alexant的笔记 https://bbs.21ic.com/?72205 [收藏] [复制] [RSS] 这里记录的是我上网时发现的一些比较好的文章和比较值得记录的知识,希望对大家有点帮助。
日志
原创:我在项目中使用FreeRTOS的源码连载-startup.S
已有 1740 次阅读2007-3-21 19:50 |系统分类:ARM| FreeRTOS, startup.S
功能:初始化LPC2142内部寄存器,包括设置PLL、初始化中断向量、设置代码加密等。由Keil的模板改来的,要与我的makefile和lpc2142-ROM.ld配合使用。
/*  This file is part of the uVision/ARM development tools             */
/*  Copyright KEIL ELEKTRONIK GmbH 2002-2005                           */
/*  STARTUP.S:  Startup file for Philips LPC213x/LPC214x device series */
 *  The STARTUP.S code is executed after CPU Reset. This file may be
 *  translated with the following SET symbols. In uVision these SET
 *  symbols are entered under Options - ASM - Set.
 *  REMAP: when set the startup code initializes the register MEMMAP
 *  which overwrites the settings of the CPU configuration pins. The
 *  startup and interrupt vectors are remapped from:
 *     0x00000000  default setting (not remapped)
 *     0x80000000  when EXTMEM_MODE is used
 *     0x40000000  when RAM_MODE is used
 *  EXTMEM_MODE: when set the device is configured for code execution
 *  from external memory starting at address 0x80000000. The startup
 *  vectors are located to 0x80000000.
 *  RAM_MODE: when set the device is configured for code execution
 *  from on-chip RAM starting at address 0x40000000. The startup
 *  vectors are located to 0x40000000.
 .extern main
 .text
 .code 32
 .align  0
 .extern __bss_beg__
 .extern __bss_end__
 .extern __stack_end__
 .extern __data_beg__
 .extern __data_end__
 .extern __data+beg_src__
 .global start
 .global endless_loop
 /* Stack Sizes */
    .set  UND_STACK_SIZE, 0x00000004
    .set  ABT_STACK_SIZE, 0x00000004
    .set  FIQ_STACK_SIZE, 0x00000004
    .set  IRQ_STACK_SIZE, 0X00000400
    .set  SVC_STACK_SIZE, 0x00000400
 /* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs */
    .set  MODE_USR, 0x10            /* User Mode */
    .set  MODE_FIQ, 0x11            /* FIQ Mode */
    .set  MODE_IRQ, 0x12            /* IRQ Mode */
    .set  MODE_SVC, 0x13            /* Supervisor Mode */
    .set  MODE_ABT, 0x17            /* Abort Mode */
    .set  MODE_UND, 0x1B            /* Undefined Mode */
    .set  MODE_SYS, 0x1F            /* System Mode */
    .equ  I_BIT, 0x80               /* when I bit is set, IRQ is disabled */
    .equ  F_BIT, 0x40               /* when F bit is set, FIQ is disabled */
/* VPBDIV definitions*/
  .equ  VPBDIV,   0xE01FC100
  .set  VPBDIV_VALUE, 0x00000000
/* Phase Locked Loop (PLL) definitions*/
  .equ  PLL_BASE,  0xE01FC080
  .equ  PLLCON_OFS,  0x00
  .equ  PLLCFG_OFS,  0x04
  .equ  PLLSTAT_OFS,  0x08
  .equ  PLLFEED_OFS,  0x0C
        .equ PLLCON_PLLE,   (1<<0)      /* PLL Enable */
        .equ PLLCON_PLLC,   (1<<1)      /* PLL Connect */
        .equ PLLSTAT_LOCK,  (1<<10)     /* PLL Lock Status */
  .equ PLLCFG_MSEL,   ((PLL_MUL - 1) << 0)
  .equ PLLCFG_PSEL, (0x02 << 5)
  .equ PLLCFG_Val, (PLLCFG_MSEL|PLLCFG_PSEL)
  .equ  MEMMAP,  0xE01FC040     /*Memory Mapping Control*/
/* Memory Accelerator Module (MAM) definitions*/
  .equ  MAM_BASE,  0xE01FC000
  .equ  MAMCR_OFS,  0x00
  .equ  MAMTIM_OFS,  0x04
        .equ  MAMCR_Val,    0x00000002
        .equ  MAMTIM_Val,   0x00000004
  .equ  VICIntEnClr, 0xFFFFF014
  .equ  VICIntSelect, 0xFFFFF00C
/* Setup the operating mode & stack.*/
        .global _start, start, _reset, reset,
        .func   _start,
_start:
start:
_reset:
reset:
/* Setup PLL */
#if (PLL_MUL>1)
  ldr     r0, =PLL_BASE
  mov  r1, #0xAA
  mov  r2, #0x55
/* Configure and Enable PLL */
  mov     r3, #PLLCFG_Val
  str     r3, [r0, #PLLCFG_OFS]
  mov     r3, #PLLCON_PLLE
  str     r3, [r0, #PLLCON_OFS]
  str     r1, [r0, #PLLFEED_OFS]
  str     r2, [r0, #PLLFEED_OFS]
/*  Wait until PLL Locked */
7:  ldr     r3, [r0, #PLLSTAT_OFS]
  ands    r3, r3, #PLLSTAT_LOCK
  beq     7b
/*  Switch to PLL Clock */
