风一样的男子的笔记 https://bbs.21ic.com/?99092 [收藏] [复制] [RSS]
日志
uClinux上的应用程序设计(5)
已有 953 次阅读2005-9-13 15:03 |个人分类:火爆嵌入式系统|系统分类:嵌入式系统
src目录下的Rules.make文件给出了编译的一些规则,如下:
# This file contains rules which are shared between multiple Makefiles.
# False targets.
.PHONY: dummy
# Special variables which should not be exported
unexport EXTRA_ASFLAGS
unexport EXTRA_CFLAGS
ifneq "$(ARCH)" "h8300"
unexport EXTRA_LDFLAGS
endif
unexport EXTRA_ARFLAGS
unexport SUBDIRS
unexport SUB_DIRS
unexport ALL_SUB_DIRS
unexport MOD_SUB_DIRS
unexport O_TARGET
unexport O_OBJS
unexport L_OBJS
unexport M_OBJS
unexport MI_OBJS
unexport ALL_MOBJS
# objects that export symbol tables
unexport OX_OBJS
unexport LX_OBJS
unexport MX_OBJS
unexport MIX_OBJS
unexport SYMTAB_OBJS
unexport MOD_LIST_NAME
include ../dir.config
include $(SRC_DIR)/arch.config
# Get things started.
first_rule: sub_dirs
       $(MAKE) all_targets
# Common rules
INC_DIR = -I$(SRC_DIR)/cal -I$(SRC_DIR)/xml -I$(SRC_DIR)/serial -I$(SRC_DIR)/packet -I$(SRC_DIR)/fifo -I$(SRC_DIR)/ping -I$(SRC_DIR)/interface -I$(SRC_DIR)/public
%.o: %.c
       @echo "Compiling..."
       @echo "$<"
       $(CXX) $(INC_DIR) $(CFLAGS) $(EXTRA_CFLAGS) -c -o $@ $<
%.o: %.cpp
       @echo "$<"
# Rule to compile a set of .o files into one .o file
ifeq (.depend,$(wildcard .depend))
include .depend
else
.depend:       fastdep
endif
ifneq ($(O_TARGET),$(O_OBJS))
$(O_TARGET): .depend $(O_OBJS)
       @echo "Linking..."
       @echo $(O_OBJS) " --> " $@
       @$(LD) $(EXTRA_LDFLAGS) -r -o $@ $(O_OBJS)
else
endif
all:   $(O_OBJS)
       echo all
all_targets:  $(O_OBJS) $(O_TARGET)
# Rule to compile a set of .o files into one .a file
ifdef L_TARGET
$(L_TARGET): $(LX_OBJS) $(L_OBJS)
       rm -f $@
       $(AR) $(EXTRA_ARFLAGS) rcs $@ $(LX_OBJS) $(L_OBJS)
endif
# This make dependencies quickly
fastdep: dummy
       @echo "make fastdep"
       if [ -n "$(wildcard *.[chS])" ]; then \
       $(SCRIPTS_DIR)/mkdep *.[chS] > .depend; fi
       if [ -n "$(wildcard *.cpp)" ]; then \
       $(SCRIPTS_DIR)/mkdep *.cpp >> .depend; fi
# A rule to make subdirectories
sub_dirs: dummy
ifdef SUB_DIRS
       set -e; for i in $(SUB_DIRS); do $(MAKE) -C $$i; done
endif
# A rule to do nothing
dummy:
config:
       cd $(ROOT_DIR); make config
c clean:
       rm -f *.o
       rm -f *.gdb
       rm -f .depend
       rm -f test
       rm -f core
       rm -f *.elf
       rm -f *.elf2flt
# This is useful for testing
script:
       $(SCRIPT)
run: test
       @echo ... running ...
       @echo `pwd`/test
       @./test
# This sets version suffixes on exported symbols
# Uses SYMTAB_OBJS
# Separate the object into "normal" objects and "exporting" objects
# Exporting objects are: all objects that define symbol tables
$(MX_OBJS):
       $(CC) $(CFLAGS) -DEXPORT_SYMTAB -c $(@:.o=.c)
$(LX_OBJS) $(OX_OBJS):
       $(CC) $(CFLAGS) -DMODVERSIONS -DEXPORT_SYMTAB -c $(@:.o=.c)
$(M_OBJS):
ifdef MAKING_MODULES
$(O_OBJS) $(L_OBJS):
endif
config 目录下,编写两个和架构有关的文件,对于x86平台,是arch.i386,如下:
.EXPORT_ALL_VARIABLES:
# Vendor specific settings
CONSOLE_BAUD_RATE = 19200
# The makefiles need to know how to do things in different contexts
# To save some pain we put it all here
# First settings we always want for all build
# ARCH = kernel,  TARGET_ARCH = uClibc
MACHINE       = i386
ARCH          = i386
CROSS_COMPILE =
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
