URAT(RS232)低层驱动+中间层软件示例
已有 696 次阅读2011-4-21 13:10
|系统分类:单片机
一般教科书上提供的UART收发的程序往往是一段采用轮循(Polling)方式完成收发的简单代码。但对于高速的AVR来讲,采用这种方式大大降低了MUC的效率。在使用AVR时,应根据芯片本身的特点(片内大容量数据存储器RAM,更适合采用高级语言编写系统程序),编写高效可靠的UART收发接口(低层)程序。下面是一个典型的USART的接口程序。
#include <mega128.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART0 Receiver buffer
#define RX_BUFFER_SIZE0 8
char rx_buffer0[RX_BUFFER_SIZE0];
unsigned char rx_wr_index0,rx_rd_index0,rx_counter0;
// This flag is set on USART0 Receiver buffer overflow
bit rx_buffer_overflow0;
// USART0 Receiver interrupt service routine
#pragma savereg-
interrupt [USART0_RXC] void uart0_rx_isr(void)
char status,data;
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#endasm
status=UCSR0A;
data=UDR0;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer0[rx_wr_index0]=data;
if (++rx_wr_index0 == RX_BUFFER_SIZE0) rx_wr_index0=0;
if (++rx_counter0 == RX_BUFFER_SIZE0)
rx_counter0=0;
rx_buffer_overflow0=1;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART0 Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter0==0);
data=rx_buffer0[rx_rd_index0];
if (++rx_rd_index0 == RX_BUFFER_SIZE0) rx_rd_index0=0;
#asm("cli")
--rx_counter0;
#asm("sei")
return data;
#pragma used-
#endif
// USART0 Transmitter buffer
#define TX_BUFFER_SIZE0 8
char tx_buffer0[TX_BUFFER_SIZE0];
unsigned char tx_wr_index0,tx_rd_index0,tx_counter0;
// USART0 Transmitter interrupt service routine
#pragma savereg-
interrupt [USART0_TXC] void uart0_tx_isr(void)
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#edasm
if (tx_counter0)
--tx_counter0;
UDR0=tx_buffer0[tx_rd_index0];
if (++tx_rd_index0 == TX_BUFFER_SIZE0) tx_rd_index0=0;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
// Write a character to the USART0 Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter0 == TX_BUFFER_SIZE0);
#asm("cli")
if (tx_counter0 || ((UCSR0A & DATA_REGISTER_EMPTY)==0))
tx_buffer0[tx_wr_index0]=c;
if (++tx_wr_index0 == TX_BUFFER_SIZE0) tx_wr_index0=0;
++tx_counter0;
else
UDR0=c;
#asm("sei")
#pragma used-
#endif
// Standard Input/Output s
#include <stdio.h>
// Declare your global variables here
void main(void)
// USART0 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART0 Receiver: On
// USART0 Transmitter: On
// USART0 Mode: Asynchronous
// USART0 Baud rate: 9600
UCSR0A=0x00;
UCSR0B=0xD8;
UCSR0C=0x06;
UBRR0H=0x00;
UBRR0L=0x67;
// Global enable interrupts
#asm("sei")
while (1)
// Place your code here
这段由CVAVR程序生成器产生的UART接口代码是一个非常好的、高效可靠,并且值得认真学习和体会的。其特点如下:
