//max7219 led drive program
//for 51 mcu
//designed by zhaoliang
//2005-6-12 13:52
#i nclude<reg51.h>
//common part
#define HIGH 1
#define LOW 0
#define TRUE 1
#define FALSE 0
#define ZERO 0
#define MSB 0x80
#define LSB 0x01
//max7219 part
#define DECODE_MODE 0x09
#define INTENSITY 0x0A
#define SCAN_LIMIT 0x0B
#define SHUT_DOWN 0x0C
#define DISPLAY_TEST 0x0F
//pin defined
//change this part at different board
sbit LOAD=P1^2; //MAX7219 Load-Data Input: rising edge pin 12
sbit DIN=P1^1; //MAX7219 Serial-Data Input: rising edge pin 1
sbit CLK=P1^0; //MAX7219 Serial-Clock Input: maximum 10MHz pin 13
//function define
void Write_Max7219_byte(unsigned char temp);//write max7219 a byte
void Write_Max7219(unsigned char address,unsigned char dat);//write max7219 command and data
void Init_Max7219(void);//Initize max7219
//test program display from 1~8
void main(void)
unsigned char i;
Init_Max7219();
while(TRUE)
for(i=1;i<9;i++)
Write_Max7219(i,i);
unsigned char i;
for (i=0;i<8;i++)
CLK=LOW;
DIN=(bit)(temp&MSB);
temp<<=1;
CLK=HIGH;
LOAD=LOW;
Write_Max7219_byte(address);
Write_Max7219_byte(dat);
LOAD=HIGH;
Write_Max7219(SHUT_DOWN, 0x01); //Normal Operation XXXXXXX1 Shutdown Mode XXXXXXXX0
Write_Max7219(DISPLAY_TEST, 0x00); //Normal Operation XXXXXXX0 Display Test Mode XXXXXXXX1
Write_Max7219(DECODE_MODE, 0xff); //Decode Mode Select D7~D0 1 B decode 0 No decode
Write_Max7219(SCAN_LIMIT, 0x07); //SCAN LIMIT 0~7 0xX0~0xX7
Write_Max7219(INTENSITY, 0x04); //Set Intensity 0xX0~0xXf
