PS2通信过程有丢失数据的现象
 楼主| 栩栩如生 发表于 2016-10-15 17:39 | 显示全部楼层 |阅读模式
用 CY7C63813 做的自动识别 USB,PS2 鼠标键盘的程序,PS2 通信是在PS2M模块程序的基础上修改的,现在发现PS2通信过程有丢失数据的现象
houcs 发表于 2016-10-15 17:42 | 显示全部楼层
什么现象
 楼主| 栩栩如生 发表于 2016-10-15 17:44 | 显示全部楼层
比如滚动鼠标的滚轮正常的数据是:0x08,0x00,0x00,0x01;发送丢失数据时会有:0x08,0x00,0x01 或者 0x08,0x00,0x00 现象。
yinxiangh 发表于 2016-10-15 17:45 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
chenjunt 发表于 2016-10-15 17:47 | 显示全部楼层
CY7C63813做的PS2鼠标键盘通信过程丢失数据
01. PS2M_Send:
02._PS2M_Send:
03..data:    equ -1                             ; Local stack variables
04..cnt:     equ -2
05..parity:  equ -3
06.;        M8C_DisableGInt
07.    PUSH    X                               ; Build the local variable
08.    ADD     SP, 3                           ;
09.    MOV     X, SP                           ;
10.    MOV     [X + .data], A                  ; Save off the data byte
11.    MOV     [X + .parity], 1                ; Start the parity at 1
12.    MOV     [X + .cnt], 8                   ; Send 8 data bits
13.        MOV                [_fHostRqs], 0
14.; Test for inhibit
15.    TST    REG[PS2M_DR], PS2M_SCLK          ; Inhibit?
16.    JZ     .rts                    ; Continue to wait if we are inhibited
17.
18.    DELAY    20, 60                           ; Min delay between check for inhibit
19.
20.    TST    REG[PS2M_DR], PS2M_SCLK          ; Inhibit?
21.    JZ     .rts                    ; Continue to wait if we are inhibited
22.
23.; Test for RTS
24.    TST    REG[PS2M_DR], PS2M_SDATA         ; RTS?
25.    JZ     .rts                             ; Jump if RTS
26.; change data pin to output mode
27.        OR           REG[P01CR], 0x01
28.        OR           REG[P02CR], 0x01                                        ;test debug
29.; Flow here to send start bit
30.    CALL   PS2M_Send_0                      ; Start bits are zero
31.    JC     .inhib                           ; Host has inhibited
32.
33.    DELAY  2, 12                            ; Wait 2 uSec
34.
35.; Flow or jump here to sent the data bits
36..snb:
37.    ASR    [X + .data]                       ; rotate the next bit to the carry
38.    JC     .s1                               ; and send a 1 or 0 based
39..s0:
40.    CALL   PS2M_Send_0                       ; Send 0
41.    JMP    .cont
42..s1:
43.    INC    [X + .parity]                     ; Count the number of 1 bits for the parity
44.    CALL   PS2M_Send_1                       ; Send 1
45..cont:
46.    JC     .inhib                            ; Did the host inhibit us during the last bit?
47.    DEC    [X + .cnt]                        ; If not, send the next bit
48.    JZ     .s_parity                         ; When it hits zero, do the parity
49.    JNC    .snb                              ; It will carry after the parity bit is sent
50.
51.; Flow here to send the stop bit
52.    CALL   PS2M_Send_1                       ; Stop bits are 1
53.    JMP    .success
54.
55.; Flow here after all 8 data bits have been clocked out
56..s_parity:
57.    MOV    A, [X + .parity]                  ; clock out the lsb of the parity
58.    MOV    [X + .data],a                     ; Save the data
59.    JMP    .snb
60.
