huangxz的笔记 https://bbs.21ic.com/?73035 [收藏] [复制] [RSS]
日志
my notes -- will edit every time
已有 488 次阅读2020-9-30 09:08 |系统分类:兴趣爱好
how to force lxde for xrdp connections on 18.04
https://askubuntu.com/questions/1160604/how-to-force-lxde-for-xrdp-connections-on-18-04
Well, nevermind. After hours of no results I now randomly stumbled upon the solution.
update-alternatives --config x-session-manager
and then select the LXDE option...
#1.cmake version
  2 cmake_minimum_required(VERSION 3.2)
  4 #2.project name
  5 PROJECT(talk_ref)
  7 #3.head file path
  8 INCLUDE_DIRECTORIES(
  9     include
 10     )
 12 #4.source directory
 13 AUX_SOURCE_DIRECTORY(. DIR_SRCS)
 14
 15 #5.set enviroment varible
 16 SET(CMAKE_C_COMPILER g++)
 17 SET( TEST_MATH ${DIR_SRCS})
 18 SET(CMAKE_BUILD_TYPE "Debug")
 19 SET(CMAKE_CXX_FLAGS_DEBUG "$ENV{CXXFLAGS} -O0 -Wall -g2 -ggdb")
 20 SET(CMAKE_CXX_FLAGS_RELEASE "$ENV{CXXFLAGS} -O3 -Wall")
 21 add_compile_options(-std=c++11)
 22
 23 #6.add excuteable
 24 ADD_EXECUTABLE(${PROJECT_NAME} ${TEST_MATH})
 25
 26 #7.add link library
 27 TARGET_LINK_LIBRARIES(${PROJECT_NAME} m pthread)
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
