是VB的语言!
'Windows API/Global Declarations for :[
' A Simple] code execution speed test
Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Private Declare Function timeGetTime Lib "winmm.dll" () As Long
code:
Can't Copy and Paste this?
Click here for a copy-and-paste friendly version of this code!
Terms of Agreement:
By using this code, you agree to the following terms...
1) You may use this code in your own programs (and may
compile it into a program and distribute it in compiled
format for languages that allow it) freely and with no
charge.
2) You MAY NOT redistribute this code (for example to a
web site) without written permission from the original
author. Failure to do so is a violation of copyright
laws.
3) You may link to this code from another website, but
ONLY if it is not wrapped in a frame.
4) You will abide by any additional copyright
restrictions which the author may have placed in the
code or code's description.
' Name: [ A Simple] code execution speed
' test
' Description:Paste this into your VB co
' de to test how long a portion of your co
' de takes to execute. The number of milli
' seconds is appended to C:\TimeTest.txt
' By: lonetron
'This code is copyrighted and has' limited warranties.Please see http://w
' ww.Planet-Source-Code.com/vb/scripts/Sho
' wCode.asp?txtCodeId=49159&lngWId=1'for details.'**************************************
'[Simple] code execution time tests for
' VB
'Paste this into your VB code to test ho
' w long a portion of your
'code takes to execute. The number of mi
' lliseconds is appended to C:\TimeTest.tx
' t
' __________________________
'|This simple solution was
'|brought to you by the P2B Consortium.
'|揅reate your very own artificial
'|intelligence chat-bot now!?'|http://www.p2bconsortium.com/sss/Creat
' eBot.aspx
'|__________________________
'Start Copying Here
'Stop Copying Here
Private Sub Form_Load()
'Start Copying Here
Dim tm As Long
tm = timeGetTime
'Stop Copying Here
Call Sleep(5000)
'Start Copying Here
Dim tma As Long
tma = timeGetTime
Open "C:\TimeTest.txt" For Append As #1
Print #1, tma - tm
Close #1
'Stop Copying Here
End Sub |
