TIM4的PWM仿真不能得到现象
 楼主| 白闻不如怡见 发表于 2019-11-20 12:10 | 显示全部楼层 |阅读模式
我想使用TIM4的PWM功能,不知道为什么仿真得不到结果呢?
代码如下,求大神看看问题出在哪里:
#include "tim4pwm.h"
uint32_t CCR2VAL = 500;
static void TIM4PWM_GPIO_Config(void)
        /* TIM4 clock enable */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
        /* GPIOD clock enable */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
        /*GPIOD Configuration: TIM4 channel 2 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_13;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
static void TIM4PWM_Mode_Config(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        TIM_TimeBaseStructure.TIM_Period = 999;       //当定时器从0计数到999,即为1000次,为一个定时周期
        TIM_TimeBaseStructure.TIM_Prescaler = 0;            //设置预分频:不预分频,即为72MHz
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //设置时钟分频系数:不分频
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数模式
        TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = CCR2VAL;          //设置通道2的电平跳变值,输出另外一个占空比的PWM
        TIM_OC2Init(TIM4, &TIM_OCInitStructure);          //使能通道2
        TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM4, ENABLE);                         // 使能TIM4重载寄存器ARR
        /* TIM4 enable counter */
        TIM_Cmd(TIM4, ENABLE);                   //使能定时器4
void TIM4PWMInit(void)
        TIM4PWM_GPIO_Config();
        TIM4PWM_Mode_Config();
