tao180539的个人空间 https://bbs.21ic.com/?589097 [收藏] [复制] [RSS]
日志
ADXL345
已有 542 次阅读2022-1-29 09:43 |系统分类:兴趣爱好
#include <stm32f10x.h>
#include <stdbool.h>
#include "IIC.h"
#include "math.h"
#include "usart1.h"
//STM32F103RCT6
  * @file    bsp_i2c_ad.c
  * @author  STMicroelectronics
//int16_t ADXL345_rxdata[3];
ADXL345_DATA  new_adxl345_data;
Recent_Measure_Angle  recent_adxl345_data;
  * @brief  I2C1 I/O配置
  * @param  无
  * @retval 无
 void I2C_GPIO_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
        /* 使能与 I2C1 有关的时钟 */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
  ///* PB6-I2C1_SCL、PB7-I2C1_SDA*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;               // 开漏输出
  GPIO_Init(GPIOB, &GPIO_InitStructure);
uint8_t reset_no;
void reset_iic_init()
        I2C_DeInit(I2C1);//RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,DISABLE);
        __nop();
        __nop();
        __nop();
        __nop();
  I2C_GPIO_Config();
  I2C_Mode_Configu();
        __nop();
        __nop();
        __nop();
        __nop();
        reset_no++;
  * @brief  I2C 工作模式配置
  * @param  无
  * @retval 无
 void I2C_Mode_Configu(void)
  I2C_InitTypeDef  I2C_InitStructure;
   I2C_GPIO_Config();
        /* 通信速率 */
  I2C_InitStructure.I2C_ClockSpeed = 10000;
  /* I2C 配置 */
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        /* 高电平数据稳定,低电平数据变化 SCL 时钟线的占空比 */
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 =0;   //从模式下单片机IIC自己的地址
  I2C_InitStructure.I2C_Ack = I2C_Ack_Enable ;
        /* I2C的寻址模式 */
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        /* I2C1 初始化 */
  I2C_Init(I2C1, &I2C_InitStructure);
        /* 使能 I2C1 */
  I2C_Cmd(I2C1, ENABLE);
#define        SLAVE_ADXL345_ADDRESS   (0x53<<1)          //定义器件在IIC总线中的从地址,根据ALT  ADDRESS地址引脚不同修改
uint8_t Write_ADXL345(uint8_t Slave_Addr,uint8_t REG_Address,uint8_t data)
    //ADXL345_Start();                  //起始信号
    uint32_t i=0;
          I2C_GenerateSTART(I2C1, ENABLE);
    while (I2C_GetFlagStatus(I2C1,I2C_FLAG_SB)==0)//读取SR1
                               if(i++>10000)
                                                          return 0 ;
                                      __nop();
                                                  __nop();
    I2C_Send7bitAddress(I2C1, Slave_Addr , I2C_Direction_Transmitter);
    i=0;
     i=0;
                while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))//
                                                if(i++>10000)
                                                        return 0 ;
                                    __nop();
                                                __nop();
          //ADXL345_SendByte(REG_Address);    //内部寄存器地址,请参考中文pdf22页
    I2C_SendData(I2C1, REG_Address);
          i=0;
                while((I2C_GetFlagStatus(I2C1,I2C_FLAG_TXE)==0))
                                   if(i++>10000)
             return 0;
                                    __nop();
                                                __nop();
          //ADXL345_SendByte(REG_data);       //内部寄存器数据,请参考中文pdf22页
    I2C_SendData(I2C1, data);
          i=0;
                                   if(i++>10000)
             return 0;
                                    __nop();
                                                __nop();
          //ADXL345_Stop();                   //发送停止信号
    I2C_GenerateSTOP(I2C1, ENABLE);
    return 1;
bool Single_Read_ADXL345(uint8_t REG_Address ,uint8_t *data)
{  //uint8_t REG_data;
        uint32_t i=0;
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY))
                                        if(i++>10000)
             return 0;
                                                __nop();
                                                __nop();
                                                if(i++>10000)
                                                        return 0 ;
                                                        __nop();
                                                        __nop();