61.; Jump here on a successful stop bit
62..success:
63.    MOV    A, 0                              ; Flow here after a successful stop bit
64.;    CMP                [PS2M_bCmdCnt], 0x00
65.;        JZ                .exit
66.;        CALL   PS2M_ReadSendBuffer
67.        JMP    .exit
68.; Jump here if we failed because we were inhibited
69..inhib:                                     ; Jump here for any failed bit
70.        OR     reg[PS2M_DR], PS2M_CLKH_DATAH
71.        MOV                [_fHostRqs], 1
72.        MOV    A, 0x88
73.    JMP    .exit
74.; Jump here if we found a RTS
75..rts:                                        ; Jump here for a RTS
76.    MOV    A, 0x90                           ;
77.; Jump or flow here to exit
78..exit:
79.        ;change data pin to input mode
80.        AND           REG[P01CR], 0xfe
81.        AND           REG[P02CR], 0xfe                                        ;test debug
82.    ADD    SP, -3                            ; Clean up the stack
83.    POP    X
84.;        M8C_EnableGInt
85.        PUSH   A
86.        DELAY    38, 12                         ; Wait 38 uSec
87.        POP           A
88.    RET
89.;-----------------------------------------------------------------------------
90.;  FUNCTION NAME: PS2M_Send_1, PS2M_Send_0
91.;  DESCRIPTION:   Local function.  Assembly interface only.
92.;
93.;-----------------------------------------------------------------------------
94.;
95.;  ARGUMENTS:
96.;
97.;  RETURNS:
98.;
99.;  SIDE EFFECTS: REGISTERS ARE VOLATILE: THE A AND X REGISTERS MAY BE MODIFIED!
100.;
101.;  THEORY of OPERATION or PROCEDURE:
102.;
103.;-----------------------------------------------------------------------------
104.PS2M_Send_1:
105.    OR     REG[PS2M_DR], PS2M_SDATA  ; Set the data bit high
106.        DELAY    10, 12                         ; Wait 10 uSec
107.    ; Clock Low                             ; Clock Low and the data
108.    AND    REG[PS2M_DR], ~PS2M_SCLK          ; Clock Low
109.    DELAY    38, 12                         ; Wait 38 uSec
110.    ; Clock High                            ; Finally Clock High and the data
111.    OR     REG[PS2M_DR], PS2M_SCLK          ; Clock High
112.    DELAY    22, 60                         ; Wait 22 uSec
113.    ; Check for inhibit
114.    CLEARC                                  ; Carry clear indicates success
115.        AND           REG[P02CR], 0xfe                                        ;test debug
116.        TST    REG[PS2M_DR], PS2M_SCLK          ; Inhibit?
117.    JNZ    .clock_done                      ; Jump if not
118.    SETC                                    ; Carry set indicates fail/Inhibit
119..clock_done:
120.    ; Done
121.        OR           REG[P02CR], 0x01                                        ;test debug
122.    RET
123.
124.
125.
126.PS2M_Send_0:
127.        AND     REG[PS2M_DR], ~PS2M_SDATA                  ; clear the data bit high
128.        DELAY    10, 12                         ; Wait 10 uSec
129.    ; Clock Low                             ; Clock Low and the data
130.    AND    REG[PS2M_DR], ~PS2M_SCLK          ; Clock Low
131.    DELAY    38, 12                         ; Wait 38 uSec
132.    ; Clock High                            ; Finally Clock High and the data
133.    OR     REG[PS2M_DR], PS2M_SCLK          ; Clock High
134.    DELAY    22, 60                         ; Wait 22 uSec
135.    ; Check for inhibit
136.    CLEARC                                  ; Carry clear indicates success
137.    AND           REG[P02CR], 0xfe                                        ;test debug
138.        TST    REG[PS2M_DR], PS2M_SCLK          ; Inhibit?
139.    JNZ    .clock_done                      ; Jump if not
140.    SETC                                    ; Carry set indicates fail/Inhibit
141..clock_done:
142.    ; Done
143.        OR           REG[P02CR], 0x01                                        ;test debug
144.    RET
morrisk 发表于 2016-10-15 17:50 | 显示全部楼层
不懂,你自己研究吧
 楼主| 栩栩如生 发表于 2016-10-15 17:51 | 显示全部楼层
结贴了,多谢大家讨论这么多哈,呵呵
