leastbad的笔记 https://bbs.21ic.com/?244348 [收藏] [复制] [RSS]
日志
跑马灯
已有 632 次阅读2010-10-26 12:06 |系统分类:EDA/PLD
module example1(clk,rst_n,led);
 input clk;
 input rst_n;
 //输出信号
 output[7:0] led;
 reg[7:0]    led;
 //计数器
 reg[24:0] count1;
 reg[2:0]  count2;
 //倍频
 reg  clk_temp;
 //Creat a new clk 1Hz
 always@(posedge clk or posedge rst_n)
 begin
  if(rst_n)
   count1 <= 'd0;
  else
   if(count1 >= 'd50000000)
    count1 <= 'd0;
   else
    count1 <= count1 + 'd1;
 end
 begin
  if(rst_n)
   clk_temp <= 'b0;
  else
   clk_temp <= (count1 >= 'd25000000)?'b1:'b0;
 end
 //LED
 /*always@(posedge clk_temp or posedge rst_n)
 begin
  if(rst_n)
   led[7:0] <= 'd0;
  else
   led[7:0] <= led[7:0] + 'd1;
 end*/
 begin
  if(rst_n)
   count2 <= 'd0;
  else
   count2 <= count2 + 'd1;
 end
 always@(count2 or rst_n)
 begin
  if(rst_n)
   led <= 8'b00000000;
  else
   case(count2)
    3'b000  :  led <= 8'b00000001;
    3'b001  :  led <= 8'b00000010;
    3'b010  :  led <= 8'b00000100;
    3'b011  :  led <= 8'b00001000;
    3'b100  :  led <= 8'b00010000;
    3'b101  :  led <= 8'b00100000;
    3'b110  :  led <= 8'b01000000;
    3'b111  :  led <= 8'b10000000;
   endcase
 end*/
 begin
  if(rst_n)
   led <= 8'b00000000;
  else
   if(led == 8'b00000000)
    led <= 8'b00000001;
   else
    begin
    led[7:0] <= {led[6:0],led[7]};
    end
 end
endmodule
一个是case方式, 一个是移位方式。
这个简单的代码花了好长时间,也不知道怎么突然就OK了,这个教训告诉我,以前错误的代码有时候是需要保存的,可以前后对比分析,找出自己错误的原因。
路过
鸡蛋
鲜花
握手
雷人
全部作者的其他最新日志
评论 (0 个评论)