                                //ADXL345_SendByte(SlaveAddress);           //发送设备地址+读信号
    I2C_Send7bitAddress(I2C1, SLAVE_ADXL345_ADDRESS , I2C_Direction_Transmitter);
    i=0;
                                                if(i++>10000)
                                                        return 0;
                                                __nop();
                                                __nop();
        //ADXL345_SendByte(REG_Address);            //发送存储单元地址,从0开始
          i=0;
                while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTING))
                                                if(i++>10000)
                                                        return 0;
                                                __nop();
                                                __nop();
        //ADXL345_Start();                          //重新设置起始信号
                        i=0;
  //ADXL345_SendByte(SlaveAddress+1);         //发送设备地址+读信号
        I2C_Send7bitAddress(I2C1, SLAVE_ADXL345_ADDRESS , I2C_Direction_Receiver);
        i=0;
  while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))
                                  if(i++>10000)
                                                        return 0;
                                                __nop();
                                                __nop();
        I2C_AcknowledgeConfig(I2C1,DISABLE);
        //ADXL345_Stop();                           //停止信号
   i=0;
        while(!(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED)))
                                  if(i++>10000)
                                                        return 0;
                                                __nop();
                                                __nop();
        //REG_data=ADXL345_RecvByte();              //读出寄存器数据
        *data=I2C_ReceiveData(I2C1);
                return 1;
bool Multiple_read_ADXL345(int16_t *read_xyz)
        int16_t  outdata;
        uint32_t i=0,j=0;
        uint8_t   xyzdata[6];
                                        if(i++>10000)
             return 0 ;
                                                __nop();
                                                __nop();
  //   while (I2C_GetFlagStatus(I2C1,I2C_FLAG_SB)==0)//读取SR1
                while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT))//
                                                        if(i++>10000)
        return 0 ;
        __nop();
        __nop();
        __nop();
        __nop();
    i=0;
                                                if(i++>10000)
                                                        return 0 ;
                                                __nop();
                                                __nop();
                                                __nop();
                                                __nop();
     I2C_SendData(I2C1, 0x32);
           i=0;
                                                if(i++>10000)
                                                        return 0 ;
                                                __nop();
                                                __nop();
                                                __nop();
                                                __nop();
     i=0;
                                    if(i++>10000)
                                                        return 0 ;
                                                __nop();
                                                __nop();
        I2C_AcknowledgeConfig(I2C1, ENABLE);
        for (j=0; j<6; j++)                      //连续读取6个地址数据,存储中BUF
       i=0;
                                      if(i++>10000)
                                                            return 0 ;
                                                __nop();
                                                __nop();
                                xyzdata[j] = I2C_ReceiveData(I2C1);          //BUF[0]存储0x32地址中的数据
        //data++;
                                if (j == 4)
