-zero DC bias level in audio signals is particularly troublesome
because concatenating two audio signals, or switching between two audio signals,
results in unpleasant audible clicks. In modern digital communications systems,
a DC bias on
quadrature signals degrades system performance and increases bit error rates.
With that said, it's clear that methods for DC removal are of
interest to many DSP practitioners.
13.23.1 Block-Data DC Removal
If you're processing in non-real-time, and the signal data is
acquired in blocks (fixed-length sequences) of block length N, DC removal is straightforward. We merely compute the
average of our N time samples, and subtract that
average value from each original sample to yield a new time sequence whose DC bias will be extremely
small.
This scheme, although very effective, is not compatible with
continuous-throughput (real-time) systems. For real-time systems we're forced to
use filters for DC
removal.
13.23.2 Real-Time DC Removal
The author has encountered three proposed filters for DC removal[5557]; their
structures are shown in Figure 13-62(a),
(b), and (c).
Figure 13-62. Filters used for DC bias removal.
Ignoring the constant gains of those DC-removal filters, all
three filters have identical performance with the general DC-removal filter structure in Figure 13-62(d) having a z-domain transfer  of
(It's not immediately obvious that the filters in Figure 13-62(c) and (d) are equivalent. You can verify that equivalency by
writing the time-domain difference equations relating the various nodes in the
feedback path of Figure 13-62(c)'s
filter. Next, convert those equations to z-transform expressions and solve for Y(z)/X(z) to yield Eq.
(13-118)
Because the DC-removal filters can be modeled with the general DC-removal filter in Figure 13-62(d), we provide the general
filter's frequency magnitude and phase responses in Figure 13-63(a) and (b) for a = 0.95. The filter's
pole/zero locations are given in Figure
13-63(c)
, where a zero resides at z = 1
providing infinite attenuation at DC (zero Hz) and a pole at z
= a making the magnitude notch at DC very sharp. The closer
a is to unity, the narrower the frequency
magnitude notch
centered at zero Hz. Figure 13-63(d)
shows the general filter's unit-sample impulse response.
Figure 13-63. DC-removal filter, a = 0.95: (a)
magnitude response; (b) phase response; (c) pole/zero locations; (d) impulse
response.
Figure 13-64 shows the
time-domain input/output performance of the general DC-removal filter (with
a = 0.95) when its input is a sinusoid suddenly
contaminated with a DC bias of 2 beginning at the 100th time sample and
disappearing at the 200th sample. The DC-removal filter works well.
Figure 13-64. DC-removal filter performance: (a) filter input with sudden
DC bias; (b) filter
output.
13.23.3 Real-Time DC Removal with
Quantization
Because the general DC-removal filter has feedback the y(n) output samples may
require wider binary word widths than those used for the x(n) input samples. This
could result in overflows in fixed-point binary implementations. The scaling
factors of (1+a)/2 and K, in Figure
13-62(a)
and (b), are less than one
to minimize the chance of y(n) binary overflow.
In fixed-point hardware the y(n) samples are often
truncated to the same word width as the input x(n). This quantization
(by means of truncation) will induce a negative DC bias onto the
quantized output samples, degrading our desired DC removal. When we
truncate a binary sample value, by discarding some of its least significant
bits, we induce a negative error in the truncated sample. Fortunately, that
error value is available for us to add to the next unquantized signal sample,
increasing its positive DC bias. When that next sample is truncated, the positive
error we've added minimizes the negative error induced by truncation of the next
sample.
Figure 13-65(a) shows
the addition of a quantizing sigma-delta modulator to the feedback path of the
DC-removal filter
given in Figure 13-62(c). The positive
error induced by truncation quantization (the Q block) is delayed by one sample
time and fed back to the quantizer input. Because the modulator has a noise shaping property where quantization error noise
is shifted up in frequency, away from zero Hz (DC), the overall DC bias at the output of
the filter is minimized[56].
Figure 13-65. Two DC-removal filters using
fixed-point quantization to avoid data overflow.
An equivalent quantization noise shaping process can be applied
to a Direct Form I version of the Figure
13-62(d)
general DC-removal filter as shown in Figure 13-65(b). Again, the positive quantization error is
delayed by one sample time and added to the quantizer input[5860]. To reiterate, the DC-removal filters in Figure 13-65 are used to avoid binary data
overflow, by means of quantization, without the use of scaling multipliers.
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
