naturc的个人空间 https://bbs.21ic.com/?593517 [收藏] [复制] [RSS]
日志
Ubuntu 18.04.3 LTS 编译安卓6.0.0_r1
已有 213 次阅读2020-3-21 13:34 |个人分类:安卓系统编译|系统分类:嵌入式系统
更换软件源为清华:
sudo gedit /etc/apt/sources.list
在文件最前面加入下面代码
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic main restricted universe multiverse
deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-updates main restricted universe multiverse
deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-updates main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-backports main restricted universe multiverse
deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-backports main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-security main restricted universe multiverse
deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-security main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-proposed main restricted universe multiverse
deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-proposed main restricted universe multiverse
修改完成后
sudo apt-get update
sudo apt-get upgrade
安装依赖:
sudo apt-get install -y git flex bison gperf build-essential libncurses5-dev:i386
sudo apt-get install libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-dev g++-multilib
sudo apt-get install tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386
sudo apt-get install dpkg-dev libsdl1.2-dev libesd0-dev
sudo apt-get install git-core gnupg flex bison gperf build-essential
sudo apt-get install zip curl zlib1g-dev gcc-multilib g++-multilib
sudo apt-get install libc6-dev-i386
sudo apt-get install lib32ncurses5-dev x11proto-core-dev libx11-dev
sudo apt-get install lib32z-dev ccache
sudo apt-get install libgl1-mesa-dev libxml2-utils xsltproc unzip m4
所需JDK:
因为是编译安卓6,所以安装openJDK7
https://download.csdn.net/download/tenyearsafterg/10462952
去某宝找代下,1元就可以下载了
用管理员权限打开文件夹,在终端输入sudo nautilus
将openJDK7解压到/usr/lib/jvm这个目录下面,比如我的目录/usr/lib/jvm/openjdk-1.7.0_121
打开/etc/profile文件:
sudo gedit /etc/profile
在末尾追加下面代码:
export JAVA_HOME=/usr/lib/jvm/openjdk-1.7.0_121
export JRE_HOME=${JAVA_HOME}/jre
export CLASSPATH=.:${JAVA_HOME}/lib:${JRE_HOME}/lib
export PATH=${JAVA_HOME}/bin:$PATH
修改了/etc/profile文件需要 重启 才能生效,但使用下面命令可以在不重启的情况下在 当前 bash环境生效:
source /etc/profile
验证
java -version
javac -version
通过国内镜像网站下载:(AOSP)源码:
下载 repo 工具:
mkdir ~/bin
PATH=~/bin:$PATH
curl https://mirrors.tuna.tsinghua.edu.cn/git/git-repo -o repo
chmod +x repo
下载 https://mirrors.tuna.tsinghua.edu.cn/aosp-monthly/aosp-latest.tar,下载完成后记得根据 checksum.txt 的内容校验一下。
使用方法如下:
wget -c https://mirrors.tuna.tsinghua.edu.cn/aosp-monthly/aosp-latest.tar # 下载初始化包
tar xf aosp-latest.tar
cd AOSP   # 解压得到的 AOSP 工程目录
# 这时 ls 的话什么也看不到,因为只有一个隐藏的 .repo 目录
repo sync -l # 仅checkout代码
# 或 repo sync # 正常同步一遍即可得到完整目录,时间非常久
建立工作目录:
mkdir AOSP
cd AOSP
初始化仓库:
repo init -u https://aosp.tuna.tsinghua.edu.cn/platform/manifest
如果提示无法连接到 gerrit.googlesource.com,repo的运行过程中会尝试访问官方的git源更新自己,如果想使用tuna的镜像源进行更新,可以将如下内容复制到你的~/.bashrc里
export REPO_URL='https://mirrors.tuna.tsinghua.edu.cn/git/git-repo/'
并重启终端模拟器。
如果需要某个特定的 Android 版本(https://source.android.com/setup/start/build-numbers#source-code-tags-and-builds):
repo init -u https://aosp.tuna.tsinghua.edu.cn/platform/manifest -b android-6.0.0_r1
同步源码树(以后只需执行这条命令来同步):
repo sync
问题:error: Exited sync due to fetch errors
解决方法:
repo sync -f
//-f or --force-broken flag allows it to recover from network error and more important recover on broken/missing objects.
