应广11位PWM输出1.7MHZ
 楼主| 34af9uc 发表于 2020-10-12 07:49 | 显示全部楼层 |阅读模式
//***************pms132pa0输出1.7mHZ****************/
//***************11位PWM*IHRC16M********************/
//*****************QQ:774145445*********************/
//**************快手:共同学习stm8*******************/
//*****************20201011*************************/
#include        "extern.h"
led                bit                pb.6;
word        pwm0_a1,pwm0_a2;
void        FPPA0 (void)
//.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
.ADJUST_IC        SYSCLK=IHRC/2, IHRC=17MHz, VDD=5V;
$                pwmg0c                enable,reset,pa0,ihrc;                //
$                pwmg0s                /1/1;
//pwmg0cubh                //pwmg0上限高位
//pwmg0cubl                //pwmg0上限低位
//pwmg0dth                //pwmg0占空比高位
//pwmg0dtl                //pwmg0占空比低位
pwm0_a1                        =36;//34;
pwm0_a1                        <<=4;
pwm0_a2                        =18;//17;
pwm0_a2                        <<=4;
pwmg0cubl                =pwm0_a1$0;
pwmg0cubh                =pwm0_a1$1;
pwmg0dtl                =pwm0_a2$0;                //先写
pwmg0dth                =pwm0_a2$1;
$                led                out,low;
while (1)
led=1;
led=0;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
319
