我是初学者,高手帮我看看这时钟程序
 楼主| heilongqq 发表于 2009-9-27 10:00 | 显示全部楼层 |阅读模式
at24co2不工作,我调了很久都没出来,哪位大侠给解决一下啊
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
sbit lcden=P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
sbit key1=P3^5;
sbit key2=P3^6;
sbit key3=P3^7;
sbit feng=P2^3;
sbit sda=P2^0;//定义数据控制线。
sbit scl=P2^1;//定义时钟控制线.
uchar t0,xiaomiao,miao,fen,shifen,baifen,qianfen,i;
void delayms(uint xms)//正常延时
uint i,j;
for(i=xms;i>0;i--)
  for(j=113;j>0;j--);
void delay()//微妙延时
/*蜂鸣器设置 */
void fengming()
feng=0;
delayms(10);
feng=1;
delayms(10);
/*液晶读写程序 */
void write_cmd(uchar cmd)
key1=0;
P0=cmd;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void write_date(uchar date)
key1=1;
P0=date;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
/*键控程序段*/
void keyscan()//设两个变量作为加减项
  if(key2==0)
   delayms(10);
   if(key2==0)
    TR0=0;
    fengming();
    i++;
    if(i>3)
    i=0;
    TR0=1;
    while(!key2);
  if(key3==0)
   delayms(10);
   if(key3==0)
    fengming();
    if(i==1)
               xiaomiao++;
    if(i==2)
     fen++;
    if(i==3)
     baifen++;
    while(!key3);
/*AT24c02程序 */
void start()
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop()
sda=0;
delay();
scl=1;
delay();
sda=0;
delay();
void respons()
uchar i;
scl=1;
delay();
while((sda==1)&&(i<255))
  i++;
scl=0;
delay();
void write_byte(uchar date)
uchar j,temp;
temp=date;
for(j=0;j<8;j++)
   scl=0;
   temp=temp<<1;
   delay();
   sda=CY;
   delay();
   scl=1;
   delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
  scl=0;
  delay();
  k=k<<1|sda;
  scl=1;
  delay();
    scl=0;
delay();
sda=1;
delay();
return k;
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
respons();
date=read_byte();
stop();
return date;
void init()//初始化
/*定时器初始化*/
TMOD=0x01;
TH0=(65536-45782)/256;
TL0=(65536-45782)%256;
EA=1;
ET0=1;
TR0=1;
/*锁存器初始化*/
dula=0;
wela=0;//由于锁存器的缘故
lcden=0;//使能端工作在高电平,所以开始要定义在低电平
/*AT24c02初始化*/
scl=1;
delay();
sda=1;
delay();
/*1602初始化*/
write_cmd(0x38);
write_cmd(0x0c);
write_cmd(0x06);
write_cmd(0x01);
void main()
init();
    /*读数据程序段*/
xiaomiao=read_add(2);
miao=read_add(1);
fen=read_add(3);
shifen=read_add(4);
baifen=read_add(5);
qianfen=read_add(6);
while(1)
  keyscan();
  if(xiaomiao==10)
   xiaomiao=0;
   miao++;
   if(miao==6)
    miao=0;
    fen++;
  if(fen==10)
   fen=0;
   shifen++;
   if(shifen==6)
   shifen=0;
   baifen++;
  if(baifen==10)
   baifen=0;
   qianfen++;
  if((qianfen>=2)&&(baifen>=4))
   miao=0;
   xiaomiao=0;
   fen=0;
   shifen=0;
   baifen=0;
   qianfen=0;
   /*保存数据的程序段*/
  write_add(1,xiaomiao);
     write_add(2,miao);
  write_add(3,fen);
  write_add(4,shifen);
  write_add(5,baifen);
  write_add(6,qianfen);
  write_cmd(0x80+0x04);
  write_date(0x30+qianfen);//  千分
  delayms(50);
  write_date(0x30+baifen);//百分
  delayms(50);
  write_date(':');//:
  delayms(50);
  write_date(0x30+shifen);//十分
  delayms(50);
  write_date(0x30+fen);//分
  delayms(50);
  write_date(':');//:
  delayms(50);
  write_date(0x30+miao);//秒
  delayms(50);
  write_date(0x30+xiaomiao); //小秒
  delayms(50);
void t0_time() interrupt 1
t0++;
  if(t0==20)
  t0=0;
  xiaomiao++;
 楼主| heilongqq 发表于 2009-9-27 10:33 | 显示全部楼层
谢谢大家了,我刚才才发现在read_add这个程序写错了,多写了一个dizhi
hujinping 发表于 2009-9-27 16:07 | 显示全部楼层
要细心啊,呵呵
个人签名:希望每天进步
25