替换已有的 AOSP 源代码的 remote
如果你之前已经通过某种途径获得了 AOSP 的源码(或者你只是 init 这一步完成后), 你希望以后通过 TUNA 同步 AOSP 部分的代码,只需要将 .repo/manifest.xml 把其中的 aosp 这个 remote 的 fetch 从 https://android.googlesource.com 改为 https://aosp.tuna.tsinghua.edu.cn/。
<manifest>
   <remote  name="aosp"
-           fetch="https://android.googlesource.com"
+           fetch="https://aosp.tuna.tsinghua.edu.cn"
            review="android-review.googlesource.com" />
   <remote  name="github"
同时,修改 .repo/manifests.git/config,将
url = https://android.googlesource.com/platform/manifest
更改为
url = https://aosp.tuna.tsinghua.edu.cn/platform/manifest
根据机型及想要编译的安卓版本,去官方 Nexus 和 Pixel 设备的二进制驱动下载页面:https://developers.google.com/android/drivers 下载了相应的二进制驱动。
下载好,解压,得到几个sh脚本,将它们复制到安卓源码目录下面并运行。
运行后,会提示你查看证书,按Enter键一行行的查看(最后一项是第8条第e项),出现下面的输入提示时,输入:I ACCEPT,会在安卓源码下生成vendor目录。其它几个自解压脚本也是这样执行。
修改 源码目录/art/build/Android.common_build.mk 文件,定位到75行,将下面的代码:
ifneq ($(WITHOUT_HOST_CLANG),true)改为ifeq ($(WITHOUT_HOST_CLANG),false) //对应问题3
开始编译:
如果之前编译过,删除所有以前编译操作的已有输出:
make clobber
make clean
(1) 在 .bashrc文件末尾添加:export USE_CCACHE = 1
echo export USE_CCACHE=1 >> ~/.bashrc //只要编译过aosp,执行过这一句代码,以后再编译aosp,就不用再执行了
(2) 为了提高编译效率,设置编译器高速缓存:
prebuilts/misc/linux-x86/ccache/ccache -M 100G
(3) 接着导入编译Android源码所需的环境变量和其它参数:
source build/envsetup.sh
(4) 运行lunch命令选择编译目标:
lunch
//输入17
//1. aosp_arm-eng不会生成我们需要的5个文件,17. aosp_hammerhead-userdebug可以
export LC_ALL=C //对应问题2
查看CPU核心数:
cat /proc/cpuinfo | grep processor
(5) 开始编译,执行make -j12, 12为同时编译的线程数,一般google推荐这个数字为2倍的cpu个数再加上2,比如4核,就是10。我使用的是12:
make -j12
花了1个多小时编译成功
编译后输出的文件都放在了源码根目录下的out文件中,比如我的目录:/android-6.0.0_r1/out/target/product。可以在该目录下面找到boot.img、system.img、recovery.img、cache.img、userdata.img五个镜像文件,这表示编译成功,这也是刷机需要的文件。
问题1:
Export includes file: frameworks/base/tools/aapt/Android.mk -- out/host/linux-x86/obj/STATIC_LIBRARIES/libaapt_intermediates/export_includes
cat out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.hpp >> out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.h
build/core/binary.mk:646: recipe for target 'out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp' failed
make: *** [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp] 已放弃 (core dumped)
make: *** 正在等待未完成的任务....
Export includes file: frameworks/base/libs/androidfw/Android.mk -- out/host/linux-x86/obj/STATIC_LIBRARIES/libandroidfw_intermediates/export_includes
echo '#endif' >> out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.h
注: 某些输入文件使用了未经检查或不安全的操作。
注: 有关详细信息, 请使用 -Xlint:unchecked 重新编译。
#### make failed to build some targets (51 seconds) ####
解决方法:
make -j12 update-api
问题2:
Lex: aidl <= frameworks/base/tools/aidl/aidl_language_l.l
flex-2.5.39: loadlocale.c:130:_nl_intern_locale_data: ?? 'cnt < (sizeof (_nl_value_type_LC_TIME) / sizeof (_nl_value_type_LC_TIME[0]))' ???
解决方法:
编译前:export LC_ALL=C
问题3:
clang: error: linker command failed with exit code 1 (use -v to see invocation)
build/core/host_shared_library_internal.mk:51: recipe for target 'out/host/linux-x86/obj/lib/libart.so' failed
make: *** [out/host/linux-x86/obj/lib/libart.so] Error 1
解决方法:
参考:
网上各种教程,因为链接太多了,就不一一列举了。
感谢各位大佬们!
路过
鸡蛋
鲜花
握手
雷人
全部作者的其他最新日志
评论 (0 个评论)
