- * main.c
- * MSP-EXP430G2-LaunchPad (v1.5+) User Experience Application for
- * Communication to ADS1118
- * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the
- * distribution.
- * Neither the name of Texas Instruments Incorporated nor the names of
- * its contributors may be used to endorse or promote products derived
- * from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
- * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
- * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * MSP-EXP430G2-LaunchPad User Experience Application for Communication to ADS1118
- * 1. Program uses GRACE configuration for Device Configuration;
- * - SMCLK, ACLK, DCO at 1MHz
- * - USCIA0 as UART, 9600, 8 bits Data, No parity, 1 Stop (Hardware Mode)
- * - USCIB0 as 3 line SPI, Master Mode, 50kHz SCLK
- * - P2.0 used as CS for ADS1118 ADC device
- * 2. Application Mode
- * - Initial start configures device on power up
- * - Configures connected ADS1118 device for differential measurement
- * pairs of AIN0-AIN1 and AIN2-AIN3
- * - Data is transmitted in continuous loop
- * - Runs ADS1118 in single shot mode reading first pair, changing mux and then
- * second pair storing data in a data array
- * - After data is read, data is sent out UART for display as ASCII hex representation
- * Changes:
- * 1.0 Initial Release Version
- * Texas Instruments, Inc.
- * ======== Standard MSP430 includes ========
- #include <msp430g2553.h>
- * ======== Grace related includes ========
- #include <ti/mcu/msp430/csl/CSL.h>
- * ======== Function Calls ========
- void uart_txc(char c);
- void uart_txstr(char *c);
- /* "hex2asc" Converts a 32-bit integer n into an ASCII string.
- digs is the maximum number of digits to display. Conversion is controlled
- by mode, as follows:
- - mode = 0: Leading zeroes are not printed. The string may be
- less than digs digits long.
- - mode = 1: Spaces are printed in place of leading zeroes. The
- string will be digs digits long.
- - mode = 2: Leading zeroes are printed. The string will be digs
- digits long.
- If the number is zero, at least one zero is printed in all modes.
- This routine works by converting n to an 8-byte BCD number and calling
- hex2asc. No division by 10 is performed.
- int hex2asc(void *n, int digs, int mode, char *s);
- void ADS_Config(void);
- void ADS_Read(int data[]);
- void Send_Result(int *data);
- void Port_Config(void);
- signed int WriteSPI(unsigned int config, int mode);
- void delay(void);
- #define h2a(d) ((d>9)?(d+'A'-10):(d+'0'))
- #define LITTLEENDIAN 1
- * ======== main ========
- int main(int argc, char *argv[])
- CSL_init(); // Activate Grace-generated configuration
- // >>>>> Fill-in user code here <<<<<
- // Initialize TC data array
- signed int data[6];
- // Port configuration
- Port_Config();
- // Set ADS1118 configuration
- ADS_Config();
- while (1)
- // Read the data from both input pairs
- ADS_Read(data);
- // Transmit the data out the UART
- Send_Result(data);
- return (0);
- // Set P1.0, P1.3, P1.4, P2.1, P2.2, P2.4, P2.5, P2.6 and P2.7 low
- P1OUT = 0x00;
- P2OUT = 0x01 ;
- * Initial configuration routine. A header file could be created, but the configuration is really rather simple.
- * In this case a 16-bit value representing the register contents is set to variable temp
- int i;
- unsigned int temp;
- // Set the configuration to AIN0/AIN1, FS=+/-1.024, SS, DR=128sps, PULLUP on DOUT
- temp = 0x78A;
- // Set CS low and write configuration
- P2OUT &= ~BIT0;
- // Write the configuration
- WriteSPI(temp,0);
- // Set CS high to end transaction
- P2OUT |= BIT0;
- unsigned int j, temp;
- temp = 0x78A;
- P2OUT &= ~BIT0;
- // First the data is captured by writing to each device to take start a conversion for A0-A1
- WriteSPI(temp,1);
- P2OUT |= BIT0;
- * Now we pause slightly before reading the data, or it is possible to either poll the DOUT/DRDY or enable an interrupt
- * where the DOUT/DRDY transition from high to low triggers a read. In this case it is kept quite simple with a delay
- delay(); // May be needed depending on method
- // When we read the data we restart the conversion with new mux channel A2-A3
- temp = 0x378A;
- P2OUT &= ~BIT0;
- // Read the earlier conversion result and set to the new configuration
- data[0] = WriteSPI(temp,1);
- // Read second channel data
- data[1]=WriteSPI(temp,0);
- P2OUT |= BIT0;
- signed int msb;
- char dummy;
- temp = config;
- if (mode==1) temp = config | 0x8000; // if mode is set to 1, this command should initiate a conversion
- * The process of communication chosen is to always send the configuration and read it back
- * this results in a four byte transaction. The configuration is 16-bit (or 2 bytes) and is transmitted twice.
- while(!(UC0IFG&UCB0TXIFG)); // Make sure buffer is clear
- * First time configuration is written
- UCB0TXBUF = (temp >> 8 ); // Write MSB of Config
- while(!(UC0IFG&UCB0RXIFG));
- msb=UCB0RXBUF; // Read MSB of Result
- UCB0TXBUF= (temp & 0xff); // Write LSB of Config
- msb = (msb << 8) | UCB0RXBUF ; //Read LSB of Result
- * Second time configuration is written, although data could be sent as NOP in either transmission, just simplified in this case
- dummy=UCB0RXBUF; // Read MSB of Config
- * One advantage of reading the config data is that DOUT/DRDY is forced high which makes it possible to either poll the state or set an interrupt
- dummy=UCB0RXBUF; //Read LSB of Config
- return msb;
- * Following code relates to formatting the data for transmission on UART
- unsigned int i;
- int intval = 0;
- char char_array[5];
- // Poke out data
- uart_txstr("TEMPS:");
- uart_txc('\r');
- uart_txc('\n');
- for (i=0; i<2; i++)
- intval = data[i];
- hex2asc(&intval, 4, 2, char_array);
- uart_txstr(char_array);
- uart_txc('\r');
- uart_txc('\n');
- int hex2asc(void *npos, int digs, int mode, char *s)
- int i,zero;
- char dig;
- char *spos=s;
- char *n=(char *)npos;
- zero=1;
- #if LITTLEENDIAN
- n+=(digs-1)>>1;
- #else
- n+=(16-digs)>>1;
- #endif
- for (i=digs-1;i>=0;--i) {
- if (i&1) {
- dig=(*(char *)n>>4)&15;
- } else {
- dig=*(char *)n&15;
- #if LITTLEENDIAN
- --n;
- #else
- ++n;
- #endif
- if (zero&&dig)
- zero=0;
- if (zero) {
- switch(mode) {
- case 1:
- *spos++=' ';
- break;
- case 2:
- *spos++='0';
- break;
- default:
- break;
- } else
- *spos++=h2a(dig);
- if (zero&&mode==1)
- *(spos-1)='0';
- else if (zero&&mode==0)
- *spos++='0';
- *spos=0;
- return spos-s;
- while (!((UC0IFG&UCA0TXIFG)));
- UCA0TXBUF=c;
- while (*c) uart_txc(*(c++));
- void delay(void)
- unsigned int k;
- for (k = 8000; k = 0; k--) __no_operation();
