五线数码管02
 楼主| 34af9uc 发表于 2020-10-2 14:58 | 显示全部楼层 |阅读模式
/*******************五线数码管*********************/
/********************PMS150G***********************/
/****************QQ774145445***********************/
/****************快手:共同学习STM8*****************/
/****************20200926**************************/
//__________________________________________
//|         __2a__     __3a__    4a   4b    |
//| 1a|    |     |    |     |    IN   OUT   |
//|   |  2f|   2b|  3f|   3b|    4c   4d    |
//|        __2g__      __3g__    5V  2.1A   |
//| 1b|    |     |    |     |               |
//|   |    |     |  3e|   3c| 4e 4f   4g    |
//|        __2d__     __3d__  %  5V  1.0A   |
//|            @1  @2  @3  @4  @5           |
//|_________________________________________|
//|      |  1-  |  2-  |  3-  |  4-  |  5-  |
//|  1+  |  **  |  2f  |  2b  |  2d  |  2g  |
//|  2+  | 1a1b |  **  |  3a  |  3c  |  3f  |
//|  3+  |  2a  |  3g  |  **  |  4e  |  4b  |
//|  4+  |  2c  |  3b  |  3d  |  **  | 4f4g |
//|  5+  |  2e  |  3e  |  4a  | 4c4d |  **  |
//      --|VDD       GND|--
//    @4--|PA7       PA0|--@1
//    @5--|PA6       PA4|--@2
//   PWM--|PA5       PA3|--@3
led_1                bit                pa.0;
led_2                bit                pa.4;
led_3                bit                pa.3;
led_4                bit                pa.7;
led_5                bit                pa.6;
void                xianshi_fenjie();        //显示分解
void                xianshi();                        //显示
void                yanshi();                        //延时
byte                xianshi_a1;                        //要显示的数字0-199
byte                xianshi_c1;                        //百位字模
byte                xianshi_c2;                        //十位字模
byte                xianshi_c3;                        //个位字模
#include        "extern.h"
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
byte        a1=0;
byte        a2;
$                led_1                out;
$                led_2                out;
$                led_3                out;
$                led_4                out;
$                led_5                out;
while(1)
xianshi_a1=a1;
xianshi_fenjie();
a2=50;
while(a2)
        a2        --;
        xianshi();
a1++;
void                xianshi_fenjie()                //显示分解
        byte                xianshi_b1;                //百位
        byte                xianshi_b2;                //十位
        byte                xianshi_b3;                //个位
        byte                xianshi_b4;
        xianshi_b1                =0;
        xianshi_b2                =0;
        xianshi_b3                =0;
        xianshi_b4                =xianshi_a1;
        while(xianshi_b4>99)                        //代替除法计算出百位
                xianshi_b4                -=100;
                xianshi_b1                ++;
        while(xianshi_b4>9)                                //代替除法计算出十位
                xianshi_b4                -=10;
                xianshi_b2                ++;
        xianshi_b3                =xianshi_b4;        //个位
/**************************************************/                //查表
//共阳0-9//0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90
//共阴0-9//0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
xianshi_c1                =xianshi_b1;                                //百位
if        (xianshi_b2        ==0){xianshi_c2        =0x3f;}                //0十位字模
if        (xianshi_b2        ==1){xianshi_c2        =0x06;}                //1
if        (xianshi_b2        ==2){xianshi_c2        =0x5b;}                //2
if        (xianshi_b2        ==3){xianshi_c2        =0x4f;}                //3
if        (xianshi_b2        ==4){xianshi_c2        =0x66;}                //4
if        (xianshi_b2        ==5){xianshi_c2        =0x6d;}                //5
if        (xianshi_b2        ==6){xianshi_c2        =0x7d;}                //6
if        (xianshi_b2        ==7){xianshi_c2        =0x07;}                //7
if        (xianshi_b2        ==8){xianshi_c2        =0x7f;}                //8
if        (xianshi_b2        ==9){xianshi_c2        =0x6f;}                //9
if        (xianshi_b3        ==0){xianshi_c3        =0x3f;}                //0个位字模
if        (xianshi_b3        ==1){xianshi_c3        =0x06;}                //1
if        (xianshi_b3        ==2){xianshi_c3        =0x5b;}                //2
if        (xianshi_b3        ==3){xianshi_c3        =0x4f;}                //3
if        (xianshi_b3        ==4){xianshi_c3        =0x66;}                //4
if        (xianshi_b3        ==5){xianshi_c3        =0x6d;}                //5
if        (xianshi_b3        ==6){xianshi_c3        =0x7d;}                //6
if        (xianshi_b3        ==7){xianshi_c3        =0x07;}                //7
if        (xianshi_b3        ==8){xianshi_c3        =0x7f;}                //8
if        (xianshi_b3        ==9){xianshi_c3        =0x6f;}                //9
void                xianshi()                        //显示
$                led_1                out,high;        //第一种状态
$                led_2                in;
$                led_3                in;
$                led_4                in;
$                led_5                in;
if(xianshi_c2.5)                //2f
{$        led_2        out,low;}
if(xianshi_c2.1)                //2b
{$        led_3        out,low;}
if(xianshi_c2.3)                //2d
{$        led_4        out,low;}
if(xianshi_c2.6)                //2g
{$        led_5        out,low;}
yanshi();
$                led_1                in;        //第二种状态
$                led_2                out,high;
$                led_3                in;
$                led_4                in;
$                led_5                in;
if(xianshi_c1)                        //1a1b百位
{$        led_1        out,low;}
if(xianshi_c3.0)                //3a
{$        led_3        out,low;}
if(xianshi_c3.2)                //3c
{$        led_4        out,low;}
if(xianshi_c3.5)                //3f
{$        led_5        out,low;}
yanshi();
$                led_1                in;        //第三种状态
$                led_2                in;
$                led_3                out,high;
$                led_4                in;
$                led_5                in;
if(xianshi_c2.0)                //2a
{$        led_1        out,low;}
if(xianshi_c3.6)                //3g
{$        led_2        out,low;}
//if(xianshi_c2.3){$        led_2        out,low;}        //4e
$        led_4        out,low;                //百分号
//if(xianshi_c2.6){$        led_2        out,low;}        //4b
yanshi();
$                led_1                in;        //第四种状态
$                led_2                in;
$                led_3                in;
$                led_4                out,high;
$                led_5                in;
if(xianshi_c2.2)                //2c
{$        led_1        out,low;}
if(xianshi_c3.1)                //3b
{$        led_2        out,low;}
if(xianshi_c3.3)                //3d
{$        led_3        out,low;}
//if(xianshi_c2.6){$        led_5        out,low;}        //4f4g
yanshi();
$                led_1                in;        //第五种状态
$                led_2                in;
$                led_3                in;
$                led_4                in;
$                led_5                out,high;
if(xianshi_c2.4)                //2e
{$        led_1        out,low;}
if(xianshi_c3.4)                //3e
{$        led_2        out,low;}
//if(xianshi_c2.3){$        led_3        out,low;}        //4a
//if(xianshi_c2.6){$        led_4        out,low;}        //4c4d
yanshi();
void        yanshi()                        //延时
.delay                8000;
五线数码管03 (2).rar
1.4 KB, 下载次数: 24
319
