[资料工具] NV32与MAX7219
 楼主| tang87633187 发表于 2018-7-27 14:31 | 显示全部楼层 |阅读模式
include "common.h"
#include "ics.h"
#include "rtc.h"
#include "uart.h"
#include "gpio.h"
#include "sysinit.h"
#include "start.h"
#include "adc.h"
* Global variables
* Constants and macros
* Local types
* Local function prototypes
* Local variables
* Local functions
void delay( int t )
{    int k,j;
            for(k=0;k<t;k++)
       for(j=0;j<1000;j++)
void SCLK(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTC0);
          else
            GPIO_PinClear(GPIO_PTC0);
        void Load(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTC1);
          else
            GPIO_PinClear(GPIO_PTC1);
        void DIN(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTD5);
          else
            GPIO_PinClear(GPIO_PTD5);
         void Max7219_SendData( char add ,char dat)
         {  int num=0;
                   char i=0;
                  num=((add<<8)|dat);
                 Load(0);
                 for(i=0;i<16;i++)
                 {  if((num&0x8000)!=0)
                             DIN(1);
                           else
                                         DIN(0);
                                   num=num<<1;
                           SCLK(1);
                                  delay(1);
                                 SCLK(0);
                            delay(1);
                 Load(1);
void Max7219_Init( )
        {  Max7219_SendData(0x0c,0x01);
                 Max7219_SendData(0x0b,0x07);
                 Max7219_SendData(0x0a,0xf5);
                 Max7219_SendData(0x09,0);
char led[10]={ 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
  char  MAX7219_SEG[10]={0x7e,0x30,0x6D,0x79,0x33,0x5B,0x5F,0x70,0x7F,0x7B};
int main (void);
void RTC_Task(void);
* Global functions
int main (void)
{ char temp;
        char i;
        int j,k;
  long int adc_data;
  char da[8];
        ADC_ConfigType  sADC_Config = {0};
    sysinit();
    cpu_identify();
                 GPIO_PinInit(GPIO_PTC0, GPIO_PinOutput);
                 GPIO_PinInit(GPIO_PTC1, GPIO_PinOutput);
                 GPIO_PinInit(GPIO_PTD5, GPIO_PinOutput);
         Max7219_Init( );
         while(1)
                 for(i=0;i<8;i++)
                Max7219_SendData(1+i,  MAX7219_SEG);
* @ TRCÈÎÎñ×Óº¯ÊýÉÁ˸LED1
*  ÎÞ·µ·µ»Ø
void RTC_Task(void)
xujunyi3611 发表于 2018-8-26 17:25 | 显示全部楼层
MAX7219,这是什么芯片呢?串口吗?
