下位机代码:
- /* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved. */
- #include <stdio.h>
- #include "Driver\DrvGPIO.h"
- #include "Driver\DrvPWM.h"
- static S_DRVPWM_TIME_DATA_T sPt,sPtCAS;
- static uint8_t is_run=0;
- void DRVPWM_PwmIRQHandler()
- //周期之后执行
- void drvpwm_timer_run()
- /* Enable PWM clock */
- DrvPWM_Open();
- /* Set PWM pins */
- DrvGPIO_InitFunction(E_FUNC_PWM01);
- /* PWM Timer property */
- sPt.u8Mode = DRVPWM_AUTO_RELOAD_MODE;
- sPt.u32Frequency = 1; //PWM频率
- sPt.u8HighPulseRatio = 1; /* High Pulse peroid : Total Pulse peroid = 1 : 100 */
- sPt.i32Inverter = 0;
- /* Select PWM engine clock */
- DrvPWM_SelectClockSource(DRVPWM_TIMER0, DRVPWM_HCLK);
- /* Set PWM Timer0 Configuration */
- DrvPWM_SetTimerClk(DRVPWM_TIMER0, &sPt);
- /* Enable Output for PWM Timer0 */
- DrvPWM_SetTimerIO(DRVPWM_TIMER0, 1);
- /* Enable Interrupt Sources of PWM Timer0 and install call back function */
- DrvPWM_EnableInt(DRVPWM_TIMER0, 0, DRVPWM_PwmIRQHandler);
- /* Enable the PWM Timer 0 */
- DrvPWM_Enable(DRVPWM_TIMER0, 1);
- void DRVPWM_CAPS()
- DrvPWM_Open();
- DrvGPIO_InitFunction(E_FUNC_PWM23);
- /* PWM Timer property for Capture */
- sPtCAS.u8Mode = DRVPWM_AUTO_RELOAD_MODE;
- sPtCAS.u32Frequency = 100; /* Set the proper frequency to capture data (Less than the input data)*/
- sPtCAS.u8HighPulseRatio = 50; /* High Pulse peroid : Total Pulse peroid = 50 : 100 (Set a non-zero value) */
- sPtCAS.u32Duty = 0x10000; /* Set the counter to the maximum value */
- sPtCAS.i32Inverter = 0;
- //u8CapTimer = DRVPWM_CAP3;
- DrvPWM_SelectClockSource(DRVPWM_CAP3, DRVPWM_HCLK);
- /* Set PWM Timer 3 for Capture */
- DrvPWM_SetTimerClk(DRVPWM_CAP3, &sPt);
- /* Enable Interrupt Sources of PWM Capture3 */
- DrvPWM_EnableInt(DRVPWM_CAP3, DRVPWM_CAP_FALLING_INT, NULL);
- /* Enable Input function for PWM Capture 3 */
- DrvPWM_SetTimerIO(DRVPWM_CAP3, 1);
- /* Enable the PWM Capture3 */
- DrvPWM_Enable(DRVPWM_CAP3, 1);
- /* Capture the Input Waveform Data */
- //CalPeriodTime(DRVPWM_CAP3);
- /* Stop PWM Timer 1 (Recommended procedure method 1) */
- /* Set PWM Timer counter as 0, When PWM internal counter reaches to 0, disable PWM Timer*/
- /* Set PWM Timer 1 counter as 0 */
- //DrvPWM_SetTimerCounter(u8Timer, 0);
- /* Disable PWM Timer 1 */
- //DrvPWM_Enable(u8Timer, 0);
- /* Disable Output function for PWM Timer 1 */
- //DrvPWM_SetTimerIO(u8Timer, 0);
- /* Stop PWM Timer 3 (Recommended procedure method 1) */
- /* Set PWM Capture 3 counter as 0 */
- DrvPWM_SetTimerCounter(DRVPWM_CAP3, 0);
- /* Clear the PWM Capture 3 Interrupt */
- // DrvPWM_ClearInt(DRVPWM_CAP3);
- /* Disable PWM Capture 3 */
- // DrvPWM_Enable(DRVPWM_CAP3, 0);
- /* Disable Input function for PWM Capture 3 */
- // DrvPWM_SetTimerIO(DRVPWM_CAP3, 0);
- void set_pwm_u8HighPulseRatio(const uint8_t * buf)
- if(is_run==0)
- is_run=1;
- drvpwm_timer_run();
- sPt.u8HighPulseRatio = buf[4];
- if(buf[2]==1)
- else
- void set_pwm_u32Frequency(const uint8_t * buf)
- if(is_run==0)
- is_run=1;
- sPt.u32Frequency = buf[7]*256*256*256+buf[6]*256*256+buf[5]*256+buf[4];
- if(buf[2]==1)
- else
- void drvpwm_timer_stop()
- DrvPWM_Enable(DRVPWM_TIMER0, 0);
- void drvpwm_timer_clear()
- DrvPWM_Close();
- void drvpwm_start(uint8_t * buf)
- switch(buf[2])
- case 1:
- //DRVPWM_TIMER
- switch(buf[3])
- case 1:
- //设置频率
- set_pwm_u32Frequency(buf);
- break;
- case 2:
- //设置高电平比率 x/100 (0-100)
- set_pwm_u8HighPulseRatio(buf);
- break;
- break;
- case 2:
- //DRVPWMCAS
- switch(buf[3])
- case 1:
- //设置频率
- break;
- case 2:
- break;
- break;
上位机程序:
- private void Set_u8HighPulseRatio_Scroll(object sender, EventArgs e)
- this.commandDate[1] = 0x2;
- this.commandDate[2] = 0x3;//PWM实验
- this.commandDate[3] = 0x1;//pwm输出实验
- this.commandDate[4] = 0x2;//调节亮度
- this.commandDate[5] = (byte)Convert.ToByte(100 - this.Set_u8HighPulseRatio.Value);
- this.NUM_u8HighPulseRatio.Text = this.Set_u8HighPulseRatio.Value.ToString();
- this.SendData();
- private void Set_u32Frequency_Scroll(object sender, EventArgs e)
- this.commandDate[4] = 0x1;//调节频率
- byte[] temp = System.BitConverter.GetBytes(this.Set_u32Frequency.Value);
- for (int i = 0; i < temp.Length; i++)
- this.commandDate[i + 5] = temp[i];
- this.NUM_u32Frequency.Text = this.Set_u32Frequency.Value.ToString();
- this.SendData();
界面:
看贴要回贴才是乖孩子!!
上位机+下位机程序:
