ysf213的笔记 https://bbs.21ic.com/?334019 [收藏] [复制] [RSS]
日志
求助,对NIOS的programmer的问题
已有 1144 次阅读2010-8-22 15:37 |系统分类:EDA/PLD| NIOS, SOPC, Programmer
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00003800 --cable='B
yteBlasterII [LPT1]'  "epcs_flash_controller.flash"
There is a problem with the JTAG chain you have chosen, or something else
on this computer is not working correctly.  Please check the power and
connections to the target system or use `jtagconfig` for further diagnosis.
在quartus中能够下载成功,在NIOS中能够仿真成功,可是Programmer时出现这个错误,不知道是什么原因,请高手指点
问题终于解决了,在烧写nios程序,先要把quartus烧写进去,然后再烧写nios,
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
