[嵌入式linux] 请教一下linux下编译问题
 楼主| sockscaps 发表于 2007-11-24 20:14 | 显示全部楼层 |阅读模式
在编译三星ARM9 2410 的vivi时,出现下面的错误
个人感觉是gcc有问题, 我用的arm-linux-gcc 2.95.3
本人新手,请各位大侠指教。。。。。。
[root@localhost vivi]# make menuconfig
make -C scripts/lxdialog all
make[1]: Entering directory `/opt/FriendlyARM/SBC2410/vivi/scripts/lxdialog'
/usr/local/arm/2.95.3/arm-linux/bin/ld: cannot find -lncurses
collect2: ld returned 1 exit status
>> Unable to find the Ncurses libraries.
>> You must have Ncurses installed in order
>> to use 'make menuconfig'
make[1]: *** [ncurses] Error 1
make[1]: Leaving directory `/opt/FriendlyARM/SBC2410/vivi/scripts/lxdialog'
make: *** [menuconfig] Error 2
a___9 发表于 2007-11-30 16:18 | 显示全部楼层
需要安装ncurses开发包
需要安装ncurses开发包 libncurses5-dev
如果你系统是ubuntu的话,源里有
$sudo apt-get install libncurses5-dev