  mov     r3, #(PLLCON_PLLE|PLLCON_PLLC)
  str     R2, [r0, #PLLFEED_OFS]
#endif /*PLL_SETUP*/
#if (REMAP)
  mov     r0, =MEMMAP
#if (EXTMEM_MODE)
        mov     r1, #3
#elseif (RAM_MODE)
        mov     r1, #2
#else
        mov     r1, #1
#endif
        str     r1, [r0]
#endif
/* Setup MAM */
  ldr  r0, =MAM_BASE
  mov  r1, #MAMTIM_Val
  str  r1, [r0, #MAMTIM_OFS]
  mov  r1, #MAMCR_Val
  str  r1, [r0, #MAMCR_OFS]
/* Setup VPBDIV */
  ldr  r0, =VPBDIV
  ldr     r1, =VPBDIV_VALUE
  str  r1, [r0]
/* Memory Mapping */
  ldr     r0, =MEMMAP
#if defined(RUN_FROM_RAM)
  mov  r1, #2
#else
  mov  r1, #1
#endif
  str  r1, [r0]
  /* clear all interrupts */
  ldr     r0, =VICIntEnClr
  mov  r1, #0xFFFFFFFF
  str  r1, [r0]
  ldr     r0, =VICIntSelect
  mov  r1, #0x00000000
  str  r1, [r0]
 /* Setup a stack for each mode - note that this only sets up a usable stack
 for system/user, SWI and IRQ modes.   Also each mode is setup with
 interrupts initially disabled. */
    ldr   r0, .LC6
    msr   CPSR_c, #MODE_UND|I_BIT|F_BIT /* Undefined Instruction Mode
    mov   sp, r0
    sub   r0, r0, #UND_STACK_SIZE
    msr   CPSR_c, #MODE_ABT|I_BIT|F_BIT /* Abort Mode */
    mov   sp, r0
    sub   r0, r0, #ABT_STACK_SIZE
    msr   CPSR_c, #MODE_FIQ|I_BIT|F_BIT /* FIQ Mode */
    mov   sp, r0
    sub   r0, r0, #FIQ_STACK_SIZE
    msr   CPSR_c, #MODE_IRQ|I_BIT|F_BIT /* IRQ Mode */
    mov   sp, r0
    sub   r0, r0, #IRQ_STACK_SIZE
    msr   CPSR_c, #MODE_SVC|I_BIT|F_BIT /* Supervisor Mode */
    mov   sp, r0
    sub   r0, r0, #SVC_STACK_SIZE
    msr   CPSR_c, #MODE_SYS|I_BIT|F_BIT /* System Mode */
    mov   sp, r0
 /* We want to start in supervisor mode.  Operation will switch to system
 mode when the first task starts. */
 /* Clear BSS. */
 mov     a2, #0   /* Fill value */
 mov  fp, a2   /* Null frame pointer */
 mov  r7, a2   /* Null frame pointer for Thumb */
 ldr  r1, .LC1  /* Start of memory block */
 ldr  r3, .LC2  /* End of memory block */
 subs r3, r3, r1      /* Length of block */
 beq  .end_clear_loop
 mov  r2, #0
.clear_loop:
 strb r2, [r1], #1
 subs r3, r3, #1
 bgt  .clear_loop
.end_clear_loop:
 /* Initialise data. */
 ldr  r1, .LC3  /* Start of memory block */
 ldr  r2, .LC4  /* End of memory block */
 ldr  r3, .LC5
 beq  .end_set_loop
.set_loop:
 ldrb r4, [r2], #1
 strb r4, [r1], #1
 subs r3, r3, #1
 bgt  .set_loop
.end_set_loop:
 mov  r0, #0          /* no arguments  */
 mov  r1, #0          /* no argv either */
 bl  main
endless_loop:
 b               endless_loop
 .align 0
 .LC1:
 .word   __bss_beg__
 .LC2:
 .word   __bss_end__
 .LC3:
 .word   __data_beg__
 .LC4:
 .word   __data_beg_src__
 .LC5:
 .word   __data_end__
 .LC6:
 .word   __stack_end__
 /* Setup vector table.  Note that undf, pabt, dabt, fiq just execute
 a null loop. */
.section .startup,"ax"
         .code 32
         .align 0
 b     _start      /* reset - _start   */
 ldr   pc, _undf      /* undefined - _undf  */
 ldr   pc, _swi      /* SWI - _swi    */
 ldr   pc, _pabt      /* program abort - _pabt */
 ldr   pc, _dabt      /* data abort - _dabt  */
 nop         /* reserved     */
 ldr   pc, [pc,#-0xFF0]    /* IRQ - read the VIC  */
 ldr   pc, _fiq      /* FIQ - _fiq    */
_undf:  .word __undf                    /* undefined    */
_swi:   .word vPortYieldProcessor       /* SWI      */
_pabt:  .word __pabt                    /* program abort   */
_dabt:  .word __dabt                    /* data abort    */
_fiq:   .word __fiq                     /* FIQ      */
__undf: b     .                         /* undefined    */
__pabt: b     .                         /* program abort   */
__dabt: b     .                         /* data abort    */
__fiq:  b     .           /* FIQ      */
#if defined(CODE_PROTECTION)
.org 0x01FC
.word 0x87654321
#endif
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
