make -j4 all
Memory region Used Size Region Size %age Used
./Startup/startup_CH573.o: in function `.L0 ':
FLASH: 10148 B 448 KB 2.21%
F:/2021-04-21-F1/CODE/EXAM/SRC/Startup/startup_CH573.S:22:(.vector+0xc): relocation truncated to fit: R_RISCV_JAL against symbol `HardFault_Handler' defined in .text.HardFault_Handler section in ./StdPeriphDriver/CH57x_sys.o
RAM: 2804 B 18 KB 15.21%
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:57: Code_OfficeLock_CH573_v1.0.1_test.elf] Error 1
16:38:56 Build Failed. 2 errors, 0 warnings. (took 24s.139ms)
