HDMI-to-eDP Converter w/ scaler
1 Features
Embedded-DisplayPort (eDP) Output 1/2/4-lane eDP @ 1.62/2.7Gbps per lane HD to WQXGA (2560*1600) supported Up to 6dB pre-emphasis
HDMI Input
HDMI 1.4a supported RGB444/YCbCr444/YCbCr422 supported Pixel clock up to 340MHz 2-channel audio supported Support Hot-Plug Detect Adaptive equalization
Reference Clock
Any freq. between 19MHz and 100MHz Crystal or single-ended clock input Built-in 5000ppm SSC generator
Misc
I2C for chip configuration Built-in eDP handshake protocol I2C-AUX channel for TCON/DPCD/EDID control Built-in video test pattern
Power
1.2V core supply 2.5V or 3.3V IO supply Power consumption ~ 150mW @ 2560*1600*24bit*60Hz Deep-sleep mode power <1mW
Package
QFN-56 (7mm x 7mm) package RoHS Compliant Sample available now
2 Block Diagram
3 General Description
NCS8803 is a low-power HDMI-to-DisplayPort/eDP converter with advanced scaling function, fractional scaling ratio from 2:1 to 1:2, which is designed for mobile devices including tablets, laptops, monitor, etc. to support high-definition DP/eDP displays.
NCS8803 supports 4-lane DP/eDP output which is typically required to support WQXGA (2560*1600) and above at 60Hz frame rate.
Thanks to our proprietary scaling algorithm, NCS8803 provides high picture quality. All the functions pack into a small 7mm*7mmQFN56 package which saves the precious space in mobile devices.
4 Pin Diagram
(Top View)
5 Pin Description