           //ADXL345_SendACK(1);                //最后一个数据需要回NOACK
           I2C_AcknowledgeConfig(I2C1, DISABLE);
                                   //ADXL345_Stop();
           I2C_GenerateSTOP(I2C1, ENABLE);////停止信号在倒数第二个数据的时候申请
          for(j=0;j<3;j++)
                                        uint8_t  i;
//                                        uint16_t  sysmbol;
                                        uint16_t  xyz_reg;
                                        i=j*2;
                                        outdata=0;
                                        xyz_reg=xyzdata[i+1];
                                        xyz_reg<<=8;
                                        xyz_reg+=xyzdata[i];
                                        //13位下高4位是符号位(12bit的有效数据D[11:0] 符号位D[15:12])
                                        outdata=xyz_reg;
                                        *read_xyz=outdata;//自测寄存器0x31 测量范围,正负16g 全分辨率13位模式32000mg/0x1fff=32000mg/8192=3.90625mg/Lsb  左对齐
                                        //*read_xyz=(int32_t)outdata*39/10;//自测寄存器0x31 测量范围,正负16g 全分辨率13位模式32000mg/0x1fff=32000mg/8192=3.90625mg/Lsb  左对齐
                                        read_xyz++;
                return 1;
        //Delay5ms();
int16_t Roll,Pitch,zz;
float   Xmg ,Ymg ,Zmg;
int16_t X1angle,Y1angle,Z1angle;
uint32_t Gmg;
void calculate_angle(int16_t ADXL345_X_Reg,int16_t ADXL345_Y_Reg,int16_t ADXL345_Z_Reg)//(int16_t ADXL345_rxdata[],int16_t *Xangle,int16_t *Yangle,int16_t *Zangle)
    //float Q,T,K;
                float m;
          uint32_t i;
          //ADXL345_DATA p;
          Xmg=(float)ADXL345_X_Reg*3.9;//分别是加速度X,Y,Z的原始数据 +_16g 全分辨率 13位 则32000/8192=3.90625
        Ymg=Ymg=(float)ADXL345_Y_Reg*3.9;//*3.9;
        Zmg=Zmg=(float)ADXL345_Z_Reg*3.9;//*3.9;
           Gmg= Xmg * Xmg +
                Ymg * Ymg +
                Zmg * Zmg;
           Gmg=(sqrt(Gmg));
           if(Gmg>2000 || Gmg<500)
                          return;
    //Roll=(float)(((atan2(K,Q)*180)/3.1416)-90);    //X轴角度值
    //Pitch=(float)(((atan2(K,T)*180)/3.1416)-90);   //Y轴角度值
          //zz=(float)((atan2(Q,K)*180)/3.1416);                   //Z轴角度值
          m=sqrt(Ymg*Ymg+Zmg*Zmg);
          X1angle=atan(Xmg/m)*180/3.1415926;
    //X1angle=new_adxl345_data->Xangle;
          //Xangle=atan2(Xmg,m)*180/3.1415926;
    m=sqrt(Xmg*Xmg+Zmg*Zmg);
//          Yangle=atan2(Ymg,m)*180/3.1415926;
          Y1angle=atan(Ymg/m)*180/3.1415926;
    //Y1angle=new_adxl345_data->Yangle;
    m=sqrt(Xmg*Xmg+Ymg*Ymg);
//          Zangle=atan2(Zmg,m)*180/3.1415926;
          Z1angle=atan(m/Zmg)*180/3.1415926;
          //Z1angle=new_adxl345_data->Zangle;
                i=recent_adxl345_data.write;
                recent_adxl345_data.struct_recent_adxl345[i].x_angle=X1angle;
                recent_adxl345_data.struct_recent_adxl345[i].y_angle=Y1angle;
                recent_adxl345_data.struct_recent_adxl345[i].z_angle=Z1angle;
                recent_adxl345_data.write++;
                if(recent_adxl345_data.write>=RECENT_ADXL345_BUFF_LEN)
                        recent_adxl345_data.write=0;
                if(recent_adxl345_data.num<RECENT_ADXL345_BUFF_LEN)
                   recent_adxl345_data.num++;
          //recent_adxl345_data.
void Init_ADXL345()
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x31,0x0B);//自测寄存器0x31 测量范围,正负16g 全分辨率13位模式32000mg/0x1fff=32000mg/8192=3.90625mg/Lsb  左对齐
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x2C,0x0A);//速率寄存器0x2C 速率设定为100HZ 参考pdf24页
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x2D,0x08);// PWR_CTL 寄存器 置于测量模式   参考pdf24页
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x2E,0x00);//中断使能 中断
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x1E,0x00);//X 偏移量 根据测试传感器的状态写入pdf29页
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x1F,0x00);//Y 偏移量 根据测试传感器的状态写入pdf29页
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x20,0x00);//Z 偏移量 根据测试传感器的状态写入pdf29页
   Write_ADXL345(SLAVE_ADXL345_ADDRESS,0x21,0x00); //
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