l.它采用两个8字节的接收和发送缓冲器来提高MCU的效率,如当主程序调用Putchar()发送数据时,如果UART口不空闲,就将数据放入发送缓冲器中,MCU不必等待,可以继续执行其它的工作。而UART的硬件发送完一个数据后,产生中断,由中断服务程序负责将发送缓冲器中数据依次送出。
2.数据缓冲器结构是一个线性的循环队列,由读、写和队列计数器3个指针控制,用于判断队列是否空、溢出,以及当前数据在队列中的位置。
3.用编译控制命令#pragma savereg-和#pragma savereg+,使得由CVAVR在生成的中断服务程序中不进行中断保护(CVAVR生成中断保护会将比较多的寄存器压入堆栈中),而在中断中嵌入汇编,只将5个在本中断中必须要保护的寄存器压栈。这样提高了UART中断处理的速度,也意味着提高了MCU的效率。
4.由于在接口程序Putchar()、Getchar()和中断服务程序中都要对数据缓冲器的读、写和队列计数器3个指针判断和操作,为了防止冲突,在Putchar()、Getchar()中对3个指针操作时临时将中断关闭,提高了程序的可靠性。
建议读者能逐字逐句地仔细分析该段代码,真正理解和领会每一句语句(包括编译控制命令的作用)的作用,从中体会和学习如何编写效率高,可靠性好,结构优良的系统代码。这段程序使用的方法和技巧,对编写SPI、I2C的串行通信接口程序都是非常好的借鉴。
作为现在的单片机和嵌入式系统的工程师,不仅要深入全面的掌握芯片和各种器件的性能,具备丰富的硬件设计能力;同时也必须提高软件的设计能力。要学习和掌握有关数据结构、操作系统、软件工程、网络协议等方面的知识,具有设计编写大的复杂系统程序的能力。
USART应用实例
使用ATmega128实现一个工业设备的主控制板,它与由ATmega8管理的按键和LED显示构成的控制面板距离在2米左右,两者之间采用USART通信联系。考虑到在实际应用中,俩者之间交换的数据很少,通信速度也不需要很高,重要的是保证通信的可靠和抗干扰,因此在硬件设计上采用电流环的连接方式,见图5.4。
在图中通信双方采用光隔和三极管,将USART的电平变化变成电流变化后传送连接,如同工业上使用的20mA电流环通信一样,大大提高了通信的抗干扰能力。
通信协议和规程的制定:
l.通信速率采用2400bps(速率太高时电流环的变化会跟不上)。
2. 用户数据包采用定长格式,每个数据包长度为6个字节,其中第1个字节是数据包起始字节0xBB,第6字节为数据包结束字节0xEE,其它为用户命令、数据和系统状态参数。
3.每次通信由A端发起,下发一个数据包;B端收到一个正确的数据包后,必须返回一个数据包应答。
4.A端下发一个数据包后,在300ms内没有正确收到应答包时(在2400bps时传送6个字节的时间约为30ms),将再次重发;3次重发均不能正确收到应答包则报警。
5.在系统正常工作时,A端每隔250ms下发一个数据包,B端如果在1s内没有正确收到一个下发的数据包,将进入安全保护程序。
在这个应用实例中,USART接口的发送程序与前面给出的典型例程中的一样,而对USART的接收程序进行了改动和简化,使其更加符合在本系统中使用。
#define UART_BEGIN_STX 0xBB
#define UART_END_STX 0xEE
#define RX_BUFFER_SIZE0 6
unsigned char rx_counter;
bit Uart_RecvFlag
// USART Receiver interrupt service routine
#pragma savereg-
interrupt [USART_RXC] void uart_rx_isr(void)
unsigned char status,data;
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#endasm
status=UCSRA;
data=UDR;
if (!Uart_RecvFlag)
rx_buffer[rx_counter] = data;
switch (rx_counter)
case 0:
if (data == UART_BEGIN_STX) rx_counter = 1;
break;
case 1:
case 2:
case 3:
case 4:
rx_counter++;
break;
case 5:
rx_counter = 0;
if (data == UART_END_STX) Uart_RecvFlag = 1;
break;
else
rx_counter = 0;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
void main(void)
while(1)
if (Uart_RecvFlag)
………… //处理收到的数据包
Uart_RecvFlag = 0; //允许USART接受新的数据包
………… //处理其它任务
在这段代码中,接收中断服务程序直接对数据包的起始字符和结束字符进行判断,并完成对整个数据包的接收。当接收到正确的6个字符的数据包后,将“Uart_RecvFlag”标志置位,通知上层程序处理收到的数据。一旦“Uart_RecvFlag”标志置位后,中断服务程序将不再接收新的数据(放弃掉收到的字节),使得数据缓冲区不会溢出。
上层程序的设计,应保证以200ms左右的间隔对“Uart_RecvFlag”标志位进行一次判断。一旦判断“Uart_RecvFlag”标志置位后,马上进行处理,回送应答数据。处理完后将“Uart_RecvFlag”标志清除,允许USART接收新的数据包。
还可以考虑在数据包中增加“数据包编号”和“数据校验”2个字节,以进一步提高通信的可靠性。
