singleywy的笔记 https://bbs.21ic.com/?632881 [收藏] [复制] [RSS]
日志
伪本征函数—Keil C51头文件INTRINS.H
已有 1382 次阅读2010-11-5 10:01 |系统分类:单片机| 伪本征, 函数, Keil, intrins
2010-10-20 20:23
转载自 flibird
最终编辑 flibird
INTRINS.H
Intrinsic s for C51.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __INTRINS_H__
#define __INTRINS_H__
extern void           _nop_      (void);
extern bit            _testbit_ (bit);
extern unsigned char _cror_     (unsigned char, unsigned char);
extern unsigned int   _iror_     (unsigned int,   unsigned char);
extern unsigned long _lror_     (unsigned long, unsigned char);
extern unsigned char _crol_     (unsigned char, unsigned char);
extern unsigned int   _irol_     (unsigned int,   unsigned char);
extern unsigned long _lrol_     (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
#endif
         伪本征函数——Keil C51头文件INTRINS.H的扩容工程
                     作者:HotPower@126.com   2004.5.27   第二版
#define _setc_()           CY    = 1
#define _clrc_()           CY    = 0
#define _setb_(RBIT)       RBIT = 1
#define _clrb_(RBIT)       RBIT = 0
#define _clra_()           ACC   = 0
#define _xorr_(RX)         RX   ^= RX                   //用于取奇偶位P,且RX=0
#define _andr_(RX)         RX   &= RX                   //用于取奇偶位P,且RX=不变
#define _orr_(RX)          RX   |= RX                   //用于取奇偶位P,且RX=不变
#define _notr_(RX)         RX    =~RX
#define _movra_(RX)        RX    = ACC
#define _movar_(RX)        ACC   = RX
#define _movcb_(RBIT)      CY    = RBIT
#define _movbc_(RBIT)      RBIT = CY
#define _movb0_(RBIT, RX) RBIT = RX   & 0x01            //用于取RX的最低位
#define _movb7_(RBIT, RX) RBIT = RX   & 0x80            //用于取RX的最高位
#define _movc0_(RX)        CY    = RX   & 0x01
#define _movc7_(RX)        CY    = RX   & 0x80
#define _rrca_()           CY    = ACC & 0x01            //产生RRC A指令
#define _rlca_()           CY    = ACC & 0x80            //产生RLC A指令
#define _rrcr_(RX)         CY    = RX   & 0x01; RX = ACC //产生RRC RX指令
#define _rlcr_(RX)         CY    = RX   & 0x80; RX = ACC //产生RLC RX指令
                累加器带进位右移指令 RRC A
汇编代码        rrc a
                累加器带进位左移指令 RLC A
汇编代码        rlc a
                寄存器带进位右移指令 RRC REG
汇编代码        mov   a,RX
                rrc   a
    mov   RX,a
例:
C51程序
unsigned char i;
        i = 0x55;
    _setc_();//CY=1
        _rrcr_(i);//i=0xaa,ACC=0xaa,CY=1
汇编代码
        mov   r7,#055h
    setb c
    mov   a,r7
    rrc   a
        mov   r7,a
                寄存器带进位左移指令 RLC REG
#define _rlcar_(RX)        CY   = RX   & 0x80; RX   = ACC
汇编代码        mov   a,RX
                rlc   a
    mov   RX,a
例:
C51程序
unsigned char i;
        i = 0x55;
    _setc_();//CY=1
        _rlcr_(i);//i=0x55,ACC=0xab,CY=0
汇编代码
        mov   r7,#055h
    setb c
    mov   a,r7
    rlc   a
        mov   r7,a
   伪本征函数"汇编级"应用
1.写串行数据
C51程序
void writedata(unsigned char val)
   _movar_(val);//或用ACC = val;
   for (val = 8; val > 0; val--)
     _clrb_(TXD);//或用TXD = 0;
     _rrca_();
     _movbc_(RXD);//或用RXD = CY;
     _setb_(TXD);//或用TXD = 1;
_nop_();
A51代码
writedata:
     mov   a,r7
mov   r7,#8
writedata_loop:
     clr   txd
     rrc   a
mov   rxd,c
     setb txd
nop
djnz r7,writedata_loop
ret
2.读串行数据
C51程序
unsigned char readdata(void)
unsigned char val;
_nop_();
     _movcb_(RXD);//或用CY = RXD;
     _rrca_();
_nop_();
   _movra_(val);//或用val = ACC;
   return val;
A51代码
readdata:
mov   r7,#8
readdata_loop:
     clr   txd
nop
mov   c,rxd
     rrc   a
     setb txd
nop
djnz r7,readdata_loop
mov   r7,a
ret
(文章推荐人:长城笑气)
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
