chenke1988的笔记 https://bbs.21ic.com/?652386 [收藏] [复制] [RSS]
日志
AT24C02的读写程序
已有 531 次阅读2010-10-21 07:53 |系统分类:单片机| AT24C02
#include <reg51.h>
#include<intrins.h>
#define uchar unsigned char
#define uint  unsigned int
sbit sda=P3^2;
sbit scl=P3^3;
void delay()
void delay1(uchar x)
  uchar a,b;
  for(a=x;a>0;a--)
  for(b=125;b>0;b--);
void start()
   sda=1;
  delay();
   scl =1;
  delay();
  sda=0;
  delay();
void stop()
  sda=0;
 delay();
  scl=1;
 delay();
 sda=1;
 delay();
void respon()
  uchar i=0;
  scl=1;
  delay();
  sda=1;
  delay() ;
  while((sda==0)&&(i<250))
   i++;
   scl=0;
   delay();
uchar read_byte(uchar date)
   uchar i;
    scl=0;
   delay();
   sda=1;
   delay();
   for(i=0;i<8;i++)
   scl=1;
   delay();
   date=(date<<1)|sda;
   delay();
   scl=0;
   delay();
   return date;
 scl=0;
 delay();
 sda=1;
 delay();
void write_byte(uchar date)
   uchar i;
   scl=0;
   delay();
   sda=1;
   delay();
   for(i=0;i<8;i++)
  scl=0;
  delay();
  date=date<<1;
  sda=CY;
  delay();
  scl=1;
  delay();
   scl=0;
   delay();
   sda=1;
   delay();
void write_address(uchar address,uchar date)
  start();
  write_byte(0xa0);
  respon();
  write_byte(address);
  respon();
  write_byte(date);
  respon();
  stop();
uchar read_address(uchar address)
  uchar temp;
  start();
  write_byte(0xa0);
  respon();
  respon();
  start();
   write_byte(0xa1);
   respon();
   temp=read_byte(address);
   stop();
   return temp;
void init()
  sda=1;
  delay();
  scl=1;
  delay();
void main()
   init();
   write_address(23,0x55);
   delay1(100);
   P1=read_address(23);
   while(1);
路过
鸡蛋
鲜花
握手
雷人
全部作者的其他最新日志
评论 (0 个评论)
