重剑无锋 https://bbs.21ic.com/?425187 [收藏] [复制] [RSS]
日志
TM1637(STM32确定能用的程序)
已有 551 次阅读2018-4-14 16:57 |个人分类:STM32|系统分类:嵌入式系统
实在是忍不住,网上那么多的STM32的程序,用到板上都有异常:显示的值最高位必须为1!!!
在不断推敲下,终于解决这个问题,问题出在引脚方向的切换时机不对。导致误停止信号。。网上说的这个芯片ACK回应有bug,实际芯片无bug,就是程序这处不对导致。
程序如下:
File Name                        :TM1637.C
New Date                          :2017-8-17
Author                                  :WangXinJia
Hardware                        :PW-A-V10
Comments                          :
/* Includes ------------------------------------------------------------------*/
//#include         "HardWare.h"
#include         "stm32f10x.h"
#include         "Basic.H"
#include        "TM1637.H"
#include         "API.H"
#include        "OP_Display.H"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define SCL_GPIO                GPIOB
#define SCL_CLK         RCC_APB2Periph_GPIOB
#define SCL_PIN         GPIO_Pin_8
#define SDA_GPIO                GPIOB
#define SDA_CLK               RCC_APB2Periph_GPIOB
#define SDA_PIN                GPIO_Pin_9
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void TM1637Init (void)
        RCC_APB2PeriphClockCmd(SCL_CLK, ENABLE);
          GPIO_InitStructure.GPIO_Pin = SCL_PIN;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
          GPIO_Init(SCL_GPIO, &GPIO_InitStructure);
//          GPIO_ResetBits(SCL_GPIO, SCL_PIN);
        GPIO_SetBits(SCL_GPIO, SCL_PIN);
        RCC_APB2PeriphClockCmd(SDA_CLK, ENABLE);
          GPIO_InitStructure.GPIO_Pin = SDA_PIN;
          GPIO_Init(SDA_GPIO, &GPIO_InitStructure);
          GPIO_SetBits(SDA_GPIO, SDA_PIN);
//SDA DIO        PB9
#define SDA_IN()     {GPIOB->CRH&=0xFFFFFF0F;GPIOB->CRH|=(8<<4);}//8/4
#define SDA_OUT()    {GPIOB->CRH&=0xFFFFFF0F;GPIOB->CRH|=(3<<4);}
void TM1637_Start(void)
        SDA_OUT();
        Delay32(20);
        GPIO_ResetBits(SDA_GPIO, SDA_PIN);
void TM1637_Ack(void)
        INT16U i=0;
        SDA_IN();
        Delay32(50);//
        Delay32(50);
        while(GPIO_ReadInputDataBit(SDA_GPIO, SDA_PIN)){
                i++;
                if(i>300){
                        break;
        Delay32(20);
void TM1637_Stop(void)
        SDA_OUT();
        Delay32(20);
        Delay32(20);
        Delay32(20);
//        GPIO_SetBits(SDA_GPIO, SDA_PIN);
void TM1637_WriteByte(unsigned char oneByte)
        unsigned char i;
        SDA_OUT();
        for(i=0;i<8;i++){
                if(oneByte&0x01){
                }else{
                Delay32(30);
                oneByte=oneByte>>1;
                Delay32(30);
INT8U TM1637_ScanKey(void)
        unsigned char reKey,i;
        TM1637_Start();
        TM1637_WriteByte(0x42);
        TM1637_Ack();
        SDA_IN();
        for(i=0;i<8;i++){
                reKey=reKey>>1;
                Delay32(30);
                if(GPIO_ReadInputDataBit(SDA_GPIO, SDA_PIN)){
                  reKey=reKey|0x80;
                }else{
                  reKey=reKey|0x00;
                Delay32(30);
        TM1637_Ack();
        TM1637_Stop();
        switch (reKey){
                case 255:
                        return(0x00);
                case 247:
                        return(0x01);
                case 246:
                        return(0x02);
                case 245:
                        return(0x04);
                case 239:
                        return(0x08);
                case 238:
                        return(0x10);
                case 237:
                        return(0x20);
                default:
                        return(0x00);
void TM1637_SegDisplay(void)
        unsigned char i;
        TM1637_Start();
        TM1637_WriteByte(0x40);//0x40µØÖ·¼Ó1ģʽ
        TM1637_Ack();
        TM1637_Stop();
        TM1637_Start();
        TM1637_WriteByte(0xC0);//ÉèÊ×µØÖ·
        TM1637_Ack();
        for(i=0;i<6;i++){
                TM1637_WriteByte(SegData[i]);
                TM1637_Ack();
        TM1637_Stop();
        TM1637_Start();
        TM1637_WriteByte(0x8F);//×î´óÁÁ¶È0x88~0x8F
        TM1637_Ack();
        TM1637_Stop();
/******** (C) COPYRIGHT 2017 LongChang Electronics CO.,ltd *****END OF FILE****/
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
