[资料工具] OLED屏的初始化函数
 楼主| 一点点0321 发表于 2020-8-21 13:02 | 显示全部楼层 |阅读模式
void OLED_Init(void)
    //SSD1306
    OLED_SCLK_Set();
    OLED_SDIN_Set();
    Delay_1ms(800);
    OLED_WR_Byte(0xAE,OLED_CMD);//--display off
        OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
        OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
        OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
        OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
        OLED_WR_Byte(0x81,OLED_CMD); // contract control
        OLED_WR_Byte(0xFF,OLED_CMD);//--128
        OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
        OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
        OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
        OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
        OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
        OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
        OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
        OLED_WR_Byte(0x80,OLED_CMD);//
        OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
        OLED_WR_Byte(0x05,OLED_CMD);//
        OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
        OLED_WR_Byte(0xF1,OLED_CMD);//
        OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
        OLED_WR_Byte(0x12,OLED_CMD);//
        OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
        OLED_WR_Byte(0x30,OLED_CMD);//
        OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
        OLED_WR_Byte(0x14,OLED_CMD);//
        OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
weifeng90 发表于 2020-9-18 19:08 来自手机 | 显示全部楼层
点亮没有啊?
guijial511 发表于 2020-9-18 19:17 来自手机 | 显示全部楼层
只是程序,没有板子?
